Question about Amana ATB1832AR Top Freezer Refrigerator
Ice with white flakes from refrigerator ice maker
My refrigerator ice maker makes ice that has a white flaky substance in it that ends up in your drink - most visible in a glass of water.
  • 403 Answers
Try setting the freeze temperature down to the initial setting selection. Your freezer is getting to cold. Hope this helps.
JimmyC
Posted on Sep 28, 2009
Gritty substance in the ice cubes and icicles
Clean and descale the inside waterways with ice machine cleaner. Check hoses for leaks. Instal in-line filter
Apr 04, 2014 | U-Line Kitchen Appliances - Others
Woodchuck told someone that the flakes coming out of their ice could be the ice mold coming apart. That's the problem I have. Pieces of that mold are flaking off. Do I have to replace that part? What is it...
Replace the complete ice maker . Less hassle and maybe $ 125. total . Only 2 or 3 screws hold the ice maker in place . If you have a side by side , buy the kit for your model . Usually kits are less expensive than buying the ice maker by itself , even though you only use the ice maker out of the kit .
Mar 30, 2011 | Refrigerators
Black specks in ice
2 things can cause this. The coating on the inside of ice maker is coming off which is rare, or the inlet valves rubber o-rings are coming apart, this usually occurs when the ice maker has been off for a while. You should be able to see if the ice maker is flaking off or not. The repair is to replace the part.
May 22, 2010 | Maytag 18.9 Cu. Ft. Top-Mount Refrigerator...
Ice from my ice maker has black specs and white flaky stuff in it.
The black specs are probably pieces of the icemaker mold coming off white stuff is probably calcium deposits. The only way to rectify this is to replace the icemaker.
Feb 23, 2010 | Refrigerators
When ice is dispensed, it leaves little white residue/flakes in the glass.What could be causing this? THANK YOU!
seems to be contaminated water filling the ice maker you should have the water supply check and possibly the water fill valve replaced.
Jan 21, 2010 | Frigidaire FRS26H5AS Side by Side...
Our Whirlpool Refrig GD25DFXFW02 is working fine our problem is the ice maker , the cubes contain white flakes, is there a coating on the ice maker that could be chipping off> We have changed the filter...
The inside coating has come off the inside of the ice maker . The white " flakes " is calcium deposits , sticking to the exposed cast metal , inside the ice maker , and sticking to the cubes , after water freezing in the mold . You need to replace the ice maker .
Nov 02, 2009 | Whirlpool ED2FHEXN Side by Side...
My ice maker produces ice with white flakes in it, and slowly.
If you also get the flakes with the water from the water dispenser it could be the water chiller reservoir behind the crisper in the fridge. If it's just the ice maker the non stick surface in the ice mold may be coming loose.
Oct 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Amana side by side
Undissolved minerals can appear when ice cubes are added to chilled drinking water. Freezing tap water causes dissolved minerals to solidify and scatter, giving a cloudy appearance. When ice cubes melt, any undissolved minerals settle to the bottom. These mineral compounds in our drinking water are naturally occurring and safe.
Sometimes we see black particles which can be the non-stick surface of the ice mold flaking off.
Sep 07, 2009 | Frigidaire FRS23R4A Side by Side...
Amana ATB1832AR Top Freezer Refrigerator Logo
529 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
