Panasonic PT-53WX53 53 in. Rear Projection HDTV-Ready Television
Problem for Panasonic PT-53WX53 53 in. Rear Projection HDTV-Ready...
How do you replace ic chips on Panasonic 52 inch
By irwin_k8th on Sep 28, 2009
How do you replace ic chips on Panasonic 52 inch hdtv projection?
Solution #1
posted on Sep 28, 2009
Not Rated)
techman007
Rank: Guru  Televisions & Videos  Expert
Rating: 90%, 95 votes
Most IC's on circuit boards these days are of the surface mount variety. You will need special Desoldering Equipment to remove these chips, especially the one wth 100 or more pins, the type of equipment used in this process heats all sides of the chip at once while a small suction that grabs the chip for removal. Now the SIP chips (Single inline package). chips which usually consists of less then 20pins can be removed with a desoldering gun such as the HAko 880 desoldering gun. Or you can use a standard soldering iron and solder Wick, that can be found at Radio Shack under Soldering Braide).. These procedures are common for all IC replacement. I am asuming you are trying to remove the Convergence IC on this model, The two large Black one labeled STK-392-110, the correct and easy way to remove these is to remove the entire board from the unit and remove the two screws holdinf each one in place, Unsolder the pins of each one and remove the IC, reverse this process to reinstall them. Good soldering technique is critical here as you don't want to bridge pins together causing yourself more problems. Double check your soldering and Double check it again.
Delhielectronics@live.com
Was this helpful?
Yes
No
Popular Solutions for Panasonic PT-53WX53 53 in.
Questions and Unsolved Problems for Panasonic PT-53WX53 53 in.
Do you recommend Panasonic PT-53WX53 53 in. Rear Projection HDTV-Ready Television?
Answer
Answer
I have a panasonic 52 inch projection comes on get red lines and then shuts off and light flashes 4... (More)
Answer
How do I remove the top part of a PT-53WX53 panasonic rear projection tv. I can get the back off... (More)
Answer
My panasonic 1080i is really dark. It is hard to even see scences that are meant to be dark. I do... (More)
Answer
I don't get a picture only a ocnstant flashing red light when I turn on my Panasonic projection TV.
Answer
I have a Panasonic Cinemavision model # PT-53WX53G. My problem just started this morning. Every... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
