Question about Acer Aspire 3690 Notebook
The screen does not work when i turn it on. When acer aspire 3690 turns on, i only see half of the screen wwith a logo and everything else is black. I also try to press the closed laptop indicator and when i release this then for 1 second i see picture.
  • ssimeonova Sep 28, 2009
    How can I boot in safe mode when I cant see any letter or command? I've tryed with F8 but the screen is Black. I dont know if this should be a screen problem, graphical card problem or the problem with the closed indicator but i'm 100% sure that it is a hardware problem
  • 788 Answers
Try booting into safe mode and see if you get a full display.
If so, you will need to reload your video drivers and hardware.
Posted on Sep 28, 2009
Acer aspire 3690 has pink screen in lower half toward middle of screen
Your screen inverter is going bad, you will need to replace the screen inverter. You can parts on ebay, and you may need to take your computer apart to get it replaced.
Jan 30, 2011 | Acer Aspire 3690-2196 Notebook
Acer aspire 3690 the right half of my screen is black/white/lines
It sounds to me like your screen has gone and needs to be replaced
Apr 22, 2010 | Acer Aspire 3690 Notebook
Help... Acer Aspire 3690 laptop.
My dear friend as I told you that you should change your RAMs it will b ok give me your response on jazib_qurashi2000@yahoo.com
Nov 19, 2009 | Acer Aspire 3690-2196 Notebook
Black screen!
It sounds like a Back light failure. A good computer shop should be able to repair it. Also could be a screen failure. a lot of work for those who have not worked on these before. but its fixable!! find a local good shop :)
Nov 09, 2009 | Acer Aspire 3690-2196 Notebook
Black screen on Acer 4720Z
If your booting to the splash screen ( ACER Logo screen ) then it goes black reboot - access the bios and do a bios hdd test - you mostlily find your hdd has died. Head scrash
Mar 07, 2009 | Acer Aspire 3690-2196 Notebook
Acer Aspire 3690 remove the screen
There screws all around the lcd that are hidden by black rubber / plastic.
Examine the plastic and you'll see them. Pop them off with a straight blade screwdriver.
Then just unscrew all the screws. Most use only 4-6 screws.
Once they are all out. Carefully pull the plastic housing off with your hands. You shouldn't have to use much force so try to be gentle.
Afterwards you should be able to take it from there. There will be brackets holding the lcd in place.
Take those out and then remove the lcd cable from the back of the screen and the inverter from the bottom portion of the lcd.
Swap the lcds and put everything back together.
That should do the trick.
Let me know if you get stuck.
Feb 24, 2009 | Acer Aspire 3690-2196 Notebook
Cannot get acer laptop to load past the logo screen
you can try to boot up in safe mode, F8 when you turn it on (try to save your personal files to USB Drive)
Most likely, you will have to reload/restore your Operating system...
Feb 02, 2009 | Acer Aspire 3690-2196 Notebook
Acer aspire laptop 3690 display black
Try unplugging the computer from the power supply,,and remove the battery,,,then replace battery and plug into power supply again,,,and try to restart.
Jan 19, 2009 | Acer Aspire 3680 Laptop
Wont work
sounds like you might need a new Hard Drive
Jan 13, 2009 | Acer Aspire 3690-2196 Notebook
Acer 3690 hangs with black screen
hi , check if u can run the system in :"safe mode with VGA"option, or just the safe mode???if it works in safe mode, u will need to restore the O/S to previous checkpoint, or reinstall the OS using "repair" option.let me know
Jan 14, 2008 | Acer Aspire 3690-2196 Notebook
Acer Aspire 3690 Notebook Logo
156 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
