Question about Tanaka 35cc Piston Kit Bladez Moby Scooter Gas P-ring
WILL NOT IDLE - Tanaka 35cc Piston Kit Bladez Moby Scooter Gas P-ring
  • 43 Answers
Vaccuum leak, or idle adjustment screw maladjusted.
Posted on Dec 31, 2009
Car engine idles really high then really low, why?
It can be issue with IAC( idle air control valve) causing the problem.
There are many other possibilities causing these idle issues. Engine idles rough.
There are few help links with solutions to troubleshoot such idle issues.
I suggest you refer the link below and follow its troubleshooting details:------
Click the link below:-----
Ford Expedition IAC valve replacing
http://technoanswers.blogspot.com/2012/12/ford-expedition-iac-valve-replacing.html
Bad miss at idle?
http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
Stumbling and stalling at idle after engine rebuild?
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
1999 Ford F-150 Idles rough and quits when gas pedal is pressed less?
http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html
Engine stumbles coming off idle when warm?
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
Erratic idle on car?
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
GMC Sonoma Stalls and idles low
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
GMC Idle Air Control (IAC) Valve Replacing?
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
1996 Camry intermittent engine failure while idle?
http://repairhelpcenter.blogspot.com/2011/10/1996-camry-intermittent-engine-failure.html
Engine quits at idle?
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
High Idle Problem
http://repairhelpcenter.blogspot.com/2012/10/high-idle-problem.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed?
http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
High rpm in neutral? Inconsistant high RPM in neutral?
http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Vehicle stumbling at idle and shows code 54?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-stumbling-at-idle-and-shows.html
Rough idle, staling and Erratic shifting?
http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
These details will help.
Thanks.
Feb 15, 2013 | 2003 Pontiac Grand Am
Does not idel well some time engin light comes on missies for 2 secomds
Bad miss at idle?
High Idle Problem
Thanks.
Jan 08, 2013 | 2005 Mazda B3000 Cab
Will not idle when cold
Its cold start issues:----
Go through the list of help links mentioned below:----
Click the link :----
Ford explorer 4.0 will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
Bad miss at idle?
High Idle Problem
Thanks.
Dec 14, 2012 | 1999 Jeep Wrangler
1999dodge intrepid 2.7 lite idle low
Car Stalls and idles low
Bad miss at idle?
High Idle Problem
Thanks.
Dec 12, 2012 | 1999 Dodge Intrepid
I have a 98 Malibu when I turn it over it runs rough then dies
Bad miss at idle?
High Idle Problem
Thanks.
Dec 07, 2012 | Cars & Trucks
1993 1500 truck 5.0 high HC at idle
Bad miss at idle?
High Idle Problem
Thanks.
Dec 06, 2012 | 1999 Chevrolet Silverado 1500
2003 spacewagon wont idle when engine is cold
Bad miss at idle?
High Idle Problem
Thanks.
Dec 06, 2012 | Cars & Trucks
92 dodge 1500 pick up 360 v8 automatic Starts, runs but hesitates, low power code 37 on diagnostic readour
Code 37 is torque converter clutch solenoid failure. Transmission wont shift in and out of overdrive.
Nov 28, 2012 | Dodge Cars & Trucks
Ford Taurus idle missing
There are many other possibilities causing these idle issues.Engine idles rough.
Bad miss at idle? http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
High Idle Problem
Thanks.
Nov 24, 2012 | 2001 Ford Taurus
REPLACED THE EGR VACUUM SOLENOID NOW IDLES RUFF AND RPM GO UP AND DOWN AT IDLE
There are many other possibilities causing these idle issues.Engine idles rough.There are few help links with solutions to troubleshoot such idle issues.
I suggest you refer the link below and follow its troubleshooting details:------Click the link below:-----Bad miss at idle? http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
Stumbling and stalling at idle after engine rebuild? http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
1999 Ford F-150 Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html
--------- Engine stumbles coming off idle when warm?
---------- Low idle when cold out side?
GMC Sonoma Stalls and idles low http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
High Idle Problem
Rough idle, staling and Erratic shifting? http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
-----------While stop engine idles like cylinder missing? http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
---------These details will help.Thanks.
Nov 23, 2012 | 2001 Ford Escape
Tanaka 35cc  Piston Kit Bladez Moby Scooter Gas P-ring Logo
108 people viewed this question
Top Tanaka Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Tanaka Toy Expert? Answer questions, earn points and help others
