Question about Exercise & Fitness
Hi, I have a Jazfit T38 treadmill. When I turn
Hi, I have a Jazfit T38 treadmill. When I turn on the treadmill E1 flashes on the screen and the conveyor belt will not move. I've tried turning off the machine and back on, but nothing seems to work. Can you please help me? Thanks :)
3 Suggested Answers
SOURCE: CONVEYOR BELT NOT MOVING ON THE IMAGE TREADMILL
This could be because the belt on the motor that turns the belt you walk on is worn out. it has grooves on this belt that must be prominant to stay in the groves on the front roller and motor. The motor belt can be ordered for about 20$ shipped on ebay the motor belt number is 118016 this is a universal belt and fits this treadmil. Before buying the replacement belt check to see if this is for sure your problem. you can tell by opening the front of your treadmill and looking at the belt. You will see worn spots on the motor belt, or as I noticed when mine went bad, it will look like someone threw a bunch of rubber eracer shavings in your treadmill.
Posted on Aug 19, 2010
  • 33 Answers
SOURCE: Treadmill Spirit machine each time after about 7
hi, check speed sensor -read switch in the near by front roller
Posted on Mar 18, 2011
Jazfit 5002 won't turn on???
If you wish to get some details; check the site http://electro-medical.blogspot.com/. Pull up older posts. Surf the site with patience. check for treadmill articles..
Mar 14, 2016 | Exercise & Fitness
I have a Jazfit 5333 treadmill - the speed and time are not working - led is fine but does not show time or speed just random numbers flash...how do I fix this??
Sounds llike you may have problem with your speed control module which will also be linked to yr time display . Call a treadmill tech for quote & availability of parts cost labour & service
Mar 02, 2015 | Exercise & Fitness
Jazfit 4400 error 7
Sounds like it is time to replace the entire lift mechanism. Usually something like that would have a kit available for such repairs., I'm sure that'a not the first one to go bad. Call our local dealer and find out what the procedure for repairing the lift screw. You can probably pick up n after market replacement at a local parts house a lot cheaper than from a dealer. Good Luck.
Col. Dana Gillespie
Jul 05, 2014 | Office Equipment & Supplies
Jazfit top 49 treadmill
Are you sure its E S and not E 5
Dec 16, 2013 | Exercise & Fitness
Fix error 2 treadmill
this is a probably a faulty sensor speed see the diagram attached. However depend of your mark , model, can be e1 ,tight the connector very well, and clean it. Test the s.speed for open or faulty.
Oct 19, 2013 | Exercise & Fitness
Incline and decline wont move, so the belt wont move either. Have a jazfit treadmill
1)LUBE THE DECK BELT, INMEDIATELY.
2) tES THE MOTOR INPUT VOLTAGE, IF THER ARE THE MOTOR NEED REPAIR.
3) tEST THE OUTPUT VOLTAGE BOARD, FOR INPUT VOLTAGE MOTOR, IF THERE ARE NOT THE BOARD IS FAULTY.
4) tRY TO RUN THE SOFTWARE CALIBRITATION.
SINCERELY.GOD BLESS YOU
May 08, 2012 | Exercise & Fitness
My tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
May 16, 2010 | Exercise & Fitness
Jazfit treadmill wont work
hai, please check control board transformer output
Jul 03, 2009 | Spirit Esprit ET4 Treadmill
Exercise & Fitness Logo
374 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
