Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
BEEN RUNNING ROUGH WITH LESS POWER THAN BEFORE. NOW WON'T START AT ALL. NEW PLUG, CHANGED OIL AND FILTER, HAS A GOOD SPARK.
  • keyosocko Sep 29, 2009
    won't start!! After sitting for several hours, with the choke on full it will try to fire once or twice and belch out a puff of white smoke from the exhaust
  • buddy_bert May 11, 2010
    When running is the exhaust smoke black, blue or white? IF black your engine is getting too much fuel IF blue you are burning oil. IF White you have water in your system.
1956 420 john deere new plugs, wires,cap,plugs,rotor,points set on 20.condenser good blue fire on points and plugs carb rebuilt BUT want start you can pull off it will start and run
Posted on Jul 14, 2011
  • 80 Answers
Even with a good spark you may need to check the points for proper setting and verify they are opening everytime. Check the plug wire to see if it is grounding out. Is there fresh gas in the tank and is the choke sticking on?
John
Posted on Sep 29, 2009
I'm having rough idle and smoke all of a sudden with my golf mk4 The oil warning lights up in dash. Oil level ok. Spark plugs not burning well. Replace spark plugs, changed oil filter, changed
Smoke is not a good sign. Running rough is not a good sign. Oil light not a good sign. You could have a combination of bad things, most likely expensive. Suggest professional help. Smoke can be bad rings or holed piston. Low oil pressure can be bad bearing or oil pump.
Nov 04, 2014 | Volkswagen Golf Cars & Trucks
Changed oil in bmw e36 now spark plug socket and spark plug are showing engine oil (old) Shop gave me wrong oil filter so have not started car yet as I do not have the right filter Also I changed air
IF there is a sleeve around the spark plugs then when replacing the plugs replace the seal under that sleave as well or rocker cover oil will leak out past the plug base.. If you want the correct oil filter you may have to buy genuine . Run fault codes to find the reason for rough idle . It may be a vacuum hose is off or cracked or loose.
Feb 16, 2014 | BMW 318 Cars & Trucks
Runs rough dies
change the fuel filter and check the fuel pressure
May 25, 2013 | Ford Expedition Cars & Trucks
Ford 1981 f 150 not running changed Coil distributor cap Roar arm plug wires did not help started bur ran extremely rough then died
motors need 3 things to run properly. gas spark and compression. the starting point. also spark timing.
the motor you are dealing with is easy. i just rebult a 1978. anyways sounds like a timing problem . first i would check the distributer. if all is ok spay a squirt of starting fluid in the air filter, or even wd40.,,,,,,,see if it is gasoline problem. isolate where the problem is.
Aug 29, 2017 | Ford Cars & Trucks
I just got a 1994 yz 125 and when i was riding it ,.. it would run good as long as i was going slow and not raping out the gears .. but when i would give it a lot of gas to take off it would bog out and...
if the plug is sooty your float is set wrong the air filter should have oil on it to catch dirt.sounds like a carb problem although it could be the power valve
Aug 24, 2011 | 2003 Yamaha YZ 125
Engine runs rough, burns tons of oil, and keps shutting down
Could be too much oil. Check oil livel and make sure that the oil is not too thin (gasoline in oil). Install new spark plug, add premium fuel in tank and start engine without the air filter (air filter could be dirty or soaked in oil). Run for a while to see if condition improves (no or less smoking). Replace air filter while the engine is running to see if it makes a difference in performance. If installing air filter had no effect, and engine continues to smoke most likely valve guides or rings are faulty. Hopefully it will clear up. Good luck
Nov 07, 2010 | Briggs & Stratton Garden
Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Aug 04, 2009 | Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
447 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
