Question about Toshiba Satelite A135-S2286 Notebook
Satelite L505 powers up then steady beep/won't
3-week old Toshiba Satelite L505 powers up then steady beep/won't boot.
    President:
  • 942 Answers
In term of power up with no display and keeps beeping this is an memory problem. All you need to do is to open the closed cover at the back of your laptop. Note: (if you can see a seal at the back and your unit is under warranty don't open it. Bring that in shop where did you buy). Check the memory stick you can swap it to the other if they have two memory stick. When the problem not fix replace the memory stick. You can disassemble you unit.
Regards
PCmania
Posted on Sep 28, 2009
    President:
  • 1,187 Answers
Remove and re-seat the memory (RAM) modules.
The task is non-destructive / harmless.
To install web cam for my toshiba satelite l505
Connect webcam o computer, Operating system should detect it and load driver, update driver after install. Load disc if camera came with software,
Nov 19, 2012 | Toshiba Satelite 4000CDS Laptop AC Power...
Toshiba Satelite M35X-S111 Beep codes on boot
You need to go into the BIOS (setup) and reset to factory defaults first. This should clear up the issue.
May 28, 2012 | Toshiba Satellite M35X-S161 Notebook
Toshiba satellitep205d-s7438 won't boot up
You need to be more specific and tell what happens when you plug in the power cord and press the power button. There are a number of reason why a computer will not boot, but if you tell what's going on someone can help you.
Computers don't boot for basically the following reasons, 1) the power supply is bad. That means when you plug it in you don't see any lights, and when you press the power button nothing happens, you hear no fans, no beeps, no blinking lights, no hard drive spinning, no cd drive clicking and nothing appears on the lcd screen.
2) A motherboard issue, usually when this happens you will either see blinking lights or hear beeps. Those blinking lights and beeps are codes that tell the technician what is really going on.
3) Static Buildup - try removing the battery and the power cord then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back in (leave the battery out) and Press the Power Button. If it boots up you had static buildup and can replace the battery, count your blessings and Thank The Lord cuz a dishonest repairman would have told you he had to replace the motherboard for $300
Mar 20, 2012 | Toshiba Satellite P205D-S7438 Notebook
Toshiba laptop L505 won't turn on
Remove main battery and turn on, next! check the power supply for correct voltage, if okay! sub the ram out one out a time and power on and repeat. If still no result, the DC jack in the laptop is a common issue, suggest a professional to assess.
Mar 13, 2012 | Toshiba Satellite L500 Series Notebook
Hi I have toshiba A200 satelite laptop, for the past two weeks my system gets restarted often, like when i unplug charger pin, when i boot my system. Is it mobtherboard problem.
More likely a battery problem. When you plug in or unplug the AC, there has to be a current surge from the battery to fill a couple of capacitors. If the battery is low, that will cause a failure and restart. How old is the battery. They never last more than 3 years.
Dec 13, 2010 | Computers & Internet
Dell power edge 2850 make 4 seconds beeps alarm without stopping and without show any error Msg on the screen.
I don't understand the beep code you describe, but the 2850 has many beep codes to help understand what is going on.
First ... Identify the beep. Does the beep start as soon as you power it on, or after several seconds? What is the pattern of the beep - is it a repeating set of beeps - 3 sets of beeps between 1 and 4 beeps ... like 1 beep-3 beeps-2 beeps, or 3 beeps, 3 beeps, 1 beep? Or is it a steady repeating beep - about once per second?
Second ... is the LCD panel on the server blue or orange? If orange, what is the error code(s) it is scrolling?
If it is a steady, once-per-second beep, it is probably your RAID controller. Does the system boot to Windows/OS ok? If so, use (or install) OpenManage Server Administrator (Managed Node from Dell's Support Site) to check the Hardware Logs and check the RAID array (under Storage/Virtual Disks). If it is not booting to the OS, then go into CTRL-M to see what the status of your array is.
Aug 16, 2010 | Dell 3.0 GHz Second Processor for...
My toshiba satelite laptop beeps continuosly, non-stop
First, check the memory (RAM) of your computer. remove and put it back in. Also checkif therre is only one or two memory sticks in, so you can check on both. It should work fine, and if not, try replacing the memory of your laptop.
May 19, 2010 | Computers & Internet
I have bought a Toshiba 'Satelite
It is probably a PDF file, so you must have adobe reader installed.
There may be a icon to do this on the desktop.
if not you can down load one from adobe,com
Mar 07, 2010 | Computers & Internet
Laptop won't boot up. Only 3 beeps.
listen to the beep heres some information on beep code errors
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jan 25, 2009 | Toshiba Satellite X200-AA3 Notebook
Toshiba Satelite A135-S2286 Notebook Logo
433 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
