Question about Razor Pro Model Scooter Red/silver Kids Children
Razor pro scooter has squeaks inside deck below vertical bar
My sons Razor pro scooter has a squeak inside deck below vertical bar. As you move vertical bar back and forward with your foot on the deck it sounds like metal on metal within the deck. I have also sprayed a lubricant but it made no difference. There are allen keys each side which are tight. How do you access inside the deck? There is a plastic cap at the end but I am reluctant to remove it as it may have a one way plastic clip. There appears to be a metal sleeve inside which has screws also. Can you assist with info on access to the deck to resolve issues?
5 Suggested Answers
  • 850 Answers
SOURCE: e-100 razor scooter battery will not take charge
its dead they need to be recharged every time they have been used
Posted on Jul 18, 2009
SOURCE: On an E 100 Razor scooter, the battery charger shows charged
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
Posted on Jul 19, 2009
SOURCE: How can you fix a
Fitted New on and off switch also new reset button. Battery ok but will not start
Posted on Nov 29, 2010
  • 63 Answers
SOURCE: Is there a fuse inside the Razor E300 electric
All electrical product have some kind of fuse or circuit protector. Should be either inline with the battery and be a blade type fuse (trace the wiring), or on the outside of the scooter near where you plug it in and it will be the festoon type. Check the blown fuse for the correct amperage replacement.
Posted on Oct 14, 2011
Why printer squeaks
There are several moving parts inside the printer. more in a color laser printer.
Generally if you have used a refilled toner recently (any color or black), the chances are that the wiper blade in NOT seated properly inside the toner or reversed.
Try the following steps.
1. Set known set of good toner (even if nesrly empty)
2. Perform self test
3. Replace one old toner with new set corresponding color and eliminate which toner causes the squeak..
4. Mark that toner defective and Return.
5. If that is not feasible, try to forcefully rotate the drum in the opposite direction to see if helps flip the rubber blade in place
6. I will not suggest you to open the toner as it can damage the drum, spill toner and lead to you bigger mess.
7. If it is not due to toner, then the culprit is in the several gear trains inside the printer and that can be tricky to solve.
Sep 06, 2016 | HP Color LaserJet Pro 200 M276nw
Vacuum squeaking loudly!!!Help!!!!
Most likely has a bunch of hair wrapped around the beater bar. Get some scissors, razor knife and some needle nose pliers. Turn the bottom up and remove the cover and start digging the hair out. You may need a new drive belt too.
Nov 07, 2015 | Vacuums
2006 hyandai sonata, does it have greese fittings
Often mysterious squeaks are from dry torsion bars bushings. There are two of them mounted to the engine "sub frame." My wife's Ford Focus has this issue as well. It squeaks when driving ove rthe curb onto the driveway. The solution is to unbolt the two hold-down clamps that secure the torsion bar to the subframe then apply soime silicone grease inside the rubber bushing so that the rubber will no longer "grab" when the torsion bar moves.
Mar 03, 2015 | 2006 Hyundai Sonata
Squeaks driving
check the "U" joints for dry and worn. check cv joints as well
Apr 03, 2014 | Dodge Dakota Cars & Trucks
Bed frame squeak
There's a chance that tightening all hardware will eliminate the squeak but you can also rub bar soap on the joint surfaces to quiet things down
Jun 12, 2013 | Baby Gear
My tape deck is making noises while operating.
As in squeaking noises? Or are you getting static and stuff on the audio itself? If it's just squeaking and stuff, then you can open it up and add a little bit of WD40 or silicone spray to the moving parts to loosen them up.
Jun 03, 2010 | Sony TC-WA9EES Dual Cassette Deck Single...
My son rode his E100 scooter through a puddle and didn't tell me until a few days later. The scooter won't turn on now and I've tried to re-charge the battery. Is there anywhere I can send this scooter for...
Your problem could be one of two things. The motor could have short circuit or the components under the deck could have short circuit. The problem is, when your son ran the scooter through the puddle the water acted like a conductor. Connecting the positive and negative poles together until the water dried out(creating a short circuit). I suggest, if you're handy, to take the deck off and check for corrosion both the battery and the controller. If that's not the problem then check the motor (you're probably going to have to take it apart). Just a quick tip, be aware of everything you apart. Where it goes and how fits on there. It will make it a lot easier to put back together. Once you find the problem replace the part either by finding the replacement at or at If you not handy then send the scooter to razor for repair, but it might take a while to get back. Best luck.
Oct 16, 2009 | Razor E100 Electric Scooter
Item dimensions are 25.5′ x 4′ x 7.25′ - Weight 8lbs.
  • Razor Pro Model Scooter has a double stacked head clamp for extra head tube strength and the scooter is made from aircraft grade aluminum.
  • It has a full deck and 98mm urethane wheels equipped with ABEC-5 high speed bearings.
  • Razor Pro Model Scooter folds for easy storage and transport.
  • It can hold riders up to 220lbs.
  • Item dimensions are 25.5′ x 4′ x 7.25′ - Weight 8lbs.
Sep 23, 2009 | Razor Pro Model Kick Scooter Fun Kid...
2007 Subaru Legacy Sedan has terrible trunk lid squeak. How to grease/fix?
does this happen when your driving or just opening and closing the trunk? iwould inspect the torsion bars in either case to see if they are properly positioned,they are locate inside the trunk below the package shelf{where 3rd brake is}move the lid up and down and see if you get any squeaks,please dont try to remove them their dangerous and they support the trunk lid
Jul 07, 2009 | 2007 Subaru Legacy 2.5i SE Sedan
Squeaking noice when temp is below 30 degrees
the squeaking is simply the belt of your car moving. the freezing temps cause that problem thats why it quits when it warms up
Jan 23, 2009 | 2003 Buick Century
Razor Pro Model Scooter Red/silver Kids Children Logo
106 people viewed this question
Top Razor Toys Experts
Clif Roberts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
Are you a Razor Toy Expert? Answer questions, earn points and help others
