Question about Kenmore Dishwashers
Dishwasher will not start on any cycle - Kenmore Dishwashers
  • Kenmore Master
  • 2,605 Answers
Does it display any of the lights ? If it does not, you are likley looking at a open thermal fuse. to access this part follow these steps.
**FIRST shut the breaker off**
there are several types of "kenmore" units. some whirlpool, some frigidaire made. the most common being the whirlpool, so we'll focus on that type.
remove all the torx screws around the door panel, (large metal part)removing the ones holding the larger panel first, not the console/control panel (plastic). once those are out, pull the panel up slightly, and out towards you, that should get that out of your way. next, remove the remaining screws around the console/control (plastic). careful there is a wire harness going to the left of the door for the condensation vent wax motor and one going down to the detergent/rinse aid combi-dispenser. remove those connection's so you don't break the tab, or the wire itself. now you can remove this control panel. you should now see a plastic "cover" on the back of the console. this is held in place by a couple of clips only, locate them (should be fairly obvious) and remove the cover. there it is ! The fuse will look like a small round disc with 2 wires going to it, or it'll look like a tiny "rocket" in a plastic holder. ohm it out, if it's infinite, it's open. if you get continuity, its good. if it's open, replace it with this kit, # 8193762
put everything back together and there you go, easy right ?!!
**Do yourself a favor, install the complete kit with the new wire connectors. Alot of customers, do it yourselfer's and even expert techs replace the fuse only, then return in several months (maybe more or less) only to have the same problem. (whirlpool issued a "kit" for a reason)
hope that helps,
good luck
Posted on Sep 28, 2009
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Samsung DMT300RFW Builtin Dishwasher will not run past wash cycle. I start it and it fills and the wash cycle starts but won't cycle past the wash cycle. No error codes.
What do you mean, it won't "run past the wash cycle"? Do you mean it stays in the wash cycle forever? Or do you mean it quits in the wash cycle and doesn't rinse or dry?
Oct 18, 2014 | Samsung DMT300RFW Builtin Dishwasher
Why does by dishwasher not cycle through
The timer controls the electro-mechanical components in the dishwasher such as the wash pump, drain pump, inlet water valve and heating element. The timer also advances the control knob on the control panel. Replace the timer if it fails to start and stop the components properly or fails to advance the control knob. Dishwasher Won
Oct 26, 2017 | Frigidaire Dishwashers
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
My Bosch dishwasher fills with water but when it comes to the wash cycle it does nothing.
If your dishwasher is brand new, then call Bosch service as they can repair it under warranty.
Feb 26, 2012 | Bosch Dishwashers
My kenmore dishwasher wont start at all now. It used to start if you pushed certain buttons a bunch of times but now the lights next to most of the buttons light up but it wont start a cycle. any ideas?
Hello
Ensure that the dishwasher is connected to a working power supply. Check the local fuse or circuit breaker and restart as necessary.
Open and shut the door firmly until it latches into place. The dishwasher will not function if the door is not latched into position.
Select the desired cycle and press the cycle button firmly, as you must choose a cycle in order for the dishwasher to begin operation.
Look at the water valve that is connected to the dishwasher and ensure it is turned on.
Turn off the dishwasher and unplug it from the power supply to reset the unit. Plug it back in and select a new cycle. Select "Start." If the dishwasher still does not start, contact an authorized service technician.
Sep 11, 2011 | Kenmore Dishwashers
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
Dishwasher won't go through it's cycles.
Remove the bottom panel and check the float switch, it is probably stuck in the up position.
Dec 04, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Whirlpool Dishwasher Fills and then Stops
  Check your connection where you connected dishwasher to power cord.
Oct 25, 2007 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwashers Logo
175 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
