Question about HP Pavilion dv6000z Notebook
Startup When ever I start my pavilion dv6000 it shows me that the file ssvichoss.exe could not be found. I ignore then continue work normally.
  • 84 Answers
I think is more an virus there cause i did not find any file of that on my comp but i know that svchost is an process used by more of the viruses
check it with norton
Posted on Jan 04, 2008
  • 39 Answers
If you are working normally..
Click start>run type msconfig
Go to the startup tab
Find this applicacation in the list. Remove the click in the checkbox, restart your computer..
Bye bye message =)
Posted on Dec 18, 2007
My webcam 1.3mp hp pavilion dv6000 is not working,i need your help to install now!
Installation Instructions (HP 1.3 MegaPixel (MP) Webcam )1. Download the SoftPaq .EXE file to a directory on your hard drive.(ftp://ftp.hp.com/pub/softpaq/sp35001-35500/sp35414.exe )
2. Execute the downloaded file and follow the on-screen instructions.
Jan 06, 2011 | Computers & Internet
Hi. There are many problems with my dell inspiron 1545. I'm using windows vista home basic. First after every startup it shows the properties of a file named "vsbntlo" and it also shows that this file has...
You probably have a computer-virus.
Backup your data/music files to an external device (USB memory-stick or external disk-drive).
Reinstall Windows.
Repeatedly, run Windows Update to update it.
Install anti-virus software: http://www.microsoft.com/security_essentials
Reload your data files.
Aug 09, 2010 | Computers & Internet
Process smartmenu.exe has a volume bar that
first of all u have to remove it from ur startup menu then search any service which support this process and remove it from ur startup Services.
procedure:
window+R
type msconfig and press OK
do above procedure
Aug 03, 2009 | HP Pavilion dv7-1240us Notebook
I cant find the switch to turn on my wireless capability on my HP paviliondv71137
it should just automatically find a wireless signal. go into your network file and look around to see what it says. mine just found a signal didn't have to do anything. click on start menu you'll see network click there.
Jun 10, 2009 | Computers & Internet
Desktop hijacked at the time of starting
Do this in order...its worked for others that had similar messages on Startup...as long as your operating system is legit. Any time you deal with this type of work on the computer...know what your doing...altering your registry can have dire effects.
1. C:WindowsDownloaded Program Files
  • Within that folder, remove any files or folders associated with .WGA
2. Safe Mode
  • Reboot your computer and as soon as Windows logs off, start repeatedly tapping the F8 Key on your keyboard.
  • As soon as you see the Windows Advanced Startup options select Safe Mode within Safe Mode get yourself into these folders…
  • C:WindowsSystem32 (Rename wgatray.exe to wgatrayold.exe)
  • C:WindowsSystem32dllcache (Rename wgatray.exe to wgatrayold.exe)
    Note: Dllcache is a hidden folder, to view hidden folders do the following, go to Start, Control Panel, Folder Options,
    Select the view Tab and under the Hidden Files option, select Show hidden files and folders
3. Safe Mode Registry
  • Click on Start, Run and within the open dialog box type regedit and click OK.
  • Within the Registry Editor navigate your self to
    HKEY_Local_MachineSoftwareMicrosoftWindowsNTCurrentVersionWinlogonNotifyWGALOGON
  • Right Click and Export the WGALOGON Folder (this should be saved onto your machine for backup purposes)
  • After Exporting the folder, DELETE the WGALOGON folder
  • After deleting close all applications and Restart your machine back to Normal Mode
4. www.microsoft.com/genuine
  • Get into the site above and manually re-validate your copy of Windows.
  • After being prompt of a successful validation, Restart your Machine
May 03, 2009 | Intel Computers & Internet
Laptop hp dv6000 will not recognize cd burner/dvd player
HP Pavilion dv6000 laptop PC
Did you 'turn off' the AUTOPLAY feature of the CD\DVD ? When the player "runs two times at startup", it is trying to find the program on the disc.2nd- Look in internet for HP dv6000 cd\dvd drive replacement.(If that is the ""exact match for the product"" you wrote about)
3rd.goto CONTROL PANEL>SYSTEM>HARDWARE>DEVICE MANAGER and look up cd\dvd and uninstall it. REBOOT, when your system comes back it will try to find the cd\dvd. If it does not, it is damaged (kaput!), must be replaced. If Windows finds the cd\dvd drive and reinstalls the drivers, but it does not work, then the heads are dirty or damaged.That Windows found the dvd\cd means that the circuit on the device works.
Mar 16, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion laptop restarts during welcome screen
Do the power drain
step1. Remove battery and ac adapter
step2. Hold on to power switch for 30secs-1mint
step3. Put back the battery and ac adapter
step4. Start the laptop as usual
IT SUD BOOT PERFECTLY
after doing this also if the symptoms are same
i apologise to tell u ...its gonna be Motherboard probs which is common nowadays in Most of the HP LAPTOP
Feb 21, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000
video driver maby what about redoing windows formatt it all
Jan 18, 2008 | HP Pavilion dv9000z Notebook
Message displayed at startup of pc
This is a trojan that has been removed, but the startup file is still in the registry, click start, run, then type msconfig, on the start up tab in the next window look for explorasi.exe and untick it.
restert the pc, select don't show aghain when the window pops up and it shouldnt show any longer
Oct 19, 2007 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
79 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
