Question about HP Media Center PC 873n (P9875A#ABA) PC Desktop
Cpu fan error, but spins
Cpu fan error, cpu shuts down in five seconds, but fan spins. I installed two new fans.
  • 138 Answers
Hi,, there may be an problem faulty in motherboard,, or processor,,,
Posted on Sep 28, 2009
Compaq laptop powers up for thirty seconds then shuts off
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Aug 13, 2012 | Compaq Computers & Internet
Asus u52 shut down unexpectedly
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jun 17, 2012 | ASUS U52F-BBL9 Laptop
Asus p6t se
harry up change cpu fan or" pemanent damage your cpu if fan is off.
May 30, 2012 | ASUS P6T SE - Motherboard - ATX - iX58 -...
Every time there is a problem of overheating error and my system shuts down .when i restart my computer cpu produce beeps . motherboard is of Intel 915 series is used.......
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is the problemis not fixed then the CPU will eventually fail.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Sep 09, 2011 | Intel D915GLVG Motherboard
Samsung r40 shuts down after running for about 20 mins, was told cooling fan was not working so stripped down laptop cleaned fan (was full of dust) reasemmbled and ran all day yesterday, switched on this...
The CPU fan may be faulty and not spinning freely.
If you had removed the heatsink off the CPU did you place new thermal grease/paste on the CPU before installing the heatsink back on the CPU?
Jun 02, 2011 | Samsung R40-K009 R40-K00A R40-K00D"...
Error on normal boot up, System Fan has stopped, system will shut down in 5 seconds. Boot to BIOS: CPU Fan Speed 1700+rpm System Fan Speed 0RPM (in red) of course CPU Temp 45c/113f I opened the case,...
HI ker7758 ,
You may need to apply "Thermal paste/grease " to the CPU.
You can watch this video tutorial from Youtube:
http://www.youtube.com/watch?v=o7rPqCvCt0g
There are different types of thermal grease. You don't have to buy the expensive ones. The cheapest on the market should be able to do the job.
Apr 09, 2011 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
Cpu high temperature, cpu shutting down
The CPU is shutting down because it is overheating (ie thermal shutdown) and won't boot up again until it has cooled down. If this problem is not fixed, eventually the CPU will fail completely.
Check the CPU fan to see if it spins freely. Also check the power supply fan to see if it spins freely. If the CPU fan has failed, then replace the CPU fan. The CPU fan and heat-sink assembly may be clogged with dust, if so loosen the dust and vacuum to remove the dust.
May 11, 2010 | ASUS P5L-MX Motherboard
Cpu fan problem
If you plugged the replacement fan into the power supply instead of the "male plug on the mother board" you will get that error message. You need to find a fan that has the female plug for the mother board. It solved my problem.
Paul C.
Apr 22, 2010 | Nuvico NVDV3-16000N
Compaq presario cpu cooling fan will not start spinning unless "helped" with tip of pen to spin over.If I dont start it manually,I get No cpu fan message,and shut down.I just replaced fan,as old had broken...
If the CPU fan speed is too slow or not working at all, the computer will shut itself off automatically to prevent damage to CPU from overheating. You may end up having to throw more money at the problem and get a new fan. I went to Compaq's web site, looked up your particualr computer, found out what type of fan you needed, and I did some research. I recommend getting the fan in the following link. It's very cheap, and has good reviews. The other fans on the site all have bad reviews. Hope this helps.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835114011
Jan 12, 2010 | Compaq Presario Cooling Fan CPU Heatsink &...
Computer keeps shutting down.
Do the fan's spin when you power the PC on? All of the fans should spin up for at least a second upon initial boot. The CPU fan and video fan (if you have an external card) will spin the entire time the PC is on and vary in speed depending on temperature.
Try booting the PC with the side of the case off and note and fans that aren't spinning. The temperature to shut off the CPU is really high. If the temperature is getting hot enough to do this, you should notice a failure in a fan right away.
Mar 09, 2009 | Computers & Internet
HP Media Center PC 873n (P9875A#ABA) PC Desktop Logo
178 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
