Question about Panasonic Video Cameras
Panasonic Mini digital video camera PV DV901D is not recognized by Windows MovieMaker, although it has been in the past. Firewire cable is good, I tested the cable on another camera on another computer with success. No luck with the Panasonic. Is there a setting on the camera I'm missing?
  • 473 Answers
SOURCE: HELP ME FIGURE OUT HOW TO DOWNLOAD VIDEO TO MAC...
I use a DV camera that is not on Apple's "compatibility" list. (It should REALLY be noted that Apple sells camcorders in it's on-line store that aren't listed as compatible!) Depending on which software package you are using, including version, results may vary. I too had a fairly confusing frustration the first time out, but here's Jeffe's notes: FireWire! (USB is not for video). Start with iMovie: (FinalCut is higher-end, and thus is more picky about what it will take.) launch the application, then plug in the powered-on camera set to it's "play" (VCR etc.) setting (as opposed to camera setting.) If iMovie STILL does not see the camera, then I'd start to worry about compatibility, and contact an Apple SPECIFIC retailer (not a chain, like CompUSA etc.) for help. BTW: Nice Camera! Let me know if it works out. I was contemplating Panasonic for my next camera.
Posted on Sep 06, 2005
SOURCE: need to connect my panasonic pv-gs80 to my imac
Best buy has brand new ones, or you could surf the web and find a cheaper one at like amazon. Just make sure that the size of the cable matches up with the size of your computer or else it will not be able to plug in.
The problem I have is like the other people, I got the firewire in the port and DV on the camera and my computer just doesn't recongnize it. Where's the solution to this? I have been trying to edit my film for over a year now with troubles with losing wires and now this and stuff. Hope this helps
Posted on Jan 13, 2009
SOURCE: No 1384 firewire driver for Panasonic PV-GS300 camcorder
I found the recipe. To get my DV Camcorder to work using 1384 (Firewire) on my computer I did:
1. Get a good cable. If you paid less than $20 for it, you got the wrong one.
2. Ensure that the 1384 (firewire) port is enabled on your computer. Go into the BIOS setup and check to be sure. Mine was OFF!
3. If you get an error with Windows XP not being able to find your hardware, you need to get all the drivers. There are four or five of them along with a configuration file. Miss any one and you are dead. My solution was to reinstall Windows Service Pack 3. This took a long time, but fixed the driver problems.
Posted on Feb 21, 2009
renx
  • 71 Answers
SOURCE: firewire
Okay then let's start with that. Download the drivers from:
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders/MiniDV-Camcorders/Drivers-Downloads/model.PV-GS39.D#ts
Install the drivers and you should be good to go! Let me know if you're having any problems after that.
Posted on May 08, 2009
  • 497 Answers
SOURCE: Sony DCR-HC52E connected with Firewire not detected in moviemaker
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Posted on Sep 15, 2009
PV-GS9
Possible dirt and dust in preforation on camera for mic or bad cable. i suspect the cable first since it is doing it with two different cameras.
Dec 10, 2013 | Panasonic PV-GS29 Mini DV Digital...
I can not get my iMac, running on OS x 10.8.5 to recognize my Panasonic PV-GS85 camcorder. Tried installing converters but they can't detect a camcorder either. ANy solutions? Any help would be highly...
You will need to capture using a firewire cable.
If you are using a firewire cable and it does not work try another brand of cable as some have a reputation for not handling DV capture.
Al
Oct 18, 2013 | Panasonic PV-GS85 Mini DV Digital...
My computer no longer recognizes my Panasonic mini-DV recorder. I am using USB 2.0, but the device manager does not even recognize the camera. I have even tried multiple USB ports, all to no success. I...
Vista may not support it but you can try some things.
oYou may need to simply and very carefully delete all usb devices from device manager and restart so they are reseen and re-installed.
usb devices in devices mgr link
Google
I would take the time to look at some of these help articles to determine how you wish to proceed:
more at this link
Google
this is a differentr camera but may also give some leads to discovering the issue:
Connecting Sony Handycam to Windows Vista Via USB
Google
Mar 25, 2017 | Panasonic PV-GS35 Mini DV Digital...
My Vista OS laptap won't recognize my Panasonic PV-GS33 camcorder. Is there a driver I could download?
If you connect with a firewire cable and open Windows Movie Maker it should work without downloading new drivers.
Apr 15, 2011 | Panasonic PV-GS33 Mini DV Digital...
I have a Panasonic PV-GS39 and want to put my movies onto computer that's running on windows 7. Using the USB cable doesn't work. Will the firewire cable really work or am I just out of luck? Thanks for...
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The way it works on my computer, the camera is controlled by the computer software.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Whether this will work with Windows 7, I am not sure. My Mini-DV camera, using a Firewire cable, didn't need any camera driver loaded to the computer, just the movie editor that came with Windows XP.
Dec 07, 2010 | Panasonic PV-GS39 Mini DV Digital...
How do it ransfer video from my pv-gs9 to my computer xp. i have a new firewire to usb cable but my computer won't recognize it.
I don't understand the "firewire to USB cable" reference. You can't just connect these two incompatible interfaces together with a cable. There is some kind of conversion device available to allow a Firewire connection to be made to a USB port, but the chatter on the forums says that it doesn't work with video cameras.
Some mini-DV cameras have a USB port, but only use it for stills and can only download video by Firewire. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
You don't say if you have the manual available for reference. If not, you can download a copy from THIS LINK
Nov 17, 2010 | Panasonic Palmcorder PV-GS9 Mini DV...
My windows 7 laptop does not recognize my Panasonic Mini DV Camcorder PV-GS39 and therefore cannot capture video any ideas?
You are going to have to check that your firewire is being seen by windows 7 first of all. If not you will need to rectify that.
When you do get it to recognize it, here is a link for an update to the program that came with your camcorder for it to work with Windows Vista but it should also work for Windows 7.
Hope this helps,
Mar 24, 2010 | Panasonic PV-GS39 Mini DV Digital...
Can i use 4 pins usb cable in Panasonic PV-GS80 MIni Digital Video Camera if not then suggest how many pins of usb cable it required.Waiting for your reply
use only K1HA05CD0014 usb cable provided by company.its use for image downloading (it have5pin at mini usb) use firewire for video capturing (it have 4pin)
Jun 08, 2009 | Panasonic PV-GS80 Mini DV Digital...
Camcoder problem
The USB port on the camera is to download still pics from the Camera's SD Card to your computer. USB connector is not for video downloading.
For video downloading you have to use FireWire port. Your computer must have a FireWire port too. You will need some sort of video downloading software - like Microsoft's MovieMaker. There are some free software to download videos from mini dv camcorders to computer. It takes 1Hr to download 1Hr tape - you have to play it all to record it all. You will need video editing software to do different editing if you want. Otherwise, MovieMaker can make a good avi file. You can upload that to YouTube.
3yrs ago when I purchased this cam, I did not have FireWire port in my computer. I searched online a lot and found a way to download video using USB - it was tough, complicated. It was possible, but quality was too bad and too many dropped frames.
If you do not have firewire port, google for FireWire PCI Card, should be <$10. You have to install it inside your PC. Also search for FireWire cable ($10+/-) that will match BOTH camera and PC ports.
Thank you.
Aug 18, 2008 | Panasonic PV-GS19 Mini DV Digital...
Panadonoc pv-gs19 camcorder
Thank you.
Jun 15, 2008 | Panasonic PV-GS19 Mini DV Digital...
Video Cameras Logo
155 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
