Question about Magic Chef (CSD2610KRW) Top Freezer Refrigerator
Ice Maker Problems
I have a Magic Chef refrigerator model # CTB1925DRW. Purchased ice maker IMBD03-004, did not work. Returned it, got another one. Still doesn't work. Am I using the wrong model of ice maker? I used a cheater chord to check the water inlet valve, it works fine. It is not getting energized by the ice maker though. The colors on the wires for the freezer ice maker connector are different from the connector on the ice maker side. The grounds don't even end up matching up which is why I'm thinking the "universal" ice maker I purchased really isn't universal. Any recommendation?
  • destry_l Sep 29, 2009
    Thank you aasc. I have indeed received a shock from the cabinet a time or two. Can you tell me what ice maker I should buy for my refrigerator model (# CTB1925DRW)?
  • Mike Smith
    Mike Smith May 11, 2010
    You are correct on the green grounds . They have to match up , or , you'll be getting a short , and possibly a slight shock , when touching the cabinet . Universal is not good . You need to get the Ice maker designed for your brand and model .
Krazytech
  • 725 Answers
SOURCE: water squirting from ice maker
Does it do it all the time or only when the ice maker call for water... you may have a bad water valve 67006531 VALVE, DUAL WATER or a ice dam in you icemaker let me know
Posted on Aug 25, 2007
  • 100 Answers
SOURCE: magic chef refrigerator relay/overload
You need at least two terminals on your relay to hook up a capacitor, one wire of the capacitor goes on one terminal of the relay and the other capacitor wire would get spliced in with the neutral line that plugs into the relay
Posted on Dec 05, 2007
SOURCE: Magic Chef Side by Side MOdel RC224RDA
I have the same problem. It turned out to be a problem with the doors. When my kids go to get a snack and close the fridge door (read slam the door) the air pressure pops the seal open on the freezer door causing the ice cubes to begin melting. The bottom items stay frozen (warm air rises). It took me a long time to work this out.
Remove the ice maker tray. Remove the ice blob, being careful to put the u-shaped wire ice-level sensing wire thing, in the up position or the system will dump ice and water all over the freezer. Put all back clean and dry and buy a velcro adhesive strip and install it on top of the freezer door to prevent the door from always blowing open.
Hope this helps
Posted on Nov 21, 2008
  • 3 Answers
SOURCE: magic chef side by side heating instead of cooling :-(
Gee, I hope you didn't throw this one away. The cooling settings between the two sides are out of balance, or something is blocking the airflow between the freezer and the refrigerator. Make sure the ducts that blow air are not blocked, set both sides on a medium setting, and give it some time (12-24 hours) to equilibrate. Also make sure the fans are running and the coils are free of dust. I have to clear the coils of my current refrigerator once a week from accumulated cat toys. Generally the cat alerts me long before the fridge does.
Posted on Jun 26, 2009
aasc
  • 1606 Answers
SOURCE: I have Magic chef Model
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Lightly hook the other end over the glass rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Posted on Sep 27, 2010
Magic chef refrigerator will not defrost and ice maker will not work
verify that the doors are closing properly. If they are not you will have to manually defrost it to get it running right again. I doors are ok, think about finding a control board
Dec 03, 2016 | Magic Chef Refrigerators
Magic Chef RB15FA0AA Refrigerator I have this refrigerator and it still works fine. I would like to know it's total cu ft capacity. Also what the refrigerator and freezer each cu ft capacity is.
After some work online...I found this advertisement buried among a bunch of other ads:
Magic Chef RB15-1A: Top-freezer style with 14.6 cubic ft. capacity and optional ice maker -- $439.
So, as I suspected the "15" in the model number is the cubic feet (total I would say). The 14.5 is probably actual, with the unit "rated" as a 15 CF.
Naturally, to find the cu. ft of the freezer, measure in inches then multiply the width X height X depth and divide that resulting rather large number by 1728 to get your cubic feet of the freezer.
You could also do the same with the refrigerated section, and add the results together and they should be near 14.5 total.
Aug 03, 2015 | Magic Chef Refrigerators
IC MAKER WORKS BUT NO WATER OUT OF WATER DISPENSER?
There are two sides to the Dual Water Control Valve. The ice maker side is still working but the water dispenser side is possibly defective. Sea Breeze Model Number?
Magic Chef Refrigerator Parts
Dec 15, 2013 | Magic Chef Refrigerators
The icemaker wont produce ice like it was when we first moved in
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 22, 2010 | Magic Chef CTB1821AR Top Freezer...
Ice maker does not work
magic chef mini fridge stops colding
mod#MCBR171W 1.7cu ft
Jun 30, 2010 | Whirlpool 17.6 cu. ft. Top-Freezer...
Magic Chef refrigerator model CTF1923. erratic ice production
As long as your freezer temperature is at 0 you should have steady ice production. If you have to jumper the ice maker to get it to harvest then you most likely have a bad thermostat. That coupled with the leak issue really warrants just replacing the entire ice maker.
Be sure to ask for pricing on both the ice maker by itself as well as the complete kit. You may be surprised to find that the entire kit (including a new valve, line and bucket) will cost lest than just the ice maker by itself.
Jun 13, 2010 | Refrigerators
Ice maker odor along with ice cubes smell
Try replaceing the water filter first thing you can get at most appliance parts store or sears or any appliance store. Thish should fix your problem.
Feb 05, 2010 | Magic Chef CTB1722 Top Freezer...
Need instruction or manual for the Magic chef ice maker model
Hope this helps. This is the link where you may be able to download
http://www.partselect.ca/Search-Suggestions.aspx?term=MCIM30TW
Nov 22, 2009 | Magic Ice Cream Makers
Magimix Ice cream maker - Le Glacier - lost instruction book
Magimix 2200 Gelato Chef 1.03 Quart Ice Cream Maker Support Magimix 2200 Gelato Chef 1.03 Quart Ice Cream Maker Support. Manual for ice cream maker ... Need Instructions/User Manual. Magic chef ice maker model MCIM30TW ... fixya.com/support/p519941-magimix_2200_gelato_chef_1_03_quart_ice/rss
best regards mike
Aug 17, 2009 | Magimix 2200 Gelato Chef 1.03 Quart Ice...
Magic Chef (CSD2610KRW) Top Freezer Refrigerator Logo
454 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
