Question about Compaq Armada M700 Notebook
I have a compaq armada but dont know the power on password how can i fix
  • TechMunki May 11, 2010
    On some models of laptops, you can short a few pins on the motherboard or remove the CMOS battery, but this isn't the case for all models and manufacturers. Some laptops may require that you send it back to either the manufacturer or take it to an authorized service center for unlock, motherboard replacement or BIOS EPROM replacement. What model of Compaq do you have? The full model number should be listed on the underside of the unit.
  • 403 Answers
Try this remove the main battery and mains power supply, hit the power switch to drain any retained charge. then remove the cmos battery. The cmos battery is on the right under the panel at the top of the keyboard, which can be popped out by gently levering it up at the edges. the key board can then be folded clear, watch for the ribbon cable under it that connects to the motherboard.no other way i know of. You might want to check this location first get to the cmos battery via the removable panel on the bottom right front of the case (other side from the battery). first remove the main battery. next remove the panel, under it you will see a modem card, remove the modem card and you should see the cmos battery to the right side its loke a big watch battery. there will be a connector on the wires going to the battery. remove this to disconnect it. now just push the start button with the machine un plugged, just to discharge any residual power. wait a couple of minutes then reconnect the cmos battery then the modem card, then the main battery. plug it in and start it up. the screen will come up with something like "cmos bad checksum, defaults loaded" do not worry this is normal. if it doesn't start normally, switch it off by holding the on button down until it goes off then restart. it should be fine after that, password gone. you can then get into your bios and set it up to your liking. I recommend not putting in a password. Let me know if this works for you.
JimmyC
Posted on Sep 28, 2009
Hi can you help me restore my compaq armada e500 to factory settings as i have forgotten password on main screen. i dont have a disc or that.
If you mean BIOS password, then you can do the following:
- plug out AC,
- take out the battery,
- press down Fn and hold it pressed,
- plug in AC,
- continuously tap on F11
this should lead to cycling LEDs on and off.
If so, let the sysetem boot. You should then receive the POST-msg "options not set".
If it is a Windows password, you can follow the instructions here
Hope this helps
Lucas
Jul 07, 2011 | Compaq Armada E500 Notebook
I dont know the Administaror password for my Armada 1700
Download PCLoginNow, burn image to a disk on a different computer. Then run it on your laptop
http://sourceforge.net/projects/pcloginnow/reviews/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 10, 2010 | Compaq Armada 1700 Notebook
Power on password is unknown
If you can get the cover off your notebook safetly,take out the cmos battery and put it back in,then power up your notebook...that may work:)
Apr 12, 2010 | Compaq Armada 1571DM Notebook
My laptop compaq armada1700 ask me power-on password what can i do?
Follow the instructions of the service manual for the Armada 1700 (you need to have some skills):
2.2 Clearing Passwords
The power-on password prevents use of the computer until the password is entered. The setup password prevents unauthorized changes to Computer Setup. To clear the passwords, you must remove all power from the system board. If you do not know the passwords, use the following procedure to clear the password:
1. Remove all battery packs from the battery bay and MultiBay, if applicable.
2. Disconnect the AC power.
3. Remove the real-time clock battery.
4. Wait five minutes.
5. Reconnect the AC power.
6. Restart the computer. During Power-On Self Test (POST, a "162 System Options not set" message appears.
7. Shut down the computer, then disconnect AC power again.
8. Replace the real-time clock battery.
9. Install the battery pack(s).
10.Proceed with the troubleshooting procedures.
Point 10 means you need to do the setup via disquette to set the date and time again, to avoid the "162 system option not set" message of the POST.
Lucas from Argentina
Mar 22, 2009 | Compaq Armada 1700 Notebook
Administrators password dont have
Download the Ophcrack LiveCD, burn it to a CD, boot the laptop off it and it will crack the password for you.
http://ophcrack.sourceforge.net/
Feb 08, 2009 | Compaq Armada E500 Notebook
I have a Compaq Armada 1592 DMT laptop I cannot get past the user/password log in screen?
Ok the first step to try is logging into administrator most people never set a password on this account. if this does not work there is free software to remove passwords just let know and I can get the name of what I has used before.
Jan 15, 2009 | Compaq Armada 1592DMT Notebook
I have a Compaq armada m700 and i dont know the power up password i put it in without realizing it
I'm copying someone else's answer; I can't vouch for it.
emove the main battery and mains power supply, hit the power switch to drain any retained charge. then remove the cmos battery and short out the contacts. the cmos battery is on the right under the panel at the top of the keyboard, which can be popped out by gently levering it up at the edges. the key board can then be folded clear, watch for the ribbon cable under it that connects to the motherboard.
Dec 14, 2008 | Compaq Armada M700 Notebook
Power-on
Computer BIOS information and help The BIOS also includes a test referred to as a POST (Power On Self Test) which will ensure that the ... CH000235, How to clear an unknown BIOS password.
Click on the above Link, Follow instructions.
Good Luck, Please dont for get to Vote.Thank You.
Dec 16, 2007 | Compaq Armada E500 Notebook
Compaq armada 4131T
hi,i presume that u cannot punch in the password as the keyboard is not working, except the Enter key, u can do two things, reset the bios, or repair the keyboard, by removing it and cleaning the contacts, to reset the BIOS, locate the small lethium battery, remove it and keep it outside for some time, then put it back,that will reset the BIOS.. try either of it.. let me know...
Dec 04, 2007 | Compaq Armada 4131T Notebook
How do I get past this Drivelock HDDBay password
mabey reformat hard drive using the windows xp disk then reinstall operating system
Oct 28, 2007 | Compaq Armada E500 Notebook
Compaq Armada M700 Notebook Logo
61 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
