Question about Dishwashers
Whirlpool Quiet Partner II Model DU1148- The clean
The clean light is flashing and I can not reset the dishwasher.
4 Suggested Answers
SOURCE: whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Posted on Dec 29, 2009
  • 126 Answers
SOURCE: Whirlpool dishwasher Quiet Partner II:
shut down the circuit breaker that controls the dishwasher for 20 - 30 minutes then turn it back on.
Posted on Dec 29, 2008
jsrock516
  • 5911 Answers
SOURCE: clean light is flashing
This can be a common issue with some Whirlpool manufactured dishwashers. This information may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Posted on Nov 02, 2009
Testimonial: "Worked perfectly! Thank you."
Whirlpool quiet partner ii clean light flashing 7 times. I installed a new heating element and reset the code, and it still flashes 7 times
Check the main control for the heater relay, this may be faulty and the cause of your issue. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Mar 30, 2016 | Whirlpool Dishwashers
Lock light stays on my whirlpool quiet partner II
If pushing and holding the lock button till the light goes out doesn't work, you likely have a problem on the circuit board.
May 24, 2014 | Dishwashers
I have a whirlpool quiet partner II dishwasher model # DU1055XTVB5 and the normal light is steady flashing I have did the sequence to reset HEATED DRY NORMAL HEATED DRY NORMAL and the normal light...
Angelia:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address, Whirlpool_Reviews@Whirlpool.com, with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Whirlpool® Social Media Relations
Mar 06, 2018 | Whirlpool 24 in. DU1055XTP Built-in...
Dishwasher takes 3 hours to wash, even on the light cycle
whirlpool Quiet partner 3 the clean light is flashing 7 times what does this mean
Mar 12, 2010 | Whirlpool Dishwashers
Whirlpool Quiet Partner V light flashing
most of the time this meens your heat element is burnt out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Feb 25, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool quiet partner III. Clean light keeps flashing clean.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Whirlpool dishwasher Quiet Partner II: Can you help me reset the "blinking clean light" indicator? Yes or no.
Dec 29, 2008 | Dishwashers
Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner 980
Bad control board ,replace it.
May 26, 2008 | Dishwashers
Dishwashers Logo
202 people viewed this question
Top Dishwashers Experts
