Question about Saeco Royal Professional Espresso Machine
Keep reading "ventilate" on the screen
It will not do anything it just reads ventilate. I had this problem before so i took it apart and cleaned it all out and then it was fine. A few months on the same has happend and the same procedure as befor is not working , it will also not seem, to produce any steam from the milk steamer ...? Please Help
  • 6 more comments
  • need coffee Dec 19, 2007
    Well first it said the dredge drawer was full but it wasn't. So we took it out and put it back a couple of times. Then it said ventilate and we can't figure out how to do that.
  • 32Magic Dec 24, 2007
    Only used machine a few times and can't get rid of the "Ventilate" on the display and the machine is disabled.
  • Anonymous Dec 24, 2007
    ventilate lite is on.nothing else works
  • gucu007 Feb 25, 2008
    Yes, I have the same problem. When I turn the machine on it shows "ventilate" on the screen and you can't do anything with the it.
    I tried to clean the hot water valve but didn't solve the problem.
    What is the next step??? Tx Mike
  • CUPPACRAZY Mar 02, 2008
    I have a royal cappuccino and has ventilate on screen. I used the hot water button and has hot water coming out of steamer nozzle but not milk frother.
    Ventilate is still displayed after doing this, WHAT DO I DO TO FIX... PLEASE HELP
  • Anonymous Mar 07, 2008
    I get venitlate and decalcify
  • OZ Wine Guy Apr 25, 2008
    Can't get Ventilate to go off screen, machine wont work, lost the manual.
  • lowlenzo Jun 02, 2008
    ventilate is on and nothing else works. Pls assist
  • 3 Answers
Running hot water button a few times worked for us
Posted on May 26, 2008
  • Darren Jones Aug 20, 2011
    !00% middle CPU board problem. Cause most likely by the main boiler leaking water on the board , You will be up for a boiler and CPU board to fix this common issue. Regards
I ran the hot water for about 1 minute and VENTILATE went away. phew! I need my espresso!
Posted on Apr 24, 2009
  • Saeco Expert
  • 223 Answers
Can you run hot water through the machine by using the hot water button on the front?
If not, then this is your issue. To remove the ventilate message you must be able to run hot water through the machine through the hot water valve. On the royal professional, due to lack of maintanence or due to not using the hot water valve at all it jams (scaling buildup) and you can do nothing about it. You can try to descale, however, 99% of the time we have to take them apart and clean the valve by hand.
Saeco Parts and Service
Posted on Dec 19, 2007
My Royal professional will not let me run the hot water in order to fix the "ventilate" problem
Posted on Oct 20, 2009
Running water thru the machine using the hot water button worked for us!
Posted on May 15, 2008
Correct answer, fixed OK. But have always descaled the machine and use filtered water.
Posted on Jan 01, 2008
Question for Solis Master 5000 Digital. After being professionally repaired, it has worked fine for about 2 months, and then suddenly stopped brewing coffee. I cleaned it.Then I decalcified it using it's...
I am not familiar with the digital model. But it sounds like something didn't get put back together properly. The top mesh is very tricky and easy to strip if you took it apart to clean. I had a problem with mine and now just leave it on and wipe it off in place. If its not tight water will just bypass the coffee grounds. Sorry, I couldn't be more help
Jul 09, 2014 | Solis Master 5000 Espresso Machine
No water comes out on ventilate. At first, the water was coming out very slowly, in drips. The doser or grind were not the problem, because even when I switched to Hot Water, it was still dripping. ...
It should take about 45 minutes to an hour to properly descale the machine. If it only took a couple of minutes you really didn't descale your machine. If you used the powder it has to disolve completly before descaling. The best way to descale is with the descaler in the tank. Turn on the machine and run about 8 ozs of water-descaler through the wand and then turn off the machine. Wait 10 minutes and repeatthe last procedure. Do this until the tank is empty. When done with the descaler, rinse out the tank and put fresh water in the tank and run the whole tank through the wand. Then fill the tank and your ready to go.
Nov 13, 2010 | Gaggia Syncrony Compact Coffee...
I fixed my Xbox 360, then it broke again.
What you could try is remove your hard drive and see if you can play a game without it, if this works reattatch the hard drive and see how you get on, you would be suprised how many times this works.
hope this helps.
Jan 12, 2010 | Microsoft Xbox 360 Console
Xbox 360 open tray prolem, for only 1 game, which works fine on--
well creamy peanut butter will clean it good or tooth paiste it may help
Mar 11, 2009 | Microsoft Xbox 360 Console
My xbox wont read my game disc
if you can't send the xbox back to Microsoft this worked for me.
The 360 would spin the game up and say reading but than stop and do nothing.
I took the case apart, took out the cd drive, took that apart so i could get to the laser.
put a little big of very clean water on a q-tip, wipe the laser lens down and use the dry side to dry it off.  put it somewhat back together and test, this worked fine for me, it read a disk no problem.
Feb 21, 2009 | Microsoft Xbox 360 Console
My xbox 360 keeps on restarting on its own
about the only thing I can recomend is make sure all connections are tight inside,because the most common thing to cause random resets is if a cable is loose,and the vibration causes it to make intermittent connection,shorting out and resetting.
Feb 19, 2009 | Microsoft Xbox 360 Console
Canon MP110
Problem seems to have been solved.I took the printer apart and assembled it again and it seems to have done the trick coz it's working fine now.Just need to give the print head a good clean.
Oct 12, 2008 | Canon PIXMA MP130 All-In-One InkJet...
you didnt use the machine for a long time start the machine remove the water container if you have a turker blaster fill with water the hole were the water container goes put the blaster in it and apply pressure and try to ventilate and for descaling the machine use descaler not vinergar. vinegar remove calcium in little piece descaler melt it use 1 part descaling produit 1 part water put that in water container start machine open valve turn it off after a few second let it rest for 15 minute and repeat untill empty do 2 or 3 rinse cycle with clean water it important that stuff is corosif thanks for using fixya pierre
Feb 10, 2008 | Saeco Vienna Espresso Machine
Saeco Magic comfort
turn the hot water / steam knob on to 'ventilate' the pressure from the machine. The ventilate /overtemperature message will disappear when ready (few seconds usually)
Oct 26, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Royal Professional Espresso Machine Logo
5,424 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
