Question about Samsung LN40B530 40 in. LCD HDTV
Problem with Samsung tv and home theater
I bought a Samsung 40" LCD TV(LN40B530) the samsung 5.1 (HT-TZ322T) home theater system, and sometimes when watching movies (through the upscaling dvd player in the home theater) the screen will go black for a second and it will come back and show the information in the top cornor (resolution, refresh rate).
Another problem im having is that the subwoofer seems to be popping. I dont believe i've cracked it or anything because I havn't had it too too loud yet (havn't gotten louder then 30/50) . This is the first home theater i've set up, so im not to sure what to check to see if its connected right.
  • 4234 Answers
SOURCE: Samsung ht-tx72 Issue
GEnerally speaking that behavior suggests that the video signal is being lost for a second and returns. The easiest thing to try is to replace the connection cable (video). A bad connection there could cause this although moving the cable should make this happen at will. Check the DVd player on another TV if possible. If hte player is the cause, the "new" TV should show the same symptoms.
The only other possibility is that the DVD player is having a problem generating the video signal. This could be because the disc is not being read correctly (I would expect the sound to be effected as well) or the video processing section of hte DVD player is defective. This wil be a bit more difficult to find.
Can you try the cable and other TV and update this?
Thanks,
Dan
Posted on Jul 28, 2008
SOURCE: Gurus, I just bought Samsung Home Theater System which i connected to my Hitachi TV with HDMI cable. I have a Optical Cable going from HT to my TV Optical port. I have another connection from my cable
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
Posted on Jun 03, 2009
SOURCE: v ipod mode in Samsung HT-Z420 home theater system not working
Plug a yellow video cable into the TV (IN) and the Sound system (Out) then go onto AV1 on the TV or which ever port you plugged the cable into and play a movie and u can see it. A menu doesnt come up like the A ipod funtion so it comes up no signal until u play an actual movie on the ipod. If u dont have a yellow video cable i think u can use the white or red audio ones.
Posted on Aug 20, 2009
  • 33 Answers
SOURCE: Connecting HT/Cable box to TV?
Get a fiber optic (Toslink Optical) cable to plug into the TV's optical OUT between the red/white RCA audio and the spot where you plug in your cable TV, to the Optical IN on your HT-DS610. This way all audio coming in to your TV from any source goes directly to your hi-fi in all it's splendor.
Have fun!
Posted on Aug 28, 2009
How to connect a Panasonic SA PT950 home theater syst. to a Samsung flat TV UN65JU650D?
Samsung 40'' 720p tv and Panasonic home theatre system ...
? 5:30
https://www.youtube.com/watch?v=zDG-PZtqCNE
Jan 4, 2012 - Uploaded by Nazil Rahman
Samsung 40'' 720p tv and Panasonic home theatre system ...How to Connect an HDTV to Your Sound ...
New way to connect TV to Surround sound using HDMI ARC ...
? 4:46
https://www.youtube.com/watch?v=fFNEKnlQd6I
Dec 13, 2013 - Uploaded by Tampatec
How to Connect TV to Surround sound receiver system setupusing HDMI ... to Samsung, LG, Sony, Vizio ...
Unable to connect Samsung smart TV with Panasonic home ...
www.tomsguide.com/.../unable-connect-samsung-smart-panasonic-home...
Dec 16, 2014 - hi I bought Panasonic SC-BTT405 blue ray disk 5.1 home theater and ... Unable to connect Samsung smart TV with Panasonic home theater ... I have an LG55LA9650 smart TV hooked up to a Bose 3-2-1 home theater system.
Jan 23, 2016 | Samsung Audio Players & Recorders
I have a new samsung 40" led tv and i have
The specs say that it has an optical audio in on your home theater system. So the easiest way to hook up is to connect the optical audio out of your tv to the optical audio in of your home theater system and walla! What ever play on the tv will play on the home-theater system. You are looking for a Toslink optical audio cable
http://cgi.ebay.com/6-OPTICAL-FIBER-OPTIC-TOSLINK-DIGITAL-AUDIO-CABLE-6-FT-/370402436177
Jul 14, 2011 | Samsung UE40B7020 40 in. LED TV
Need Vizio TV code for my Samsung HT-X50 home theater remote!
Mine is 5. Press the TV button and let it go. When it quits glowing press the power button and hold it down. Then press a number (1-86) on the keypad while holding the power button down. If the TV turns off, you are done. Press the power button again and the tv should come on. If it does not work. Release the power button for a second and then repeat with a different number until the tv turns off.
Jul 05, 2009 | Samsung HT-Z310T Theater System
No sound thru surround sound system in TV Mode
You need to connect your TV to the AUX connection in the back of your HT system. Then set your HT system on AUX 1 and wait about 5 seconds for the TV sound to come through. If it does not work on AUX 1, you may have to try on AUX 2 or AUX 3 settings on your HT system. Make sure the A/V cable you use is good and in working order and is a good quality cable.
Hope that helps, Gary
Jan 30, 2009 | Samsung HTZ-510 Theater System
Can't get the Samsung HT-z310 Home Theater to stay on AUX2
you need a fibre optical cable for this, simply you connect that from your dvd to tv and then set the input on the dvd to digi in. i have exactly same home cinema system.
Nov 27, 2008 | Samsung HT-Z310T Theater System
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
HDMI conection
Hi.
Connect the Home cinema and the TV with the HDMI cable. When you turn it on, first turn on the TV and then the home cinema. I hope this works.
Oct 07, 2007 | Samsung HT-HDP40 - 800 Watts 5 Disc HDMI...
Samsung LN40B530 40 in. LCD HDTV Logo
729 people viewed this question
Jerry Greenberg
Jerry Greenberg
