Question about Samsung Propel A767 Cell Phone
My background picture slides down and most my screen is white and blank, how do i fix this? I've tried taking the battery and sim out but this doesnt help at all.
SOURCE: i was taking a picture on my phone and the screen went white
I had the same problem, but ive just turned it on and of and it goes away.
Posted on Sep 20, 2007
  • 5 Answers
SOURCE: dispaly loosing its original colurs when i slide it up
chang the striPer or dislay
Posted on Jun 08, 2009
SOURCE: Samsung g600,dropped,buttons,sound not working and screen blanks
Hi, I have a Samsung G600 Service Manual PDF if you want it, and it will tell you all the disassembly and reassembly instructions!
Let me know Harvie
Posted on Aug 19, 2009
  • 171 Answers
SOURCE: so my main screen is
You must replace the phone flexible band
Posted on Feb 11, 2011
mmnhltm
  • 695 Answers
SOURCE: my phone screen is white
Your mobile needs repair
The problem in the CABLE wich is connect the HARDWARE BOARD with the SLIDE
it needs to be changed with a new one
Posted on May 13, 2011
Lap top screen only shows background picture
Does the mouse work? I would Cold-stat the machine: 1) remove AC plug from outlet, 2) remove battery, 3) hold down on/off button for 10 seconds, 4) replace battery, 5) plug into wall outlet 6) push on/off button.let me know if there is any change, if not you can try another procedure.
Nov 01, 2012 | Compaq Computers & Internet
I have an HP compaq presario cq71-230sa. Laptop worked fine a few hours before, and then when I lifted the lid, the screen was black with 2 lines of white dots running down the left hand side, and the...
Can you check the function buttons and make sure the primary display is set to show the output on the laptop. Try repairing your OS. If not then re-install the os. As you are saying till the time windows gets loaded, all works fine so it seems the issue isn't really the hardware.
Jul 18, 2011 | Compaq Presario 700 470024-192 Notebook
My screen on my lg phone stopped working and only turned white but then goes back off and then doesnt work what should i do?
When a phone screen is blank, has a white screen, etc, there are three things that could be the cause;
  1. Bad/defective screen and the solution is screen replacement
  2. Software/Virus problem and solution is to flash the phone
  3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
I hope this helps.
Good luck.
Apr 23, 2011 | Cell Phones
My background (a picture of a small town in Italy) has almost dissapeared . A large white screen covers 3/4's of the screen . I can't make it go away. Please help an 80 yr old fix this problem easily. I...
Generally, you right click on a blank spot on your desk top; personalize, and reset your picture to stretch, or tile or as you have it center.
Another choice is download Picasa from Google. It is a great picture catalogue program that allows you to choose your desktop background.
Sep 11, 2010 | Computers & Internet
Getting a blank white screen on Sony Ericsson F305...It was working fine two days ago and just last night and this morning I'm getting a blank white screen. I'm unable to access anything and even turning...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck
Jun 29, 2010 | Sony Ericsson F305 White +512MB Unlocked...
White screen on my samsung rant
There is a fix. Ok so what you wanna do is power off your Samsung rant then you take out the battery and put it back in. After that you open to the slide pad and hold down the T and Y keys then power it on while still holding the 2 keys after the Samsung logo pops up then you can let go. Keep the slide keys open while it is powering on. You can close the slide pad when your screen shows up then it should be fixed. Well hope this works for you it worked for my moms phone when she was having this problem. Note: If your phone screen freezes or turns white again just redo the process.
Jun 03, 2009 | Samsung Rant Cell Phone
Blank white screen
Two things might be going on .
First you could have a bad ccd sensor or the LCD is defective
Apr 10, 2009 | Nikon COOLPIX S200 Digital Camera
Pantech matrix has white screen
Many users of the Pantech phones have been experiencing the same thing. There are a lot of default in this phone. I would suggest you to return it to Pantech and try to get a software upgrade. Although, I would recommend you NOT to use it. Even if the Pantech exchange it for a new one, the same problem will happened in a day or two.
Jan 25, 2009 | Pantech Matrix Cell Phone
Blackberry Pearl 8100c Screen blank out
i want to change the network code of blackberry peral 8100
how i can unloack the phone
IMEI = 355767018968151
Dec 22, 2008 | RIM BlackBerry Pearl 8100
My sony ericsson w600i just went blank
i have white screen in W600i model please solve this problem
Sep 10, 2008 | Sony Ericsson W600i Cellular Phone
Samsung Propel A767 Cell Phone Logo
19 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
