Question about Plumbing
Re: soap dispenser of my K-R10430 Kohler 4-hole faucet. The small spout has started coming out of the body of the dispenser when dispensing detergent. Installation and homeowners guide don't show whether there should be a gasket to keep the spout in or not. The dispenser has periodically leaked even before the spout started coming out. How can I repair or replace dispenser?
  • 129 Answers
I'm not sure if it can be repaired or not, but lowes carries the same dispenser that came with faucet. To replace unscrew bottle from under counter now you remove plastic nut that holds the body to counter and install new one.
Posted on Sep 28, 2009
Kohler soap dispenser leaks onto counter
Your dispenser nut is either not tightened down underneath or your plastic base/o-ring needs to be replaced. Turn off water at value. Using sink nut removal & installation tool that is available at any Lowe's or Home Depot. Remove it and look at what is wrong. Conntact Kohler for free parts to repair it. Reinstall dispenser .
Mar 01, 2014 | Kohler Home
Soap no longer dispenses automatically.
Mine would not work with the Costco brand (Kirkland) batteries. The light indicator came on but the pump did not work. Once I replaced them with Durcell, the pump started working. I'm guessing Energizer brand would work just as good.
Nov 22, 2013 | Umbra Otto Automatic Soap Dispenser,...
I've taken the spout off and can see the diverter but I can't get it out of there. How do you get it out?
I have a K-R10430. I was having issues with the hand spray - poor water pressure. Kholer sent out a new diverter. After shutting off watner, when you remove the small screw in the back of the Spout, pull the spout off. Put a paper towel into the body to soak up excess water inside body. Then you need a small screw driver or small flat item to fit inside one side of the retaining ring near the opening, there is a space where you can fit something behind and carefully move the retaining ring out. Pull out with needle nose pliers then pull the diverter out with needle nose pliers. Insert new diverter with teeth facing up and push down. Insert retaining ring and make sure it slips into same **** in wall of body.
Jul 11, 2010 | Kohler Model 10430: Fort® Single-control...
Soap not dispensing from pump
Try pumping it and covering the hole with your finger until pressure builds. This usually works. Soap is heavier than water and it takes a little longer to move up.
Jul 03, 2009 | Price Pfister Marielle Kitchen Faucet with...
The spout on built-in chrome sink soap dispenser fell out
The only good solution here is to purchase a new pump.. Sorry
Kurt
Mar 21, 2009 | Home
It seems that the plastic pump mechanism is not
Unfortunately it is a very common problem with soap dispensers. First before you replace the dispenser, dillute a small amount of water mix with the soap in the bottle of the dispenser to see in fact if the pump is deffective. It could simply be that the soap is too thick for the pump to work properly. As to replace it, call the manufacture of the faucet which I presume came with the dispenser and very often they will stand by their products and send you one free of charge.
Feb 20, 2009 | Price Pfister Marielle Kitchen Faucet with...
Kwc kitchen soap dispenser wont work
Sorry but you need new one, the cheapest I have found is KWC America 504 938 000 Primo Lotion Soap Dispenser on amazon. I hope this was helpful, cheers
Feb 16, 2009 | Delta RP1001-BL Classic Kitchen...
Unable to pull spout to replace O'Ring in Kohler Faucet F10416
They just pull out, sometimes things get stuck and I cant get them lose as a plumber and you just have to buy a new one...dont feel bad
Jan 31, 2009 | Kohler K-10416-BN Fort½ Single Control...
Kohler 5988 Sink leaks from soap dispenser spout (?) when dishwasher is running
Hi.. Its a breather or "vent "and its clogged. Remove the drain tube under the sink that runs from the vent to the connection on the drain( under sink). Clean vent and replace. Please send me some Positive feedback if I've help. Thankyou!
Jan 21, 2009 | Kohler K-5988-2-7 Entree Self-Rimming...
Plumbing Logo
244 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
