Question about CD Players
CD player skipping
The right side CD player is skipping and stuttering with a number of different CD's indicating it must the CD deck and not the cd's. I find this tends to happen after about 20 minutes of operation and it is only the right hand side deck.
  • 93 Answers
SOURCE: cd player skipping
Try to clean it manualy. Remove cover, use dilute alcohol and cotton, be careful and DO NOT PRESS TOO HARD, be very gentle. Good luck.
Posted on Oct 08, 2007
SOURCE: numark cdn95 left player skip even with new cds
CDN95 uses the same CD transport as a CDX, aka....junk. Its mostly likely defective, replace left CD drive.
Posted on Oct 17, 2008
  • 35 Answers
SOURCE: my cd player skips
Unplug the unit, remove the cover and clean the laser lens glass with a Q-tip. Spray a bit of window cleaner on one end of the Q-tip (over a sink), then use that end to clean the objective lens of the laser. Then dry it with the other end. Wipe Carefully!
Do not apply pressure while cleaning, wipe slowly and then reassemble the unit and test. This is a common problem on many laser-based products, dust and smog get inside the unit and cloud the lens, causing it to skip or not read at all.
Posted on Mar 02, 2009
SOURCE: The drawers on the left side that hold 5 cds will
Most likely you need a belt kit and cleaning.
Posted on Feb 25, 2010
SOURCE: Denon DNS1000 distorted/fuzzy sound
im having the same problem too, right in the middle of a tune, was playing fine, then all of a sudden a distorted sound increased the volume. now i have this fuzzy sound over the music when it plays
iv looked on the denon forum, but cant find a suitable solution for my problem
Posted on Apr 09, 2010
  • 15 Answers
SOURCE: Skipping cd deck 2 on numark cd mix 1 player.
You're best bet is to replace the stock rubber feet with a true vibration absorbing rubber pad. Audiofiles like myself have discovered that Sorbothane rubber is the best for this application. There is no other material that can even come close to matching it's performance. Get yourself a set of their Sorbothane rubber hemispheres, probably something about a 1" diameter would work best. The best place to get them is
1.25" Sorbothane Rubber Hemispheres
Posted on May 01, 2010
0 characters
1 Points
Skipping and stuttering problem on my CD Player
You most likely need a new reader. If you are handy at all you can get a replacement online and do it yourself.
Dec 24, 2014 | CD Players
How do I get my Sony RCD-W1 to record from one CD to another
using the dubbing button on your recorder will recorder from your cd player on the right side of the deck to the cdr recorder on your left side..the left side of the deck is the cd recorder...hope it helps...just place a cd disc on the right side and a blank cd on the left side push dubbing button and wait till the left side reads the song on the recorder cd on the right
Dec 09, 2012 | Sony RCD-W1 2-Disc CD Recorder
Cd skips alot
Check the laser pickup unit for dudty. Clean it. If this does not help you replace it.
Mar 07, 2012 | Philips GEMINI Professional 2U Dual CD...
My tascam cd-1500 dj left side only display good day while the right side is fine
how can i b deck going on my tascam x1700 from gd day when i got deck a working i cant remmber what i pressed can any one help
Aug 25, 2011 | Tascam Cdx1500 Dual CD Player CD Player
3 disc Phillips cd player sometimes skips. It is
At some time in its life, the laser that reads the CD starts to get too weak to operate reliably. That's probably what's happening here. Unlike mechanical parts that can be inspected for wear, electronic parts tend to work fine one day, then the next, poof. The laser assembly is replaceable if you can locate the part and find someone to install it. An electronic service shop could give an estimate for repair. If you can provide the full model number, I'll see if I can find the part number.
Mar 08, 2010 | Teac AD-600 3-Disc CD Changer
Have a Denon DCD-520 and it skips forward and back while playing
Hopefully, it may just need cleaning and lube.
I have a Denon DCM-460 purchased from Goodwill a couple days ago and had problem with one CD-R skipping and stuttering toward the end.
Cleaned the CD which helped a little but still started skipping and stuttering.
Noticed a scratch toward the outer end which I suspect is where the problems occurred.
Anyway, last night I cleaned laser, rails, lubed spindles and moving parts. I used 99.9% alcohol to clean. I used a light teflon oil (Tri-Flow) to lube spindles and rails. And white electronic grease where you see remnants of white grease.
Today, I now played through the problem CD-R with no problems.
Assuming placement is level and stable, certainly worth a try and the effort.
Feb 01, 2009 | CD Players
Numark CD MIX2 right deck skipping, sounding scratchy
Did you by any chance buy it from a b stock retailer?...send it back...also reduce your burn speed when recording cds
Aug 04, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Music CDs skipping while playing
yes..if CD cleaner not sucess, you can open the DVD..if you have been done and not working, maybe the optical has been weak..
sorry for my bad english..^_^v
Aug 09, 2007 | Panasonic SCAK410 5-Disc CD Changer
CD Players Logo
52 people viewed this question
Top CD Players Experts
Dave Jukebox
Are you a CD Player Expert? Answer questions, earn points and help others
