Question about Garmin StreetPilot i3 GPS Receiver
Garmin streetpilot i3 wont power on
Hasn't been used for months, has no updates, won't power on, either vier cigarette lighter or new batteries, any clues
  • goobaa Dec 20, 2007
    cheese for that, still wont power up
Hi, Thank you for the tips, I had done step one, I saw the message that reads ""DO YOU REALLY WANT TO ERASE ALL USER DATA". However, I couldn't select yes, when my finger still needed to hold on the power button to let it turn on, I used the wheel to move up YES but I couldn't. I tried to let go the buttons and turned the wheel quickly but that wouldn't work b/c the GPS turned off right away. Please help! I love my Garmin and just owned it not long ago
Thank you
~Christy
Posted on Dec 31, 2007
WARNING: You will lose all user data when you do a master reset.
To erase all user data on the device, please follow these steps:
  1. With the unit turned off press and hold the thumb wheel down, then press the back arrow and hold down, then press the power button.
  2. When all 3 are held down a message will appear that reads "DO YOU REALLY WANT TO ERASE ALL USER DATA". Select "Yes".
  3. Let go of the buttons and go through the reset sequence. The unit will need to sit outside to acquire satellites.
Posted on Dec 20, 2007
'93 Jeep won't start - used cigarette lighter for gps instead of power socket
Sounds like a bit of a stretch... (nah).
"Lighter" is a GREAT OUTLET...
Has been for decades.
Perhaps it is just time to consider some BATTERY MAINTENANCE... cable and terminal cleaning
or even A REPLACEMENT battery.
I ASSURE you a cigar/cigarette lighter ELEMENT
pulls a lot more power than your Garmin Nuvi 1450LMT.
Get your JEEP battery checked...!!
Carnac the Magnificent
Jan 07, 2018 | Garmin Nuvi 1450LMT
Seems to be dead .wont turn on when plugged into the cigarette lighter Garmin street pilot c 510
Before writing the unit off as dead I would try obtaining a new 12v power cable and maybe try your cable in someone else vehicle, often the 12v power in your car can short not providing power to the GPS.
Hope this helps!
Apr 13, 2011 | Garmin StreetPilot c510 Deluxe GPS...
Battery on my garmin c510 sat nan wount hold a charge how easy is it to change
Had the same problem. Fixed with a new battery. Takes the same as a Streetpilot c530 and can be purchased anywhere on line. A 10 minute job with a soldering iron.
1. Open face plate. Unscrew 4 screws. Remove battery connector and clip.
2. Unsolder the wires to the two speakers - 4 wires.
3. Remove the sticky wrap from the old battery and place around the new one (to stop it rattling).
4. Solder back the new speaker wires.
5. Plug in battery, reassemble unit and charge Garmin off PC wih usb cable.
Done!
Sep 15, 2009 | Garmin StreetPilot C330 GPS Receiver
I have a Garmin Streetpilot c330 with a car charger but it doesnt charge the battery for some reason so now my system is dead, is there anyway to fix this problem?
Check the fuse in both the cigarette lighter socket on the car and the cigarette lighter adapter on your power cord, the tip should twist off and this should expose a fuse.
Hope this is of some help.
Ed
May 05, 2009 | Garmin StreetPilot C330 GPS Receiver
WILL NOT CHARGE SAID BATTERY LOW AND WILL NOT CHARGE
I used another charger in house and charged battery must be the car charger adapter I haven't used it yet but I will today and let you know if it works
Jul 24, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin Streetpilot i3 GPS cannot load map to memory card
Sounds like your battery died and there's no juice to it. When the battery is low, the unit shuts itself off and has a hard time starting up. If possible, try plugging in your unit with a USB cable from the computer and leave the computer on for a few hours and see if that doesn't solve the problem. When in the car, sometimes the cigarette lighter socket comes loose.
Regarding your i3, the USB drivers must be loaded BEFORE you connect your garmin. If you do not have your USB drivers, you can download them from:
http://www8.garmin.com/support/collection.jsp?product=010-00434-00
Also, why would you need to upload maps? The i3 comes pre-loaded.
Jul 13, 2008 | Garmin StreetPilot C330 GPS Receiver
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Batter low message when plug into lighter holder
Sound as though the I3 is not getting power from the lighter. Hook the garmin to your laptop and turn on the laptop, now turn on the I3, does it still shows low battery message on the screen? If the answer is yes then the USB connector has failed (know problem with the I3). There are many unit sold on ebay with broken USB connector. If the I3 doesn't show Battery Low then the lighter cable is defective.
Dec 18, 2007 | Garmin StreetPilot i3 GPS Receiver
Garmin street pilot 330
Take the navigator 2 a repair center, because somethin that new, shouldn't happened unless it hasn't been charged for awhle after being in the box on the shelf
Oct 14, 2007 | Garmin StreetPilot i3 GPS Receiver
Garmin StreetPilot i3 GPS Receiver Logo
105 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
