Question about Briggs & Stratton Garden
I have rjdeing lawnmower with a BRIGGS&STRATTON 13.5 OHL WHEN YOU PUT IT IN GEAR AND ENGAGE THE BLADE IT LOSES POWER WQNT RUN. FAMLEY 4BSXS.3442VM 275943
Craftsman mower 19.5 HP model # 917.270822 won't run when clutch is disengaged and blades engaged, will continue to run when I get off the seat all switches replaced excempt seat switch.
Posted on Nov 10, 2011
    Scholar:
  • 138 Answers
If you mean that when you let off the clutch pedal and/or engage the blades, the engine dies, lift the seat and make sure the connector is firmly plugged into the switch attached to the seat.
Posted on Sep 28, 2009
How do I remove the blade and the sprocket piece that holds the blade on?
looks like it might have a pin thru the shaft then use a gear puller.lots of penetrating oil too
May 08, 2015 | Briggs & Stratton Briggs Stratton...
How to change blade boss on briggs &stratton sp 470
Unscrew the central bolt (9/16") - remove blade and any washers etc. It's a conventional right hand thread (anti-clockwise to remove), but may well be extremely tight. If necessary, grind the head of the bolt off and replace it.
The blade boss slides off the shaft - in theory. In practice, you will probably have to use a puller bearing on the blade bolt to pull it off. Remove the drive belt first!
Sep 21, 2014 | Briggs & Stratton Briggs Stratton...
How do I sharpen a lawnmower blade
You have to take the blade off of the mower by taking the center bolt out and if there are other bolts beside the center bolt they also have to come out.
I use a bench grinder to sharpen all of mine and when you put it back on make sure you put it on the right way. Not upside down.Making sure the center bolt is tight but don't strip it. You have to hold the blade when taking it off and if it's too tight I put a block or vice grips on the blade and body so it don't slip.
Jul 09, 2014 | Briggs & Stratton Briggs Stratton...
Remove blade hub
Put bolt in crank and use puller or pull on hub while hitting bolt with hammer Use heat if avaiable. Thank you for using fixya.
Jun 22, 2013 | Briggs & Stratton Briggs Stratton...
Bolens riding lawnmower st100 pto won't engage?
check for power to the clutch if yes the clutch could be bad or a wire going to it if no power check the safety switches
May 17, 2012 | Briggs & Stratton Garden
Lawnmower blade hit a stump now can't pull starter cord
sheared timing flywheel key replace it check to see if crankshft bent if throw it away or replace motor
Apr 01, 2012 | Briggs & Stratton Briggs Stratton...
Does briggs&Stratton have shaft extensions to lower my blade 1in. or 2
are you sure you have the blade on the right way or the right blade for the mower?
Does the nuts on the blade go on the top or the bottom to protect them thanks mark.
I assume you have a blade mount that uses two bolts to connect the blade to the shaft.
Put the nuts on the top....facing the deck. If you put them down.....facing the grass they wear off quickly (after about 40 hours of mowing)
When they wear off they get rounded and you will have to use a locking pliers (visegrips) to get them off.
Jan 13, 2011 | Briggs & Stratton Briggs Stratton...
My briggs & Stratton star but they don not
Remove the brass bolt holding the carburetor bowl on and clean it real well. It has some very small holes in it that carry gas up to the carb and may be partially or completely clogged, causing your problem. All holes must be clear.
May 28, 2010 | Briggs & Stratton Briggs Stratton...
5hp Briggs & Stratton lawnmower starts but stop running?
Try cleaning the air filter, and check fuel tank for any debris.
Replace fuel filter if there is, and give the fueltank a good cleanout.
Use fresh fuel to refill.
May 17, 2009 | Craftsman 16" High Garden Tractor Snow and...
Garden Logo
586 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
