Question about Frigidaire Washing Machines
After washing and rinsing it wont't proceed to spin
    President:
  • 1,197 Answers
Please provide us the make and model number of the unit so that we are able to help you better
regards
Ps: and also if its a top load or front loadr
Posted on Sep 28, 2009
Any suggestions to washing machine which works with irregular water supply?
all models have a water level sensor in them that you set according to the wash load you have
when you turn them on the water flows until the level set switches off the inlet tap and proceeds to wash
regardless of the water pressures and delivery, the wash will not proceed until the water level setting is reached
the problem that you face is that during the rinse cycle , there may not be enough water available to rinse within the rinse/ spin cycle
Aug 14, 2016 | Indesit Washing Machines
Why is the machine Not rinsing and spinning?
something is blocking it from draining so it wont spin and it wont rinse because it wont spin
Jun 10, 2014 | Brandt WFH1176 Front Load Washer
No rinse or spin cycle but washes
Could be something as simple as the solenoid fill valves for the water if you using a different temp for rinse from the wash cycle (warm wash cold rinse) in that case the cold side of the valve could have failed, in which case you'd be getting hot water for the wash and no water for the rinse and, without the fill, the cycle won't proceed from that point.
Mar 09, 2014 | Haier Washing Machines
Machine will rinse but wont always spin
Possible that the program controller is not proceeding sequentially to the program cycle and so there is a missed spin at some point.
Check the connections from the program controller, before it can be suspected.
Jan 22, 2013 | Whirlpool Estate TAWS750PQ 27-Inch Washer
I have a whirlpool Model RAS7233KQ0 and it wont spin automatically
Possible that the timer module is faulty and there is no switching when the cycle proceeds to the spin mode.
Please check the timer module for any loose connection or dry joints on the module.
Jan 15, 2013 | Whirlpool Washing Machines
Hi, i start my machine and it will wash until it reads 31 on the led screen then it wont do anything else it just sits there and reads wash never rinse or spin, the lid stays locked. fav6800aww
I feel your Upper One-Way bearing is seized. Google this Neptune TL Spinning Issue Will Not Proceed
It was very very difficult for me to pull info from this owner near the end of the post is the fix.
If you want to DIY the fix I will help at that forum.
Aug 24, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a Frigidaire front load washer and used dishwashing soap accidentally. now it wont spin in the final spin leaving the clothes soaking wet
Hello, Welcome to FixYa.
Based on your post I understand you have a problem with a Frigidaire washer that has had the wrong "soap" placed in it.
If you can remove the lower panel on the front you should inspect and insure the shock absorbers are still intact and not broken before proceeding. This is what you'll be looking for...(yours may in fact be plastic cylinder type shocks, that's the older version)
If they are not broken then it should be safe to proceed. Here's what I'd suggest (see below).
Let me know how that works for you and we can move forward from there if this doesn't resolve the problem.
When oversudsing has occurred, have the washer cleaned out by running it without clothing using a hot water wash (with cold water rinse) & ½ gallon of white vinegar. If problem persist after, run a cold water rinse using 1 gallon of white vinegar.
Regards,
Macmarkus :)
May 11, 2011 | Frigidaire Washing Machines
Washer will wash and rinse but will not drain or spin.
More than likely your pump or controller or sensor to do with your pump has failed, or even a section of the micro,has gone kaput.. perhaps the pump is blocked? usually though it is a job for the serviceman. Always ask for a firm "Quote" before proceeding with any work.
Jan 30, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Whirlpool washing machine stuck on rinse cycle. Might have had to much in the machine and now will not proceed with rinse.
If it will not pump the water out and spin, it could be the lid switch. If that is not it, then it is probably the timer. Advance it to the spin cycle and try it.
Jan 03, 2010 | Washing Machines
Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Aug 12, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
