My Samsung XO5 laptop wont boot---I get message "operating system not found". However I have discovered that removing the hard drive and just rubbing it and the ribbon cable often cures the problem----but it will surface again virtually every other day. My hard drive is new and replaced a three year old one which manifested the exact same fault----so it cannot be a hard drive problem. Can anyone help? This recurring fault is driving me up the walls.
John
Every time I have had this problem, it was either the drive or the drive being reconogized in the BIOS, or a glitch in the operating system. I would go into Setup at the boot up and see if the BIOS is reconogizing the drive. If it does, then I would use the operating system installation CD but not do a install but use the repair feature. In the repair function run "chkdsk /r" many time this will cure a problem. BPCS
Hi, If that doesn't work you could try replacing the connection cable that connects the hard drive to the motherboard. As this happened on both hard drives its either the software on the hard drives (as BPCS suggests) or the connection cables.
Hope this helps,
Owain.
Was this helpful?
Yes
No
Solution #3
posted on Mar 31, 2008
Guest
Rank: Apprentice
Expert
Rating: 0%, 0 votes
I have the exact same problem with my samsung xo5.. Havent found anything that works so far except turning off and on with the power button a few times, eventually it gets over it and boots up. Although now my ac adapter has given up so i cant boot the damn thing even if i wanted to!!
why my cd rom cannot read the disk. it not detect to my CD ROM or else? it was happen last year, but...
(More)
why my cd rom cannot read the disk. it not detect to my CD ROM or else? it was happen last year, but i already delete the "upper and lower..." in regedit. but it happen again and it cannot do in regedit.any solution? i use windows vista
I have a dell 630 laptop. when I turn it on the screen lites up lightly but nothing shows up. Every...
(More)
I have a dell 630 laptop. when I turn it on the screen lites up lightly but nothing shows up. Every once in awhile it will turn on but not long the screen goes blank again.. help me please
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
