Hp printer 3500 series home pc . paper wont feed .please advice
    Scholar:
  • 96 Answers
Check you tray settings for the correct paper size. check your feed rollers.
Posted on Sep 28, 2009
We have an HP color laserjet 3500 printer; we want to print 4x6 paper; how do we do this?
You will need to feed the paper through the manual tray and you will need to set the paper size in the driver for 4X6.
Apr 27, 2011 | HP Color LaserJet 3500 Printer
Hp psc 1100/1200 series All-in-ONE INK JET PRINTER PAPER WONT FEED INTO PRINTER
Try cleaning rollers and everything you can get to on paper path. Use hand wipes, or baby wipes, etc
It sounds like the path needs cleaning.
Jan 04, 2011 | HP inkjet 2280 Printer
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
Error message 41.5
Basically this error 41.5 occurs due to media feed error reason Paper reached a sensor too early. In order to resolve the issue please go through the below mentioned link, scroll down and look for 41.5 MEDIA FEED ERROR on that page:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl06726
Feb 22, 2010 | HP Color LaserJet 3500 Printer
13.01.00 paper jam tray 2
The pickup rollers are worn out. Replace them and your problem will be gone. While you are sourcing them, use some alcohol. This may give them a little more life.
Jul 23, 2009 | HP Color LaserJet 3500 Printer
I put paper in the printer, but it will not recognize that there is actually paper in the Machine.
The paper feed sensor is malfunctioning.. I would suggest cleaning if that doesn ot work..and it still does not feed you will need a new sensor.. Rate me by advice only Thanks
May 20, 2009 | HP Photosmart 7450 InkJet Printer
Hp 1350 all-in one psc
your paper feed problem may be due to the feed rollers or due to the fact the mecanism that raise the paper doesn't function properly. Normally if you clean the rollers that should work
Jan 25, 2009 | HP PSC 1350 All-In-One Thermal Printer
Paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavypaper) and place it in the feed way. Then press the printbutton applying a slight amount of pressure on the Card Stock so itwill feed through the printer. The reason for this, is in some cases Ihave been able to clear the paper track of debris that was deposited thereover time.
Worth a try, as I have fixed a number of printers thisway, saving costly repairs.
Hope this helps. Bud
Jan 09, 2009 | HP Photosmart C7280 Laser Printer
HP LaserJet 1200 series
Hi vgde2004: Here are some things to check.
1. The printer is in manual feed mode.
Possible solution: Change the manual feed setting in "printer properties"
2. The door is open,the media is out,the toner cartridge is installed incorrectly,or the paper is jammed. Check paper path.
3.Fan error
Solution:
1. Check fan cables for looseness.
2. Replace fan assembly
Dec 15, 2008 | HP Color LaserJet 3500 Printer
85 people viewed this question
jasbo
jasbo
