Question about Hoover Dryers
Mesh filter needs replacing
Hoover Dryer 5050 ED
Seeking closest location to Box Hill, Melbourne where I can purchase a new mesh filter for the door / exhaust.
John Rashleigh
jfr@navyhealth.com.au
(03) 9896 9350
  • 8,197 Answers
You can get the lint filter here. If not listed you will need to call them and they will get for you.
http://www.alliedappliance.com.au/scripts/part_search.php?view=m14&cat=Clothes Dryers>Lint Filters
Good luck
Posted on Sep 28, 2009
Filter position
the wire mesh should be closest to the engine. it keeps the filter material from being drawn into the carburetor.
Feb 09, 2014 | 2007 Bajaj Pulsar 150 DTSi
Ac unit does not have anything to hold filter in place
Assuming you are talking about a residence unit, the filter is supposed to have a wire mesh on one side. This mesh is to prevent paper-alike filter getting sucked in. Filters have arrow-marks for air-flow, double check that.
Sep 29, 2012 | Heating & Cooling
Filter mesh holder is damaged, locking holes are broken will not lock in place - need new filter mesh
Hi Joe: The model has been discontinued and difficult to find replacement parts. I located a few online suppliers offering a HEPA Filter that fits the BUC11700UC. See here:
http://www.vacuumcleaners.net/bosch-buz200hcuc-hepa-filter-for-bagless-jet-upright.html or
http://www.allergybegone.com/boshepfilfor4.html or
http://www.wikio.com/product/vacuum-parts-accessories-compatible_with_bosch-reviews-12020-page3-sort0.html
Is this the part you are looking for? The third site above does offer other replacement parts if you are looking for a different filter piece.
Thank you for using Fixya!
Jan 14, 2012 | Bosch BUC11700UC Cyclone Jet Bagless...
Change the oil
1.prepare materials needed such as:
  • An allen wrench or screwdriver (for fairing removal, if necessary.)
  • An oil filter wrench (for removing the oil filter.)
  • The appropriate crush washer for your oil drain plug-- this can be purchased from a hardware store or motorcycle service shop.
  • A pair of needle-nose pliers, in case the oil filler cap is hard to reach or tightly screwed on.
  • An adjustable socket wrench.
  • Clean rags.
  • The proper amount of manufacturer-recommended engine oil.
  • A new, manufacturer-approved oil filter.
  • A funnel
2. Unscrew the oil filter caps 3. Remove the oil rain plug 4. Replace and remove the crush washer 5. Clean the oil drain plug 6. Remove the oil filter 7. remove and clean plastic mesh filter 8. Lubricate the O-ring of the new filter and attach it to the engine 9. Replace Oil drain plug and plastic mesh filter then pour oil 10. Check oil level
Jun 14, 2010 | 1983 Honda XL 125 R
The filter light wont go off even though i have cleaned the filter
Try running the appliance with NO filter in for about 10 minutes. Does this make a difference? If so then the fault is in the filter unit --- possibly the micro mesh is blocked.
If symptoms persist use a hoover nozzle down where the filter fits to remove any debris.
Hope this helps
aardvark repairs
Nov 16, 2009 | Hotpoint TDC32 Electric Dryer
The dryer has ruined many of my clothes, straps and tank tops get caught on the lint filter and then twist until they tear apart. how can i fix this?
Purchase a lingere mesh bag.
Put delicate items in the mesh bag (has a nylon zipper) and dry.
Purchase two or three at Target, WalMart, etc.
Oct 06, 2009 | Dryers
I lost the mesh filter on my DeLonghi Caffe Elite coffee maker. How can I obtain a replacement?
Since nobody could tell me where I could purchase a replacement mesh screen folter, I now use 2 paper filters and that seems to work reasonably well.
Apr 18, 2009 | DeLonghi Caffe Elite DC76T Coffee Maker
I have a Bosch Exxcel tumble- dryer. It starts normally and runs normally for about five then, then a light begins flashing and washing is completely wet. I have been moving the washing around and...
3 important things to maintain with this dryer.
1. after every dryer use you MUST completely clean the lint filter in the machine. examine the fiter closely as washing powder and softener overuse can clog the fine mesh.
2. You should empty the water draw regularly.
3. You need to clear the condenser of lint and dust. This is located at the bottom of the Machine behind a hinged door. Unsecure the condenser and slide it out. (aluminum mutifinned box assembly) Take the condenser outside and using a garden hose with plenty of water pressure , carefully spray the airways clear in both directions, longways and crossways. Crossways is the more difficult to clear but must be done. Make sure you can see daylight through the fins once completed. Reassemble and test. If still problems a service man must come and clear lint and build up away from the pump area.
0417362369 Melbourne and Metro area
Regards Sam
Jan 29, 2009 | Audiovox Bosch 718 World Cellular Phone
Bosch axxis WTL lint indicator problem.
I have been struggling with this lint filter problem big-time. After reading the previous user's comment that his mesh holes had become clogged, I took a closer look at my filter and noticed that the tiny holes in the mesh were, indeed, clogged up. In fact, when I initially ran water on the filter it pooled up on the mesh like a solid plate...pretty good sign that air wasn't able to pass through the filter properly.
I used a soft toothbrush and soap to clean the filter, and when I ran water to rinse it off it the water passed right through the mesh. I popped it back in and, voila...That fixed it!!
Mar 08, 2008 | Bosch Axxis WTA 3510 Electric Dryer
KitchenAid Superba KSCS25FKSS00 SideXSide Refrigerator
I had two (2) broken wires in the harness. I don't think you actually have to take the door off. It may be a little cramped working, but I think it can be done. Once you take off the bottom grill, find the end of the harness next to the water filter and unplug the white plug. Just below that is a ground wire. Remove the screw and take the green wire off. Then, next to that is a white "c-clip" holding the harness against the bottom of the refrigerator. Remove that clamp and you should have enough "play" to work on the harness. (It is probably a pain in the #*@ to remove the entire harness because it runs into a hole in the bottom of the door and then up through the door itself) You'll have to cut away the black mesh sleeve over the harness. I cut it with a pair of wire cutters as close to where the harness goes into the door as possible. There may also be a bit of black electrical tape at the end of the mesh closest to the white plug. Remove that, and you should be able to slide the mesh sleeve off, over the plug. This should reveal the broken wires. I just took some 12 gauge braided wire and cut a couple of pieces
Oct 12, 2007 | KitchenAid Superba Architect KSCS25INSS...
Dryers Logo
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
