Question about Apple PowerBook G4 Mac Notebook
Blues screen starting up
I have kind of the same problem, when I startup the mac it only gets to the blue screen sometimes and I have to this 2 or 3 times until I finally get it started. It start happeniugn after an online updating.
What is to reboot in a safe mode??
  • 33 Answers
Safe Mode turns off all user prefs. and boots only using OS prefs. to find out if the issue is from corrupt user pref or not
Posted on Oct 06, 2009
My laptop is on but the screen is blue and won't go to the desktop
A Mac that shows you a blank blue screen instead of logging you in may be afflicted by a malfunctioning startup item. Most people have a number of programs that start up whenever you log into your computer, and it's likely that one of these programs is causing issues. The startup item is unable to load, and so it causes the rest of the computer to hang.
In order to get your Mac past this hanging blue screen, you need to boot into safe mode and figure out which startup item is causing problems. The Apple Support article "I see a blank blue screen when I try to start up my computer" tells you exactly how to go about this procedure. Basically, you must remove all your startup items and add them back in one-by-one, rebooting each time until you find the one that causes the hanging blue screen.
Dec 28, 2010 | Computers & Internet
The computer is on, but the screen is all blue
Dec 28, 2010 | Apple MacBook Mac Notebook
When powering it up it starts to boot I get a blue screen then it goes black where do I start ?
Try starting your mac from it's install disc.
1) First turn off your computer.
2) Then restart it, right when you push the power button to turn it on, press the option key down and hold it
3) pressing the option key will bring to a screen where you can choose your startup disk. Usually, you'll see your Macintosh HD available to startup from. Don't choose anything yet.
4) Insert your install disc into the CD slot.
5) wait a couple of seconds and then clock on your install disc as your startup option.
6) after clicking on the disc, go to the menubar and click on Utilities then disk utility.
7)once the disk utility app is open hit "verify disk permissions"
8) after you've "verified disk permission" hit "repair disk permissions"
- this might take a long time depending how much you've actually done this (which it's good to do every other month or so to keep your mac running smoothly). things might seem to freeze up as well, but it's the mac trying to verify and repair broken permissions on your computer. Don't that's normal.
9) after you have repaired the disk permission, reboot your mac by quitting disk utility and then choosing the startup disk as your normal macintosh HD. That should do the trick. If not, tell us what has changed.
Dec 15, 2010 | Apple PowerBook G4 Mac Notebook
My mac book 13 frozen with blue screen. start up disk full. managed to get on to interenet through the Mac OS X software option on my apple thing. but cant get to my files to delete or transfer to my...
There could be many known issues related to the blue screen. I would have mentioned few steps in this mail but i rather provide you with the steps guiding to online website.
Click on the Troubleshooting link and follow the steps accordingly :
Troubleshooting Link
Also, Try this step below as well
1) Put in the install CD that came with your Mac, reboot, hold down the letter C after you hear the chime, and when it boots to the installer, pick a language, and then run Disk Utility by finding it in the top menu.
2) Instead of holding down C at startup, hold down the letter D and make sure all your hardware's okay.
Nov 09, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Mac book starts with blue screen startup disk full
your disk partition is having problem.if u have not taken backup then boot the system with FW mode with saperate Laptop and backup the data,then repartition the hdd and install freshly
Apr 17, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Powerbook G4 blue screen on start up
Basically some causes of blue screen is the RAM check the RAM remove first maybe it is clogged by the dust. Remove the dust of the memory stick and insert it back to you computer. Usually of you have this problem again you need a recovery disk. Load a windows CD to your CD drive you need to boot and repair the windows.
Regards
nicole
Oct 03, 2009 | Apple PowerBook G4 Mac Notebook
When i stert my g4 imac,s screen was became blue
You need to reset your pram
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Jul 01, 2009 | Apple iMac All-in-one - 3.06GHz Intel Core...
Powerbook G4 Laptop not starting :-(
sotware is awry 1. put in your system disk and restart holding the c key 2. when the screen shows hit continue 3. go to utilities in the header menu 4. select disk utilty 5. select repair permissions 6. select repair disk after the permission repair is complete 7. quit utility go to start up disk  select your hard drive and restart good luck
Apr 01, 2009 | Apple PowerBook G4 Mac Notebook
Resolution issue Acer V223w
Hi, I'm sorry to hear you are having trouble....
THis is a tricky one. My first step would be to connect another screen to your G5 and connect your V223w to another Mac... Are you able to do this, do you have access to another system, could even be a PC ( in the worst case )
Ideally, having 2 screens connected to your G5 would be the best situation.
THis way, with one working screen, you can attempt to modify the resolution and refresh rates on the V223w from the good screen, be sure to activate screen mirroring, otherwise you will not have access to the other window of monitors system preferences.
If you can get two monitors connected and mirroring is not an option, then either your monitor is KAPUT or the video card secondary port is KAPUT, try switching the port of the card your displays are connected to. I think they are both DVI ports. If the opposite screen is now working, then you know it's the port on the video card.
Hope this will get you through it.
Mar 28, 2009 | Apple Power Mac G5 Desktop
Apple PowerBook G4 Mac Notebook Logo
299 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
