Question about Tivo Series 2 80-Hours Video Recorder
Tivo my tivo keeps stoping and going on recorded programs
  • 2 more comments
  • terro12 Dec 18, 2007
    please help me
  • terro12 Dec 19, 2007
    I am having the same problem and we erased everything and it is still doing it...now it even stops and goes when we are watching live TV!!! Now what??????
  • terro12 Dec 20, 2007
    Where do you purchase a kit and is it easy for someone who never replaced one before?
  • Anonymous Mar 25, 2014
    My TiVo no longer getting programing update thru the phone line and the phone jack is working
  • 38 Answers
It's most likely your hard drive. It can be replaced by doing it yourself or by using a pre-configured kit that you just put in and reprogram your settings and season passes. You will LOSE EVERYTHING on your drive, and if you are having trouble with your drive, there is no way to salvage any recordings off of it.
Posted on Dec 19, 2007
  • Steve Vance Dec 19, 2007
    No matter if you are watching live or recorded programs, it all goes through the hard drive, replacing the hard drive should fix it.
  • Steve Vance Dec 20, 2007
    Just google tivo upgrade kits and you'll get a list of who sells upgrades. yes, they are very easy to install.
What is the best way to remove protection from TiVo videos?
Yes, TIVO recordings store the video using MPEG-2 compression and include copyright protection. To retain its intact video quality, you can use a copy-protection removal program. In this way, protection is removed and the original video will be kept to be compatible with common media player. The program I recommend is Pavtube Video Converter which provides "Directly copy" option. Just input your TIVO access key, choose directly copy and you will get copy-free MPEG 2 video with extreme speed. I bought this program mainly to convert recorded TIVO videos for my iPad 3. This program provides presets for ipad. The output videos play perfectly in my iPad. http://www.pavtube.com/video_converter/
Jun 11, 2012 | Audio Players & Recorders
Tivo turns off TV
For some reason your Tivo is tripping the internal breaker of your TV. Check the cables and see that they are not damaged and are connected properly (all the cables that hook up to the Tivo). If you have a spare set of cables, try them to see if the TV still turns off.
Jan 01, 2008 | Tivo Series 2 80-Hours Video Recorder
Can a tivo series 2 be modded to use as a dvr without subscribing
No. But, i belive the series 2 will allow you to "create a mnual recording" .... so, if you know the time and channel your proigram is on, it will record. Keep in mind that you won't know what program is what since you haven't downloaeded the program titles....
May 22, 2009 | Tivo TCD540040 700-Hours Video Recorder
How to connect cable tv, dvd and vcr together and tivo, too
go to tivo.com they have all possible connections available.
pt
Jan 16, 2009 | Tivo Series2 TCD649080 Video Recorder
TiVo stops recording
The problem is probably due to lack of available space on your Hard Drive.
Try deleting some programs you have saved as "Keep Until I Delete" and you should then be able to completely record the new programs.
Also, in case you didn't know, Tivo will NOT let you fill up the entire Hard Drive with programs you want to record, but rather, it keeps approx. 30 minutes of Hard Drive space for each tuner as a buffer so that in the case of a show you are watching live, you can go back and replay part of a show you have just seen.
Oct 19, 2008 | Tivo Series2 TCD649080 Video Recorder
TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal.  Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly.  This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs.  I have the cable input on a different "input" to make it work.  Hope this helps.  Call TIVO tech assistance because they are the ones who talked me through this.
Mar 01, 2008 | Tivo Series2 TCD649080 Video Recorder
Tivo turns off TV unexpectedly
You could have a faulty power supply going out...
I would replace the power supply.
Tivo and direct tv
No, unfortunately there is not. That tivo only has 1 tuner, so you can only record or watch 1 live program. You can however watch a pre-recorded program while recording a live program. If you have directv, you can step up and get their hr20 dvr. It's not a tivo by any means, but it has 2 tuners so you can record 2 things at once and watch a pre-recorded show. It takes a little while to get used to the interface, but once you get the hang of it, it's pretty straightforward.
You can also get an older DVR w/ tivo (hr10) however, it will not get ANY of the new MPEG4 High Def channels that are out there.
If you have an hdtv, then you really should grab an hr20, give directv customer retention a call and ask what they can do for you. You'll need a new slimline dish and they'll come out install it and everything you need for watching off the new satellites and enjoying the new mpeg4 hd channels (the old hd channels are in mpeg2).
Good luck.
Dec 12, 2007 | Tivo Series 2 80-Hours Video Recorder
Tivo Programing
You either don't have it hooked up right w/ the source video cables connected or if you've changed setups from one tv to another (different cable box or input) you need to go through guided setup again, but first check your cables, ensure they are going to the inputs (rca or coax) and not going to the outputs.
Dec 03, 2007 | Tivo Series 2 80-Hours Video Recorder
Tivo Series 2 80-Hours Video Recorder Logo
Top Tivo Televison & Video Experts
Dave
Dave
Level 1 Expert
Tom Chichester
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
