I need the code for the philmore pm-rc1a so i cant watch my tv!
  • yana_rules Sep 28, 2009
    i don;t have the codes, and when i turn the tv off and follow the instructions, the tv does not turn back on ...
  • 403 Answers
Try this as most remote controls work the same when manual setting.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Posted on Sep 28, 2009
  • James Chavez Sep 28, 2009
    Try this with your remote.
    1. Manually turn on the device ( TV ).
    2. Press and hold CODE search until red indicator stays on, then release the CODE search button.
    3. Press and quickly release the TV button. The red indicator blinks off once.
    4. Face the remote directly to TV.
    5. Press the POWER on/off button down till the red indicator light stays on, then release your finger.
    6. The red indicator will keep on flashing till TV turns off.
    7. Press and release ENT ( enter ) to install the code before the next blinks.
    This method applies to VCR, DVD etc. You may not know the direct code but it does not a matter as long as it works. Good Luck !
    JimmyC
    The information I got for this remote is that there are no code for it. It works straight out of the box. I know this sounds crazy but did you change the batteries. Try this with your remote:
    Turn the TV ON. You can use the code search option by pressing Code
    until the LED flashes. Press the Power button until the TV turns off.
    Then press Enter.
    JimmyC
I need instructions and codes for a Philmore PM-RC26 iniversal remote.
Check the slot in TV where the HDMI cable is inserted. On your TV remote control (not Philmore) there will be a Source button or Input button. Press it & on your TV screen select HDMI 1 or HDMI 2. Now take the other remote control i.e. Philmore Universal remote in your hand. Press & release the S (set) button. Immediately enter the code. You have to be extremely fast in doing this.
Following are few codes which you can try:
Check the Visio TV manual for the Brand name, Model no & TV code if any. Then contact your TV manufacturer or retailer for the TV code to enter & synchronize with your new Philmore Remote Control.
Nov 13, 2016 | Televison & Video
I need codes for samsung blueray on philmore pm-rc1a
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Jan 22, 2016 | Samsung Televison & Video
Have a philmore pm-rc1a and need codes for sharp tv do you have them please
Sharp TV codes from instruction set = 004, 006, 012, 029, 095, 111,112,113, 122,171,173, 196
May 04, 2011 | Sharp Televison & Video
Codes for philmore Pm-rc1a remote control!
Philimore PM-RC 1A remote user guide:
* Manual turn on TV DEVICE.
* Press CODE on remoter until red light stay on, press "TV" on remoter,
then the red light will flash to keep searching for properly code until
TV DEVICE turn off (=right code found ), immediately press ENT on remoter. done!
GOOD LUCK!
Apr 08, 2009 | Televison & Video
Need codes for a philmore remote
need to know how to program a philmore pm-rc6 remote
Nov 14, 2008 | Motorola Audio Players & Recorders
Tv codes
try this link HERE
Thank you
May 08, 2008 | Televison & Video
Universal remote
Try these magnavox codes 011, 012, 013, 003, 043, 047 they are for a Philmore Commander remote
If your remote has 4 digit codes add a zero to those or try these.
0054, 0179, 0030, 0020, 0024, 0096, 0186, 0171
May 02, 2008 | Televison & Video
Philmore remote model # Pm RC1A
www.replacementremotes.com
Mar 19, 2008 | Televison & Video
Televison & Video Logo
274 people viewed this question
Top Televison & Video Experts
