Question about Microsoft Excel for PC
Bottom sheet numbers have disappeared
Bottom sheet numbers (worksheets) have disappeared
    President:
  • 1,901 Answers
Are you using the Custom Footer option?
Click View>Header and Footer...>Custom Footer...
It should have &[PAGE] in the section that you want the Page# to appear. If it does not, click the section where you want it and then click on the icon that has the # sign on it. Click OK.
Thanks for using Fixya.
Posted on Sep 28, 2009
How do I pull a figure from a spread sheet and add it to another in the same file.....
Are you talking about different worksheets in the same file.
go to the other worksheet then go to the particular cell and press = on keyboard
then use mouse to select the other worksheet from the bottom of the spreadsheet .
Then click on the cell you wish to link and press enter key on keyboard.
https://support.office.com/en-us/article/Insert-or-delete-a-worksheet-19d3d21e-a3b3-4e13-a422-d1f43f1faaf2
https://www.microsoftpressstore.com/articles/article.aspx?p=2447199&seqNum=2
You can also do this to spreadsheets with different file names by opening both spread sheets in different windows and switching between the windows.
you can also copy just the data by copy whole sheet (click on the square in top left hand and copy and then right click paste special on new worksheet - with values only rather than the original formulas from the spreadsheet
Jan 06, 2017 | The Computers & Internet
Tip
Excel- Unhide All Sheets
Advanced Hide Options
When we hide worksheets using, still user can right click on tabs and un-hide the worksheets. For example, following example will hide the worksheet and user can un hide the sheets on right click on sheet tabs:
Sub sbHideSheet() Sheets("SheetName").Visible = False 'OR Sheets("SheetName").Visible = xlSheetHidden End Sub What if you do not want to permit users to un-hide worksheet, you can set the Visible property of worksheet to xlSheetVeryHidden and lock the VBA code. so that user can not un-hide the worksheet. The below example will hide the sheet and user can not see it in un hide worksheet dialog list.
Sub sbVeryHiddenSheet()
Sheets("SheetName").Visible = xlSheetVeryHidden
End Sub
on Dec 09, 2016 | Microsoft Excel for PC
Describe the each part of microsoft excel 2207
Parts of the Excel 2007 Screen
Active Cell In an Excel 2007 worksheet, the cell with the black outline. Data is always entered into the active cell.
Column Letter Columns run vertically on a worksheet and each one is identified by a letter in the column header.
Formula Bar Located above the worksheet, this area displays the contents of the active cell. It can also be used for entering or editing data and formulas.
Name Box Located next to the formula bar, the Name Box displays the cell reference or the name of the active cell.
Row Number Rows run horizontally in an Excel 2007 worksheet and are identified by a number in therow header.
Sheet Tab Switching between worksheets in an Excel 2007 file is done by clicking on the sheet tab at the bottom of the screen.
Quick Access Toolbar This customizable toolbar allows you to add frequently used commands. Click on the down arrow at the end of the toolbar to display the toolbar's options.
Office Button Clicking on the Office Button displays a drop down menu containing a number of options, such as open, save, and print. The options in the Office Button menu are very similar to those found under the File menu in previous versions of Excel.
Ribbon The Ribbon is the strip of buttons and icons located above the work area in Excel 2007. The Ribbon replaces the menus and toolbars found in earlier versions of Excel.
Here are the main parts of Microsoft Excel 2007. Thank you for using Fixya !!!
Nov 15, 2010 | Microsoft Windows XP Professional
Cammot change numbers or names on wage sheet trial expired need product key
1) Purchase the product
or
2) Try to save the worksheet, uninstall and reinstall the trial product and load up the worksheet again. If that doesn't work try to send the worksheet to another PC and install the trial there.
Jul 15, 2009 | Compaq Armada M700 Notebook
Using sumifs formula accross multiple sheets
Here is the syntax: =SUMIF(Sheet2!A1:A3,"> 1", Sheet2!B1:B3)
This says if the cells A1 through A3 in worksheet "Sheet2" are greater than 1 then return the values from worksheet "Sheet2" cells B1 through B3.
Change the worksheet name Sheet2 to your worksheet name and change the cell references to the ones you need.
Apr 17, 2009 | Computers & Internet
How do I add a number from one work sheet to another in excel ?
You can access numbers from another worksheet by using the formula (=SheetName!P1)
That would access cell P1 on the worksheet called "SheetName"
Jan 12, 2009 | Microsoft Office Standard for PC
Closing Worksheet on executing Hyperlink command
You could do this by creating a close button with the worksheet- Do this via insertin ga prompt in Macro.
Dec 20, 2008 | Microsoft Computers & Internet
Reference other worksheet in excel
eg if i want to add to numbers
in sheet 1 i have the value 20 in cell B3
in sheet 2 i have the value 10 in cell B4
thus the formula would be:
=sheet1!B3+sheet2!B4
Mar 13, 2008 | Microsoft Excel for PC
Unsure of correct formula
You can add a reference from the worksheet 1 to all other worksheets
Is it OK?
Mar 08, 2008 | Microsoft Excel for PC
Exel 2003
You can refer to cells that are on other worksheets by perpending the name of the worksheet followed by an exclamation point (!) to the cell reference. In the following example, the AVERAGE worksheet function calculates the average value for the range C1:C10 on the worksheet named Marketing in the same workbook.
default.aspx?assetid=za010939481033 Refers to the worksheet named Marketing default.aspx?assetid=za010939491033 Refers to the range of cells between C1 and C10, inclusively
  1. Click the cell in which you want to enter the formula.
  2. In the formula bar (formula bar: A bar at the top of the Excel window that you use to enter or edit values or formulas in cells or charts. Displays the constant value or formula stored in the active cell.) default.aspx?assetid=za060515351033, type = (equal sign).
  3. Click the tab for the worksheet to be referenced.
  4. Select the cell or range of cells to be referenced.
Jan 01, 2008 | Microsoft Office Standard for PC
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
56 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
