Question about IBM ThinkPad T30 2366 Notebook
Will not come out of hibernation --I left it hibernating for a few days and now it won't wake up. Hard drive light blinks briefly when I hit the power button but nothing else happens. Battery and power supply are OK.
  • 448 Answers
Please remove the Battery from the Computer and clean the metal contacts.
Next, press and hold the Power button on the Notebook for 30 seconds before inserting the battery and turning it ON.
Good luck!!!!!!!!!!!
Posted on Sep 28, 2009
Hp550 computer not going to sleep mode properly
No matter which model of HP laptop you own, battery life is a big issue. Hibernation mode is designed to increase the battery life of your HP laptop by switching off the monitor, hard drive and other parts of the unit after they have been idle for a specific period of time. While hibernation mode works well most of the time, in some cases, your HP laptop may not wake from hibernation the way it should.
Docking Station Issues Many hibernation problems are caused not by the HP laptop itself but by the docking station to which it is attached. Some models of docking station interfere with the normal operation of the hibernation on the HP laptop. The easiest way to test this is to remove the laptop from the docking station and allow it to sit until hibernation begins. If hibernation mode works with the laptop undocked but not while docked, you know the problem lies with the docking station instead of the HP laptop. b> Remote Desktop Issues If you need to connect to your HP laptop from elsewhere, it is helpful to reset the power settings to the Always On mode before you leave your home or office. Many models of HP laptops do not wake properly from hibernation when users connect to them remotely using the remote desktop feature of Windows. When users connect with remote desktop, the program sends a signal to the remote computer that should wake it from hibernation and allow it to function normally. However, this process does not always work as intended with HP computers, so it helps to change the power settings to allow a seamless connection. Video Drivers Problems with HP laptop hibernation also can be caused by a corrupt or outdated video drive. HP laptops come with built-in video processors, and the drivers they use are installed during the initial setup of the unit. If there is a problem with that driver, HP releases an update, so if you see problems with hibernation, your first step should be to check for an updated video driver. b> External Keyboard and Mouse Sometimes the HP laptop does not respond properly and does not wake from hibernation when you use the built-in keyboard and touchpad mouse. The sensitivity of HP touchpads varies from model to model, and that sensitivity can be reduced over time. You can test for this problem by attaching an external keyboard and mouse to the laptop to determine whether that resolves the problem.
Feb 20, 2013 | Computers & Internet
Dell d520 hibernates, won't wake up
When you get access, go into power options, select hibernate top right, and uncheck the box to the left to disable it, this will free up more disc space and get rid of microsoft worst idea.
Jul 20, 2012 | Dell Latitude D520 Notebook
I have set up the hibernation settings for when you close the lid but now it wiont come out of it when the lid is opened
Hit the space bar or enter key to wake it up. Maybe you have to pres the Power Button to wake it up.
Read the manual to see how to wake it up.
Get online and got to www.google.com In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals on the site and search them on hibernation.
Below is what your manual says to get out of hibernation you have to press the Power Button (very last paragraph at bottom).
Hibernate Mode Hibernate mode conserves power by copying system data to a reserved area on the hard drive and then completely turning off the computer. When the computer exits hibernate mode, it returns to the same operating state it was in before entering hibernate mode.
notice.gif NOTICE: You cannot remove devices or undock your computer while your computer is in hibernate mode. Your computer enters hibernate mode if the battery charge level becomes critically low.
To manually enter hibernate mode:
  • Press <Fn><F1>.
or
  • Click the Start button, click Turn off computer, press and hold <Shift>, and then click Hibernate.
or
  • Depending on how you set the power management options on the Advanced tab in the Power Options Properties window, use one of the following methods to enter hibernate mode:
    • Press the power button.
    • Close the display.
    • Press <Fn><Esc>.
note.gif NOTE: Some PC Cards may not operate correctly after the computer exits hibernate mode. Remove and reinsert the card, or simply restart (reboot) your computer. To exit hibernate mode, press the power button. The computer may take a short time to exit hibernate mode. You cannot make the computer exit hibernate mode by pressing a key or touching the touch pad or track stick. For more information on hibernate mode, see the documentation that came with your operating system.
May 14, 2012 | Dell Latitude D610 Notebook
How to wake msi u130 from sleeping?tnx
If it is in sleep pressing any key or moving the mouse will generally wake it up. If you left the computer unplugged in sleep mode then it most likely ran out of power. If your using hibernate I would recommend not using it as it has so many issues.... :) If you have to hit the power button to wake it up then it's either shutdown or in hibernate. FYI there will generally be an amber light on to indicate sleep mode. If no lights it's most likely not in sleep mode.
Comment if you need additional assistance.
Aug 24, 2011 | Acer Aspire One Netbook 8.9" Notebook
My laptop keeps saying hibernating and i cannot get to menu screen.
Definition: Hibernate is another option for powering down your laptop. When you use Hibernate all data will be saved to the hard drive in a compressed form. Once you start up from Hibernate mode you will be able to work with the applications and documents you left open before putting the laptop into Hibernate.
Hibernate is best used to conserve laptop battery power when you will be away from the laptop for more than a few minutes. You can put your laptop into Hibernate overnight or when you will be away from it for a few hours. Examples: Rather than shutting down my laptop each night, I use Hibernate to help conserve battery power and enable me to access my open files quicker in the morning.
If you are not going to use your computer for a few hours, it is a good idea to put it to sleep (also known as mode) to save power. If you are not going to use the computer for more than a day, it is usually best to turn it off.
hope it helps.... please rate if you like my post...thanks
Jun 06, 2011 | Computers & Internet
Acer Aspire One in permanent hibernate ''coma''
There have been times when Ctrl + Alt + Delete has brought the desktop back up. Usually, hibernation is disrupted by simply pushing the power button once, the computer will eventually come out of hibernation. Most clients I have done work for have me take hibernation off completetly, this is done in the control pnel under power options. There is a tab specific for hibernation.
Nov 30, 2009 | Acer Aspire One AOA150-1570 Notebook PC
Same as above I think
first of all never never never use hibernate only use standby. you want you hard drive to crash and loose all you info keep hibernating your laptop.
Jun 22, 2009 | ASUS Eee PC 901 XP Notebook
Toshiba Qosmio F15 AV201 - permenant hibernation
i have the same problem but the power is completely shutdown
Oct 22, 2008 | Toshiba QOSMIO F15-AV201 Notebook
My laptop wont hibernate!
Typically this indicates a problem with a particular piece of hardware or its driver that is not cooperating when windows tries to hibernate. Do you have anything new attached to the system? If so, try unplugging it, rebooting, and see if it cooperates then. Also, have you checked the windows event log to see if windows reports any particular errors when trying to hibernate?
Sep 02, 2007 | Toshiba Satellite M55-S135 Notebook
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
IBM ThinkPad T30 2366 Notebook Logo
302 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
