Question about Polaroid i835 Digital Camera
My camera isn't turning on even though i put the battries but it still isn't working
I cant charge the battery through computer
The C183 isn't a battery charger. If you use rechargeable AA batteries in it, you must charge the batteries outside the camera using a separate battery charger.
Aug 01, 2012 | Kodak C183 Digital Camera
Camera will not turn on...charged battery but the charge light blinks instead of staying solid
If battries still blinking , chances are that the battries are buggred...try new battries after fully charging...this is cheaper option to try before trying to open the camera..
May 20, 2009 | Casio Exilim EX-Z77 Digital Camera
Camera will Not turning on even when battry is fully charged.
take out your battery and then put it back in mine does that and found out the little black rubber pice fell off
Feb 12, 2009 | Panasonic Palmcorder VDR-M50 DVD Camcorder
DV5900
Connect the USB connector into the computer and turn on your camera. The camera might turn on because of the connection. You may be able to drag your files into your computer now.
Or, if your camera has a memory card, insert it into your built-in card reader(in your CPU, if you have one) or buy a memory card reader...
May 16, 2008 | Aiptek Pocket DV 5900 DV Digital Camcorder
Camera wont turn on even with new batteries
In order to narrow down the issue, I suggest you the following steps. 1) First of all we have to power drain the Camera. Take out the battries and unplug adaptor, now hold the power on putton ( Click Button) for a minute this will clear the static power on Camera. If this doesn't fix the issue, Than.... 2) As cam is working fine with Ac adaport and batterys are not working you have to check the cam with the new battries. If you store battries for a long time with out using them, they may result in battery drain. If this doesn't work. 3) Then it need a Physical check, where we can track if Power suply from battries are reaching till its destination or not. This is the way to narrow down the issue. Thanks you.
Apr 08, 2007 | Konica Minolta DiMAGE Z1 Digital Camera
My camera is not starting at all
I had the same problem. Almost brand new. Would turn it on and would last only 2-3 seconds, couldn't even complete one picture. Suddenly, I put in fully charged batteries and now it works! I had tried these before. The only difference was I used the batteries in another device and returned them to recharge. Just last night I decided to try once more and the charged batteries worked. No problems since with power, except now I can't get images to transfer! I did notice one little line in instructions I had never seen than when you change batteries, you have to program the camera with type used.
Mar 27, 2007 | Nikon Coolpix L1 Digital Camera
Display blurred and cam showing low batt
Bad luck is that the CCD sensor in your camera has stopped working properly and needs replacing. You are lucky though because Canon repairs this fault on S1 - IS free of charge so phone them and inquire.
Dec 26, 2006 | Canon PowerShot S1 IS Digital Camera
Polaroid i835 Digital Camera Logo
55 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
