Question about Acer Aspire 5100 Notebook
Dead screen---many colors vertical lines - Acer Aspire 5100 Notebook
  • 167 Answers
I have seen this a lot-it is more likely that the cable from the motherboard-that run up the through one of the hinge. and a lot of opening and closing can wear that cable down. it is also possible the video hardware is at fault. if you bend a cable enough it will wear. good luck! hope this helps.
Posted on Oct 15, 2009
    Problem Solver:
  • 7 Answers
Good news and bad news. The bad news is your screen is definitely dead, my guess, it was either dropped, flexed too hard or maybe bad cable.
The good news is that LCD replacement screens are cheap these days and replacement is fairly easy. About 7-8 years ago, a new LCD panel for a laptop would cost about $1000, but these days you can buy an OEM LCD screen for a little as $100 and replace it yourself or take it to a shop for repair. Ebay Search for acer aspire 5100 lcd
If you're handy and have a small phillips screwdriver, you can easily replace the LCD yourself in as little as 30 minutes. I can't tell you exactly how to replace the LCD on an Acer, as I've only worked with IBM (now Lenovo), Dell, HP/Compaq, Everex, mostly enterprise class laptops.
But to separate the LCD from the shell, you'll most likely need to remove a few plastic self-adhesive screw covers on the inside of the plastic trim, which will allow you to split the bezel away from the lid. You'll also likely need to unscrew a few screws from the bottom of the case to lift out the keyboard and the top cover nearest the LCD hinge. You'll probably need to open these up so you can access the LCDs cable connection to the laptop motherboard. Split the bezel from the lid and you'll see more screws to remove to take out the LCD. You'll need to remember what you're doing, because you'll need to do the work in reverse to install the new screen.
It's not that hard, but it does take some time and patience. The screws are very small and can get easily lost and some of the parts are fragile.
Posted on Sep 28, 2009
    Scholar:
  • 96 Answers
LCD screen is faulty, but just to be sure, plug in a monitor, press and hold the function ( FN ) button (bottom left), press the F3 F4 or F5 key (the one with a picture of a monitor on it) this should enable to external display. If that works, then you need a new LCD screen (or maybe it's just a loose connection. Take it to the repair shop.
Cheers.
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Dell Latitude D505 half of screen is black with colored vertical lines.
Sounds like you have a section of dead pixels. This can happen if the laptop has been dropped a lot or stepped on or some type of impact on the laptop. This is a hardware issue. You will need to have the screen replaced. In my opinion, by the age of the laptop, its better off getting a new one.
Oct 01, 2014 | Dell Latitude D505 Notebook
I have multi colored vertical lines across the entire screen. The menu screen is perfectly legible when selected on the remote and will go on and off like it is suppose to.
If this tv vertical colors lines problems happen by itself,tv problems not causes by u or an object by hitting forces to the tv LCD screen panel itself.The tv board that call the T-CON board it is dead,this board sit in the bottom in the middle of the LCD screen panel.Must be replaced the T-CON board to solve tv vertical colored vertical lines.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.If causing by u or an object by hitting forces it to the LCD screen panel itself.The tv not worth a whole tv anymore,because by replacing the tv LCD screen panel will cost the same as a new tv.
Jul 28, 2011 | JVC LT37XM48 LCD TV
I have a sharp 52d62u with a lot of vertical lines on the whole screen. They vary in color. Is there any fix for this or do I need to find a new tv?
Anybody or an object hit the LCD screen panel,that cause truama to it,than it not repairable.The LCD screen panel it dead.Nobody or an object hit the LCD screen panel.If vertical colors lines it happen,by itself.Than the T-Con board is dead.The T-Con board,that the board,that sit right in the middle bottom of the LCD screen panel.Replaced the T-Con board should solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con board for the replacement.
Sep 17, 2010 | Televison & Video
My Samsung PS50Q96HD had coloured vertical lines on the right of the screen. An engineer from Comet came had a look at it and said it was the screen which can be replaced for aroung £500.00 nearly the...
The colors vertical lines on the tv are more 3 or 4 lines,not worth fixing,he porobally right the screen is dead,not.Take the Samsung authorised offer,because it there products,the 90 Euro refuned,it great,if repair have to be made.
Jul 03, 2010 | Samsung LTN1535 15 in. HD-Ready LCD...
No picture just sound.
Ur video ic inverter board is dying about to be dead.U need a new video ic inverter board.
Aug 25, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Blue vertical line
The lines appearing on your LCD means it has a defect on the screen.
There are 3 types of pixel defect
1) dead pixel - pixel is always off
2) stuck pixel - pixel is always on
3) hot pixel - pixel is on but in red, green, blue or yellow, can also be a light black color
You can try to fix stuck or hot pixels but dead is dead.
1st method, flashing different colors rapidly:
JSScreenfix.com has a great tool. This is their free java applet or you can download it below.
2nd method, applying pressure to pixel:
Damp paper towel, Small stylus or dull pencil.
3rd method, tapping the pixel:
Pen with cover on or another small, blunt object.
If your laptop is still under warranty, get it replaced. If not you are looking at the most expensive part in a laptop to get replaced. (LCD screens on laptop is roughly equivalent to 40-60% of the total laptop cost
Please rate this if it this helps.
Jun 05, 2009 | Compaq Presario M2000 Notebook
My Ibm Laptop r51 has a vertical lines on the screen
Jun 02, 2009 | IBM ThinkPad R51 Notebook
Screen had multi-color vertical lines, then went black
the monitor has power board issues it is not your video card. its not dead but it will require some soldering work to repair.
May 22, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Acer Aspire 5100 Notebook Logo
512 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
