Question about Toto MS854114S - Ultramax One Piece Toilet - One-Piece Toilets
Fill value won't shut off even though flapper
Fill valve won't shut off even though flapper seats properl.
Do I simply replace the fill valve or is there a repair I can make?
  • 863 Answers
Your fill valve is clogged with sediment.  You probably got one of those cheap *** Fluid Master brands.  Go to Lowes and get a better fill valve made by Korky and happy flushing my friend.
Posted on Oct 26, 2009
  • Poppy Chulo
    Poppy Chulo Oct 26, 2009
    You should replace the flapper with a Korky brand also, cause your flapper is not sealing even though it looks like it is sealed.
    Genius:
  • 1,341 Answers
Some of these can be solved simply by adjusting the fill valve,check float as well. If these do not solve your problem then you need a replacement.
Posted on Sep 28, 2009
Tip
Our commode isn't leaking, yet it refills many times a day
If your commode is refilling over and over, you may have a Ghost Flushing problem. Even though there's no water on the bathroom floor, you likely still have a slow leak somewhere in the tank. To locate and identify the source of the leak fill the tank and shut off the water to the commode. Remove the tank lid and draw a pencil line along the top edge of the water line. Leave the water turned off and go back several times and redraw the pencil line at the water line. When the water stops draining see where the water level is. If the water has stopped just below the overflow tube, you likely have a siphoning problem. If the water drains to the bottom of the tank you likely have a flapper problem.<br />To correct the siphoning problem reset the the depth of the fill tube in the overflow tube. Fill the tank up, shut the water off, and recheck after some time. Repeat these steps until the water stops draining.<br />To correct the flapper problem gently lift the flapper and clean the bottom of the flapper and the flapper seat. Refill the tank, shut the water off, and recheck later. If water still leaks replace the flapper.
on Dec 28, 2010 | Plumbing
Will not stop filling
press on the flapper and see if the water fills and stops filling. If not replace the fill valve.
replace the flapper if when you force the fill valve closed or shut off the supply water to the toilet and it drains out.
Sep 21, 2013 | Toto Orinigal Replacement Part Thu013p 1...
My cadet toilet does not fill. I have to open the tank and push the valve to get it to fill. Do I need to replace a part ?
I would suggest trying to clean the flapper seat and also the pins that the flapper hinges on. If the flapper looks closed you can try putting a bit of petrolium jelly on the flapper seat and see if that fixes the problem. If nit you should replace the flapper.
May 26, 2011 | American Standard 4112.016 Cadet Toilet...
My toilet keeps running. I tried to adjust the float with a phillips but that did not work. There is slight leaking into the chamber over the top.
If there is a continual leak in to the toilet bowl you will likely need to replace the flush valve or the toilet flapper.
As a first step try try cleaning the sealing surface of the flush valve to se if the flapper will seat and make a seal.
If this does not work and the flapper is visibly detioriated and breaking down shut off the water supply, remove the toilet flapper and visit your local plumbing supply store to purchase a suitable replacement. Install the new flapper, turn on water supply.
These illustrated instruictions may also assist:
http://www.danco.com/HowTo/How-To-Replace-a-Toilet-Flapper
Although less likely, if the sealing surface of the flush valve is damaged or detioriated proceed with replacement of the flush valve. Again turn off water supply and follow the instructions set out here:
http://www.danco.com/HowTo/How-To-Replace-a-Flush-Valve
If there is not a leak in to the toilet bowl and the water flow does not shut off completely, then water is flowing through the fill valve and the overflow pipe and you may need to adjust the float and float rod to allow clsoure of the fill valve. See here:
http://www.danco.com/HowTo/How-To-Replace-a-Float-and-Float-Rod
Mar 09, 2011 | Kohler Cimarron 2-PC Elongated Toilet with...
Eljer 0220 toilet leaks from tank to bowl, then fill valve spurts out water from top and around the edges, and also through the tube that goes to the overflow. Replaced the flapper, but still leaks. Also...
When the tank is full and leaking into the bowl reach in and put slight pressure on the flapper and if the leak stops then you may have the wrong flapper or the flapper is not installed properly. If that is not the case then make sure the flush valve seat is not cracked or that the surface is not warped.
Mar 05, 2011 | Eljer 091-0220-00 White Savoy Two-Piece...
Changed the flapper on my toto toiet and yet still there is a hissing from the fill valve, any suggestions?
changing the flapper will not help the fill valve if it is not shutting off. It is not shutting off all the way once the water fills up, you either need to replace the seal in the fill valve or replace the fill valve. They can get grit in them or get scaled up and they stop working properly.
Oct 21, 2009 | Toto Ultramax One Piece Elongated Toilet...
The gmax continues to run and won/t stop
if it worked fine and now it has stopped....then there is no adjustment that will fix it. If the fill valve is not shutting off you either need to replace the seal in the valve or get a new fill valve. If the water is leaking past the flapper you will need a new flapper.
Oct 20, 2009 | Toto Drake ADA Compliant Toilet with...
Same problem. water wont shut off.
You need a new fill valve,Get Fluidmaster style.That is if you have the old ball type.
We find toilet flappers the main reason there is septic backups(leaking flappers)
Good luck.
Jul 23, 2009 | Duravit 001422.00.00 Vario Connector Set...
Water continues to drip from fill tube after the fill.
Chances are the flapper is leaking. Thats causing the random refilling as the tank slowly loses water into the bowl.
Replace the flapper with only the best available at your supply house. the cheap ones tend to leak even when new. The good ones are less than 8 bucks most places.
If your fill valve has the float ball, there should be a screw right on top of the fill valve at the end of the rod holding the ball to adjust the water level.
Closckwise lowers the level.
Be carefull not to break the plastic ones. If the adjustment is all the way in or does not work, you will need to replace the fill valve.
You could also try bending the metal rod holding the ball, but only as a last resort.
Nov 25, 2008 | Home
Toto MS854114S - Ultramax  One Piece Toilet - One-Piece Toilets Logo
490 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
