Question about GE GSS25SGMBS Side by Side Refrigerator
My gss25sgmc freezer creates ice all over the freezer, not just the ice dispenser, do i need to change the temperature?
  • GE Master
  • 4,655 Answers
I believe your condensate defrost drain is either blocked or frozen over behind the rear panel of your freezer. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, there is also a short movie that makes the repair look easy, Thanks Sea Breeze
click on link below
Click Here=> HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
SEA BREEZE TIP'S
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Posted on Sep 28, 2009
No water or ice coming from the dispenser, ice is being made. Cannot change the freezer temperature
Fix your GE refrigerator door ice and water dispenser ...
? 18:47
www.youtube.com/watch?v=8yNWbNaNCOA
Oct 20, 2013 - Uploaded by StewTube
Fix your GE refrigerator door ice and water dispenser and save ...it makes ice but no water or ice come out from the dispenserAnd if it's the ...
Oct 24, 2015 | Refrigerators
I have a frigidaire gallery series and my ice has started melting once it is dispensed. All of the ice is in one big block and water comes out of the dispenser and pools at the bottom of the refriger
Hello Michelle Driscoll, thank you for your post!
I see that you're describing that the ice is coming out as a big block and your dispenser is leaking on your Frigidaire refrigerator. I would turn down the temperature on the inside of your freezer to see if that would help create blocks. If that is not successful it could be an issue with an air leak causing heat to come into your freezer I would recommend checking the gasket which can be done by using a dollar bill. Place the bill between the body of the freezer and close the door. Pull the dollar out, if it sticks the seal is good, but if the bill comes out easily the gasket needs to be changed.
If your appliance continues to create an ice block or leak water I would suggest contacting a professional to come out to your home to diagnose your appliance. I hope this is helpful information. -Matt
Sep 07, 2014 | Frigidaire FGHG2344MF 23 counter depth fd...
We changed the filter for the water, now it will not dispense water, but the ice maker still works.
Hello nott225 - The issue sounds like it might be related to the temperature in the freezer. What is it set to? Make sure that the temperature is approximately around 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. If it is properly set, then consult a professional to accurately pinpoint any potentially more serious issues like a faulty ice maker valve or even the ice maker itself.
Feb 03, 2013 | Frigidaire FRS23H7CS Side by Side...
Freezer cool and refrigerator side warm GE SIDE BY SIDE Model# GSS25SGMC BC SERIAL# 205507-- WORK OK after unplugging and defrosting
Check out the coil after defrosting you can get all of the ice out of the coils at the back of the freezer. While letting the ice melt, do some cleaning as well. Check if this solves it. If not, you may have to have the thermistor replaced.
Aug 29, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice dispenser not working, temperature display off then on
If you pull out the collecor of ice can you then hear and see rotater arm rotating in the back of freezer. If not you need to remove panel and check for voltage at notor and inspect motor.
If you have 120vac and no motion you'll need to replace motor. We have them same day shipping 704-819-6657
Mar 14, 2009 | GE Profile¿ Arctica® Energy...
Dispenser stops working
THIS PROBLEM COULD BE CAUSED BY THE MAIN PCB, HOWEVER IT IS MORE LIKELY TO BE A FAULTY CONNECTION OR A BAD CONNECTION ON THE POWER SUPPLY TO THE APPLIANCE. REGARDS ADVISOR
Aug 24, 2007 | GE GSS25SGMBS Side by Side Refrigerator
GE GSS25SGMBS Side by Side Refrigerator Logo
286 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
