Question about Fender Audio Players & Recorders
The light on my twin reverb is dimming - Fender Audio Players & Recorders
    Problem Solver:
  • 3 Answers
If everything still sounds ok, the bulb is probably just getting old. there are many places on the web to order replacement parts without having to pay big money for repairs at the big stores.
Posted on Sep 28, 2009
This is a newer model Twin with SN CR-278102 what is the year of manufacture
Please provide more detail. There could be like a million devices with similar serial #
Name=
Model #=
What type of device it is=
Dec 02, 2015 | Fender 65 Twin Reverb Amplifier
No reverb on my fender ps 160 Vocal amplifier
Here is a link to the schematic drawing
http://www.prowessamplifiers.com/schematics/fender/ps160.pdf
items to check are
1-the footswitch and plug
2-the reverb unit ,usually found at the bottom of the box
3-the reverb unit is plugged in to the amp
4-V6 a 7025 valve
5- the reverb switch is in the on position
Hope this helps
Len
Oct 14, 2014 | Music
05 cadillac sts left brakelight is dim
The globe may be in backwards. Twin filiment globes can sometimes be installed back to front. See when you have your running lights on if that one is brighter than the other, if so it is backwards, Otherwise the globe is probably getting old & blackened & need to be replaced.
Jun 22, 2012 | 2005 Cadillac STS
How do I get the electronics out of the cabinet to clean the pots .Thanks Paul
DO NOT CLEAN the pots... Use CRC226 available at Home Depot nin the electrical dept in them. Use of contact cleaners destroys the resistance element and its lubrication. Typically there are screws to remove to release the chassis... AND often the handle screws are ALSO used to hold the chassis... sometimes these screws are hidden under caps at the ends opf the handle.
May 30, 2011 | Fender 65 Twin Reverb 85W 2x12 Tube Guitar...
The reverb channel on my fender twin feeds back
Not sure of how it is feeding back. Two possibilities... the reverb tank in the cabinet is no longer shock mounted. The other is your guitar can "hear" the speaker... make sure you are away from the amp. With the reverb on, the feedback stability is less than with it off so make sure your guitar is away from the amp. Acoustic guitars are more sensitive to this than solid body ones.
May 10, 2011 | Fender 65 Twin Reverb 85W 2x12 Tube Guitar...
I got this old Reverb Amp from cleaning out a house for a real estate agent. I was wondering its worth & how to go about getting it to someone who would like to have it. Thank You Its a Pioneer SR-202...
It's an old 'spring-type' reverb.
http://en.wikipedia.org/wiki/Reverberation#Spring_reverberators
I have one from the mid-70's, long unused. Digital reverb is more predictable and not susceptible to rom vibrations or jarring. There are those who would still want one.
You might put it out on eBay. They don't get much for them.
This auction expires in 2 days. The bidding is $20.50 right now. You might watch it to see what the unit eventually goes for.
http://cgi.ebay.com/Vintage-Pioneer-Reverb-Unit-SR-202w-/260777273468?pt=Vintage_Electronics_R2&hash=item3cb789687c
May 05, 2011 | Audio Players & Recorders
Twin tube amp. power comes on, no sound. replaced tubes, still no sound
Do you have the speakers connected properly?? If so, maybe speaker wiring needs checked.
Feb 19, 2011 | Fender 65 Twin Reverb 85W 2x12 Tube Guitar...
Hot Rod Deville, reverb squeal...
Here is an article that might help:http://www.guitarplayer.com/article/reverb-troubleshooting/jun-09/97165 Here is the schematic:http://www.fender.com/support/amp_schematics/pdfs/Hot_Rod_DeVille_Schematic.pdf Check to see if someone hasn't reversed the input and output cables at the reverb tank. Then troubleshoot the reverb section .
Aug 28, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Peavey bandit 112 reverb
It might just be the control knob. My fender's reverb went out and it was just the knob.
Mar 23, 2009 | Audio Players & Recorders
I have a Fender tube amp The Twinn. 4 6l6 2 12at7 and 4 12ax7. Mu reverb is dead and I here some strange oscillation. I suspect the 12at7 in reverb and one 12ax7 Both microphonic and very dem fil. ...
Hi ohmytom
Yes, they could be causing the problem.The filaments are a little hard to see sometimes, you will always get a little microphonic activity about preamp tubes. It may also have failing capacitors depending on how old it is. Is it a "Twin Reverb". Let me know the exact model and we can be a little more specific of the problem and solution. Cheers
regards
robotek
Jul 14, 2008 | Audio Players & Recorders
87 people viewed this question
Top Fender Audio Players & Recorders Experts
Michial Gueffroy
Glenn Mayer
Glenn Mayer
 Grubhead
Grubhead
Are you a Fender Audio Player and Recorder Expert? Answer questions, earn points and help others
