Question about Giottos Giotto's MH7001 Pro Ball Head with Built-in MH652 Quick Release Plate, Supports 11 lbs. Tripod
I own a bogen grip action ball head and I want to mount it to my light stand and use my light stand as a tripod. Is there an adapter available to make it fit?
How do I tighten my Manfrotto 3265 ? After 15 years of use, it is slipping and not supporting my camera.
Check out the videos at http://bogentripodparts.com/repairs.htm the second on the leftside deals with this problem. They also do reapirs.
Oct 19, 2013 | Bogen Communication Bogen Manfrotto 3265...
Ball slipping
Check out this page and see if there are any parts here that might be what you're looking for:
http://www.bogentripodparts.com/parts/head322RC2.htm
However, I'm not sure there's a way to fix a ball head tripod due to how the tension works for the ball that it rests on. You can also order a new head from the same website. If you have any questions, shoot us an email at email@spartanphotocenter.com
Nov 21, 2012 | Bogen Communication Bogen Manfrotto 322RC2...
My 322RC2 Grip Action Ball Quick Release has lost
I had the same problem and found the solution after much looking online. Use rubbing alcohol to clean the ball! This works even with the ball in place as long as you rotate the head around to reach all surfaces of the ball. Note that many suggestions to tighten the Allen screw at the base of grip clamp or to roll the wheel to its tightest position do not work because they affect the amount of effort you need to squeeze the clamp, and not specifically the amount of friction between the ball itself and the head. Over time the ball loses it's grip but rubbing alcohol removes finger oils, dust, airborne pollution, etc. After wiping with rubbing alcohol, my ten year old head is now as tight as the day I bought it! Hope this works for you.
Apr 03, 2010 | Manfrotto (Distributed by Bogen) 190XPROB...
I have a Manfrotto 3265 tripod head. The quick
You can get the quick release lever seperately. Check the website for the part needed.
http://bogentripodparts.com/parts/head3265.htm
Hope this helps,
Andrew
Feb 17, 2010 | Bogen Communication Bogen Manfrotto 3265...
Need a user guide for a Manfrotto Bogen 3265 grip action ball hea
Hi, This should get you to what your looking for, Go to this web site : http://www.manfrotto.com/Jahia/spareparts/site/manfrotto/cache/offonce
Feb 25, 2009 | Nikon TRIPOD, BOGEN PRO WITH PISTOL GRIP
Manfrotto 322rc2 tripod ball head
here is manfrotto's "How To" site, they have illustrated how to use almost all of their products.
http://www.manfrotto.com/Jahia/site/manfrotto/cache/offonce/pid/2475
hope this helps out. if you have other questions please lemme know
Nov 04, 2008 | Bogen Communication Bogen Manfrotto 322RC2...
322RC2
I just had this same problem and came across your post.  In frustration I held the grip and then let it go very quickly where the grip 'snapped' back.
Now it works.  Go figure.  I will mention a very small piece of plastic fell out of it, but it does not appear to hinder the functionality.
Jul 01, 2008 | Bogen Communication Bogen Manfrotto 322RC2...
Giottos Giotto's MH7001 Pro Ball Head with Built-in MH652 Quick Release Plate, Supports 11 lbs. Tripod Logo
Top Giottos Photography Experts
Steve
Alcolu John
Alcolu John
Tony Parsons
Tony Parsons
Are you a Giottos Photography Expert? Answer questions, earn points and help others
