Question about Toshiba Satellite M45-S331 Notebook
I'm trying to install a wireless adaptor on a computer running windows XP. The netgear softeware wont launch. In the network connections box, it does not show anything wireless. Any suggestions?
  • Toshiba Master
  • 8,404 Answers
Check your device manager. Are all the drivers properly loaded?
Posted on Sep 28, 2009
Netgear WN111v2 Adapter disconnected
Is the Netgear Wi-Fi Management software installed on the computer? If it is, you may have a conflict between Window's built in Wi-Fi Manager and the Netgear Wi-Fi Manager. If it isn't, you may need to install it.
Assuming it isn't, there's links to download the software at the Netgear Global Download Center.
I would default to the most current version, if you're running Windows XP, you may need to install the v2.1, however, I would assume the v3.1 would be backward compatible with XP.
Install the software and follow the prompts that will guide you through the installation/setup.
Now, if the software is already installed, you need to find the program and configure it through that avenue. If that does not fix the issue, you should uninstall the Netgear software, remove the Wi-Fi adapter and reboot the computer. After it completely boots back up, you should either plug in the Wi-Fi adapter, let Windows recognize it and install the drivers, (they should still be in the system even after you uninstalled the software). Once Windows successfully locates and installs the drivers, reboot the computer again, (no need to remove the adapter). Once Windows completely loads again, open Start, Control Panel, and System. On the resulting window, click the hardware tab at the top then click the "Hardware Manager" button in the middle about 1/3 down the window. Click the "+" next to "Network Adapters" and verify that your WN111v2 is indeed installed.
Assuming it is at this point, close out everything but the Control Panel and open "Network Connections". Find the wireless adapter there, (may be listed as "wireless connection2" depending on how many times it's been installed). Right click on the wireless device and select "Show Available Wireless Networks"
I'm also uploading a video showing what needs to be done.
Establishing WiFi Access in WinXP
Jan 27, 2014 | NetGear Computers & Internet
Hi, I have just purchased a new WNA-1100 wireless adapter. I have installed it with no problems, but when it asks me to insert the adaptor and press next, it just keeps saying 'detecting adaptor', for as...
Got this fix off of newegg, and it works for XP
Install the updated software package from Netgear. Go into C:/ Program Files/Netgear/ and copy the Driver folder. Paste to your desktop or wherever.
Uninstall the Netgear software. Plug the wireless adapter back in, let Windows locate, and point it to the XP folder in the drivers folder. You're up and running. ^.^
Oct 23, 2010 | NetGear WNA1100 WirelessN 150 USB Adapter...
Netgear WG111 USB adaptor does not work
-- check the device manager of your computer
-- for win xp - go to right click on my computer - manage - computer management - device manager - on the right hand side that the netgear adapter is listed under network adapters or other devices
-- check the status that its working properly
-- then upgrade the latest drivers ...
-- follow the link ::
http://kb.netgear.com/app/products/model/a_id/2556
and try to connect ..
Mar 26, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
NETGEAR Wireless G USB Adaptor Problems
I contacted Bigpond after my whole internet collapsed due to my amature abilities in fixing the internet. >_<" yet they fixed my internet connection by disconnecting my current (DLINK DIR-300) router from the network. hmmmm... the technician also confirmed that my current broadband modem (2WIRE 2071-A) isnt capable of supplying a shared connection to more than one computer!! she also directed me towards a modem with an inbuilt wifi router that "supposedly" is the best option right now. (2701HGV-W) I'm a bit shaky and the stupid NETGEAR adaptor problem still exists - im willing to buy the new modem if its guaranteed to abolish this problem and give me a better internet wise outlook - please any suggestions will be appreiciated =)
Apr 23, 2009 | NetGear Wireless-G USB Adapter...
NETGEAR WG311v3 Wireless PCI adapter STUCK on scanning.
Hi
What you to do first verify that the device is installed properly for that ---
Go to Device manager-- click on Network adaptors -verify the your wireless adaptor is listed there without any yellow or red mark .If you see a yellow mark then you need to install and reinstall the adaptor
Second , You might see an icon for netgear adpaptor in right lower corner under taskbar and you need to Right Click on it , it will show you several options just look for use window to manage wifi or xp wifi client , like that .. sect that option ..
after that it will display a message wireless network detected , click on the messege , you will see your network . select and connect
Mar 29, 2009 | Computers & Internet
My Netgear Adaptor keeps scanning after is found my wireless netw
on your computer goto start - run - type services.msc and press enter.goto wireless zero configuration and enable it. now goto start - run type msconfig and press enter then goto startup and uncheck your netgear adapter.press apply and OK or close. restart your computer.goto start - control panel - network connection then right click wireless network connection and view available wireless networks.select your network and connect.once it`s connected goto start - run - .cmd - enter..type ipconfig..you`ll get ip address,subnet mask,default gateway.copy it. now right click wireless network connection again and click on properties and double click on internet protocol(TCP/IP).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
this will fix your problem...
Dec 28, 2008 | NetGear : WG111U Double 108 Mbps Wireless...
I cannot connect my netgearWG111T wireless usb adaptor to my router
Wireless Adapter Installation
A. Install the software.
Note: Firewall and anti-spyware need to be disabled. They sometimes treat software installation as a behavior of a spyware and therefore will prevent installation.
Windows XP:
1. Please power on your computer. Allow the operating system to boot up completely and log in as needed.
2. Insert the NETGEAR adapter Resource CD into your CD-ROM drive. The CD main page shown at the right will then load.
3. Click the Install Driver & Utility.
4. Please make sure that you follow the Install Shield Wizard steps. Click Finish when done and turn off your computer.
B. Install the adapter.
Windows XP:
1. Please make sure that you shut down the PC first and then remove the power cord.
2. Please insert the NETGEAR adapter into the available expansion slot.
Note: If you have PCI adapter, connect the antenna to the adapter, making sure the antenna is in the upright position.
3. Reconnect the power cord and reboot the computer.
4. When the Found New Hardware Wizard displays, please click on Next and then follow the prompt. If you are prompted with a Windows XP Logo testing message, just click on Continue Anyway.
5. After the installation completes, click Finish to close the wizard.
Configure the NETGEAR adapter.
1. Please Double click on the NETGEAR icon on the right lower end portion of your computer.
Note: If you do not see the icon, click on Start and go to Programs. Locate the NETGEAR Utility and click on the NETGEAR Smart Configuration Utility.
2. Click on the Networks tab.
3. Click on the Scan button.
4. Select the Network Name or SSID of your wireless network.
5. Click on the Connect button.
6. You will be directed to the Settings tab.
7. Type a name for the Profile.
8. The Network Name (SSID) will be the same with your wireless network.
9. Make sure that the Network Type is set to Access Point (Infrastructure).
10. Select the Security that you are using on your wireless router.
11. Click on Save Profile.
12. Click on the Apply button.
Enabling Wireless Zero Configuration Utility
1. Please click on Start, Run and type in services.msc and click on OK.
2. Scroll down and look for Wireless Zero Configuration. Right click on it and click on Start.
3. Right click on Wireless Zero Configuration again and click on Properties.
4. Under the General tab, set the Start up Type to Automatic and Service Status to Started. Then, click on Apply and OK.
Connecting to the Wireless Network
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
For Windows Vista:
1. Click Start then select Connect To.
2. Connect to a network window will show up.
3. Select your wireless network and click Connect.
4. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
We hope that the above steps provided would help resolve the problem. If the steps above did not work, we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Can your computer go online when it is hardwired to the router?
2. What wireless adapter are you using?
3. What is the operating system of your computer?
Nov 08, 2008 | NetGear WG111T 802.11g/b (E82321) Wireless...
Cannot connect to my laptop with a built in wireless.
Windows XP:
Windows 2000/ME/Win98SE:
Note: Windows 2000 may require you to be logged on with administrator rights.
2. Insert the NETGEAR adapter resource CD into your CD-ROM drive. The setup page will then load.
3. Afterwards, click on the Install Driver & Utility link.
4. Make sure to follow the Install Shield Wizard steps, and click Finish when done to restart your computer.
Windows XP:
2. Insert the NETGEAR adapter into the available expansion slot.
4. On the Found New Hardware Wizard, click on Next, then follow the prompt to proceed.
5. After the installation completes, click Finish to close the wizard. Please make sure that you can see the NETGEAR icon located at the lower right portion of your computer screen.
Note: If Windows displays Digital Signature Not Found warning, click Yes to continue.
C. Configure the NETGEAR adapter.
Jul 13, 2008 | NetGear WG111T 108 Mbps 802.11g Wireless...
Netgear wireless connection
Check the wireless IP address on the XP computer. try to ping default gateway and see whether its giving succesfull reply, after that do ping yahoo.com and check successfull pinging. if it pings successfully the yahoo website , then you should go online.
Oct 24, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Toshiba Satellite M45-S331 Notebook Logo
56 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
