Question about Lexmark X5470 All-In-One InkJet Printer
Just installed 2 ink cartridges shows error1203
Just installed 2 new ink cartridges shows error1203
My printer will not accept the ink cartridges I have bought because they are not from lexmark it is showing error1203 how do I get around this?
Possible that the ink cartridges are not meshing along with the contacts. Hence the original is important to get the ink cartridges to contact.
Remove and set back the cartridges, if possible remove the printer and reinstall after removing the driver software. If this wont work the original cartridge must be sourced.
Dec 08, 2010 | Lexmark X5470 All-In-One InkJet Printer
My Brother MFC-685CW Printer Wireless doesn't recognise a new colour cartridge despite having cleaned the printer head. It also is not recognised by the PC despite reloading it. Help!! Troubleshooter...
If the message "NO CARTRIDGE" remains on the LCD after you have installed the ink cartridge(s), it is possible another ink cartridge is empty and needs to be replaced or one or more of the cartridges are not installed properly. Complete the following steps:
  1. Unplug the machine from the AC power outlet, wait approximately 10 seconds and then plug it back in.
    1a. If the display continues to show NO CARTRIDGE, verify the cartridges are installed properly by uninstalling and reinstalling all four ink cartridges. Follow Steps 2a through 2f.
    1b. If "INK EMPTY XXXXX" (Xs = color, i.e. INK EMPTY CYAN) is displayed on the LCD, the specified ink cartridge is empty and needs to be replaced. Follow Steps 2a through 2f.
  2. To resolve an INK EMPTY message or to confirm the ink cartridges are installed properly, complete the following steps:
    2a. Open the ink cartridge cover. Pull the lock release lever(s) down and take out the ink cartridge(s). While you have the ink cartridge(s) out of the machine, verify the cartridge(s) are genuine Brother supplies with the Brother logo embossed into the side of cartridge.
    2b. Reinstall the ink cartridge(s). Lift and push the lock release lever(s) until it clicks into place and close the ink cartridge cover.
    2c. The LCD may then display:
    Did you change xxxxxx? Yes No.
    for the color(s) that was replaced. If this message appears, BE SURE to follow the instructions on the LCD to correctly select Yes or No. Select Yes if you installed a new cartridge(s) to automatically reset the ink dot counter for that color. Select No if you did not install a NEW ink cartridge(s).
    2d. After all the correct selections are made, the machine will then enter a cleaning cycle.
    2e.If the display again shows INK EMPTY XXXX, go back to Step 2 and follow the instructions to install a NEW ink cartridge.
    2f.If the machine did not enter a cleaning cycle and the display continues to show NO CARTRIDGE after reinstalling new genuine Brother ink cartridges, your machine may require service.
If your computer is not recognizing the printer you should uninstall and reload the drivers. You might consider downloading a new driver for your operating system from this site:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_list.html?reg=us&c=us&lang=en&prod=mfc685cw_us_as&Cat=112
I recommend bookmarking thihs site for future reference.
I hope this is helpful. :)
Dec 08, 2010 | Brother Office Equipment & Supplies
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
I have a Brother MFC5460CN...I can't find the owners manual and I can't figure out where the ink cartridges are? I need to replace them
I found this on the Web site. You can download the manual for yourself. Just click on the link below. If you find this information helpful, pls rate me.
http://www.retrevo.com/d/ds/progress?doc=9adbcf37695f2981dab6cde6d0fdb2d1
Replacing the ink cartridges B
Your machine is equipped with an ink dot counter. The ink dot counter automatically
monitors the level of ink in each of the 4 cartridges. When the machine detects an ink cartridge is running out of ink, the machine will tell you with a message on the LCD. The LCD will tell you which ink cartridge is low or needs replacing. Be sure to follow the LCD prompts to replace the ink cartridges in the correct order.
Even though the machine tells you that an ink cartridge is empty, there will be a small amount of ink left in the ink cartridge. It is necessary to keep some ink in the ink cartridge to prevent air from drying out and damaging the print head assembly.
a Open the ink cartridge cover. If one or more ink cartridges are empty,
for example Black, the LCD shows Ink Empty Black and Replace Ink.
b Pull the lock release lever down and take out the ink cartridge for the color
shown on the LCD.
C Open the new ink cartridge bag for the color shown on the LCD, and then take
out the ink cartridge.
d Remove the protective yellow cap (1). Each color has its own correct position.
Insert the ink cartridge in the direction of the arrow on the label.
f Lift each lock release lever and push it until it clicks, and then close the ink
cartridge cover.
G If you replaced an ink cartridge, the LCD
may ask you to verify that it was a brand
new one. (For example, Did You Change Blck?) For each
new cartridge you installed, press 1 (Yes) to automatically reset the ink dot
counter for that color. If the ink cartridge you installed is not a brand new one, be
sure to press 2 (No). If you wait until the LCD shows
Note
If the LCD shows No Cartridge after
you install the ink cartridges, check that
the ink cartridges are installed properly.
Pls rate met. Thanks and Good Luck.....
Feb 05, 2010 | Brother MFC-5460CN InkJet Printer
Installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Jan 20, 2010 | HP PSC 1315 All-In-One InkJet Printer
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
My printer says install magenta what does that mean
It means for you to install the magenta ink. Magenta is a color. You have 4 colors. Yellow, magenta, cyan, black
Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
I don't know how to change the ink bought this printer from a guy at work no manual
Lift the scanner cover from the right-hand side of the MFC until
it locks securely into the open position.
If one or more ink cartridges are empty, for example Black, the
LCD shows Ink Empty Black and Cover is Open.
Pull the ink cartridge hook toward you and remove the ink
cartridge for the color shown on the LCD.
and then take out the ink cartridge.
Remove the cartridge covers.
Each color has its own correct position. Keep the ink cartridge
in an upright position when you insert it into slot. Press down on
the ink cartridge until the hook snaps over it.
Lift the scanner cover to release the lock. Gently push the
scanner cover support down and close the scanner cover.
If you replaced an ink cartridge while Near Empty was
displayed on the LCD, the LCD may ask you to verify that it was
a brand new one. Example: Did You Change Blck? 1.Yes
2.No. For each new cartridge you installed, press 1 on the dial
pad to automatically reset the ink dot counter for that color. If the
ink cartridge you installed is not a brand new one, please be
sure to select 2.
If you wait until Ink Empty message is displayed on the LCD,
the MFC will automatically reset the ink dot counter.
If the Install message is on the display after you have
installed ink cartridges, check that the ink cartridges are
installed properly.
Hope that helps you!
Aug 12, 2009 | Brother MFC 420CN All-In-One InkJet...
Print cartridges
  1. When one or more ink cartridges are empty, for example, Black, the LCD shows “Ink Empty Black” and “Open Cover.” Close the printer’s document support and the document tray.
  2. Lift the top cover to the open position until it locks securely into place.
  3. Pull the ink cartridge hook toward the front of the printer and remove the color ink cartridge displayed on the LCD. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  4. Open the new ink cartridge bag for the color shown on the LCD and remove the new ink cartridge. The cartridge cover may come off when you open the bag. This is not uncommon and will not damage the cartridge.
  5. Each color has its own correct position that is clearly labeled and color coded inside the printer. Keep the ink cartridge in an upright position when you insert it into slot. It will only fit in the correct direction. Press down on the ink cartridge until the hook snaps over it.
  6. If you replaced an ink cartridge while “Near Empty” was displayed on the LCD, the LCD may ask you to verify that the replacement cartridge was brand new one. Example: “Did You Change Black? 1.Yes 2.No.” For each new cartridge you installed, press 1 on the dial pad to automatically reset the ink dot counter for that color. If the ink cartridge you installed is not a brand-new one, select 2.
Sep 16, 2008 | Brother MFC-5840CN All-In-One InkJet...
Unable to reset printer after installing new ink cartridges
I want to known you have replaced the cartridges or refill the cartridges.
Feb 23, 2008 | Office Equipment & Supplies
Lexmark X5470 All-In-One InkJet Printer Logo
47 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
