Question about U-Line 2175BEVS-01 Uline Beverage Center Left Hinge - Black Interior - Stainless Steel
I am getting a flashing message E5 where the temp is normally displayed on my U-Line Beverage Center. I could not find info in the manual on this code?
  • 286 Answers
E5 means that the unit is 10 degrees warmer than the set point for more than 12 hours. You may need service to help you find out if its a sealed system or maybe a thermistor in the wrong location
Posted on Oct 08, 2009
I have a 2007 Eddie Bauer Explorer how do I fix the message center that keep flashing circle slowly then it flashes calibrate complete.
Do you have base instrument cluster) or high series instrument cluster) ?
Symptom Chart Condition Possible Sources Action
  • The message center is not operating correctly (base instrument cluster)
  • Instrument cluster
  • OBSERVE the operation of the message center when pressing the TRIP/SELECT button. Does the message center display change when the TRIP/SELECT button is pressed?
    • If the message center display changes, the system is operating normally at this time.
    • If the message center display does not change, INSTALL a new instrument cluster. REFER to Section 413-01 . TEST the system for normal operation.
  • The message center is not operating correctly (high series instrument cluster)
  • Message center switch
  • Go To Pinpoint Test A .
Jan 24, 2015 | 2007 Ford Explorer Eddie Bauer
My U-Line beverage cooler is indicating an E5 error code and the unit will not get cold. What is this telling me?
I am not familiar with this unit but in guessing but I would not assume the thermistor is bad, actually if as you say the compressor is running that is all the thermistor can do. My first guess is the condenser needs cleaning, that is the area where it gets warm. If that is clean then the possibility of a refrigerant leak is there. If not that then the compressor most likely has a bad valve in it. I would suggest contacting a refrigeration tech after everything has been cleaned and it still does not cool.
Dec 19, 2014 | ULINE U-Line 1175BEVS-00 1000 Series 24"...
Avanti outdoor beverage cooler (new), should temperature lights go off? How do I know what the temp is, if the lights go off? It appears to go off for no reason. Owners manual mentions door gasket?? I
The temp lights might indicates the actual temp settings havent reach the programmed settings. If its on and off coz it try to recover the temp lose after it drop below prog. Temp. Monitor it first if its cooling must be normal only.
Sep 21, 2014 | Avanti Orc2519ss Steel Outdoor Beverage...
E5 message on my Singer Brilliance sewing machine. What does it mean and how do I fix it? There is nothing in the manual to help.
If you are winding the bobbin in the middle of sewing process, it is normal to get a notification (E5) that bobbin winder should be returned to the left position before continuing to embroider.
Mar 21, 2014 | Sewing Machines
Maytag neptune error message e5
This normally indicates that the thermistor is bad. Try measuring it to prove it is OK. It should be 10K Ohms at room temperature (20C / 68F).
If necessary, replace it then clear the error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Sep 06, 2012 | Maytag MDE9700AYW Neptune 174 Electric...
I purchased a 52 bottle kitchen aid wine cooler. No matter where I set the thermostat, it is always 45 degrees and readouts are sideways "T's" instead of numbers.
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download. arrow_results_summary.gif Get Adobe Acrobat Reader Click Here=> KUWA244PBS Parts List
and here=> KUWA244PBS User and Care Guide
If you should need the service manual you will need to cant me here=> HERE Reason is Whirlpool does not allow me to publish the SM here.
The beverage center and wine cellars have a temperature display for each zone. 12 volts
AC is supplied to the display board from a transformer in the unit compartment. The displays are only temperature displays and have nothing to do with any cooling function. A thermistor is used to sense temperature for each zone. The thermistor for the bottom zone is located inside the lower portion of the separator. The thermistor for the top zone on the wine cellar, (mid zone on beverage
center), is located in the upper portion of the separator. The thermistor for the beverage center upper zone is located on the inside of the 2-piece evaporator cover. It is on the right-hand side.
The mid temperature for the bottom zones on either unit are 60? Fahrenheit plus or minus 5 degrees. The mid temperature for the mid zone on the beverage center and the top zone
on the wine cellar is 45? Fahrenheit plus or minus 5 degrees. The mid temperature for the
top zone on the beverage center is 38? Fahrenheit plus or minus 5 degrees. I think at tis time you should check each section with a pocket size digital thermometer to cofirm tha the mechanical thermostat is within calibration. Click Here=> 4344690 Temperature Control
Click here for a=> KUWA244PBS Beverage Center Wiring Diagram
I believe the problem may be in the PCB transformer shown at the bottom right corner of the wiring diagram. It is possible o change the transformer but I have not been able to find the board that powers the LED temperature readouts. If needed let me know and I will call Whirlpool mfor you, Thanks, Sea Breeze
Oct 09, 2011 | KitchenAid KUWA244PBS Wine Cooler
Frigidaire ffbc46fsls beverage center refrigerator does not resume "on" condition after power glitch. If the unit is unplugged while running, then plugged back in, it resumes normal function,...
Wow if you have lost that much because the memory dumps during a power failure then we are going to need do something serious about that! May take me a while to come up with a solution but being the case I think you have a serious point to make. Acording to The
Frigidaire FFBC46F5LS Beverage Center User Manual
and on page 7 of the PDF
The default temperature for the beverage cooler is 41°F (5°C). The temperature after power failure will be the temperature set before the power failure. So something is wrong with the control board part=> Pc board,input ,display I believe I would call USA 1-800-944-9044 and ask why that may be happening. Below is a parts list.
Frigidaire FFBC46F5LS Beverage Center Parts
Hope this helps, Thanks, Sea Breeze
Sep 03, 2011 | Frigidaire FFBC46F5LS
Hi, I bouught a new Nokia E5. When i receive messages, there is no display of name. Only the number is shown. What needs to be done fo rthe Name to be displayed?
Manual E5
Try browsing this manual of E5 cellphone to be familiar with your phone. Most probably, the number of your friend was not saved to either your phone or into your sim. Or, it was saved twice in the same memory (phone or sim) that's why the phone cannot recognize the number.
Thanks,
Jan 13, 2011 | Nokia E5 Cell Phone
Carrier Programmable Thermostat - E5 Code
Ok what you need to do is call your local service company and have a technician come out and check your Thermostat, its currently not able to read humidity probably due to a power surge
Apr 28, 2009 | Carrier Heating & Cooling
E5 flashing error code
I have the same error on my U-Line beverage refrigerator. U-Line said the error indicates the thermostat was out of range for over 12 hours (perhaps due to a recent power outage). My fridge seems to be working just fine so I am not planning on calling a technician until something more serious breaks down.
Apr 25, 2009 | Refrigerators
U-Line 2175BEVS-01 Uline Beverage Center Left Hinge - Black Interior - Stainless Steel Logo
1,006 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
