Question about Epson Aculaser C1100 Printer
Epson c1100 print problem
We have a black line running length of page about 2 inches from edge of paper
  • Epson Master
  • 1,879 Answers
You can try this:
remove the toner and photoconductor then tip it GENTLY from side-to-side
reseat them and print
Posted on Jan 04, 2008
When printing invoices, the first page skips one line, the second page 3 lines and so on throwing all of the invoices off. Any ideas on how to fix this?
Set the page length at the printer's settings according to the real page length. If your paper is punched on it's sides, you can compute the real length knowing that the punches are 1/2 inch each other (or you can simply measure it). For more details, please specify the type of software you are using (ms-dos, windows, etc).
Mar 08, 2011 | Epson LQ-590 Matrix Printer
Printing thin black lines the length of my color pages, HP laserjet 3800
one question......
do the lines go off the edge of the paper?
if so either the black drum unit or the belt has gone bad.
if the lines stop before the edge of the paper it could be on the print job itself.
go through the menu and look for demo pages or the configuration pages to print and examine them.
Jan 11, 2011 | HP LaserJet 3800 Printer
My Ricoh Aficio CL2000N is printing several faint lines
Couple possibilities:
Fuser hot belt has wear lines transfering to the page
Black pcu needs to be replaced
Transfer unit is not being cleaned properly and needs to be replaced.
Remove each of these assy and inspect them for wear or lines that corespond to the lines on your prints.
Mar 25, 2010 | Ricoh Aficio CL2000N Laser Printer
White vertical line in image printing
how can we take all fax sent and received print from hp 3050 printer.
Apr 01, 2009 | Epson Aculaser C1100 Printer
Black lines across my printer paper
potential driver error; reload driver. Once reloaded, go through all setup procedures [alignment of print head, etc]. Do not skip steps. The printer utilizes the setup features [user interface] as a calibration which is fundamental to its performance.
Oct 15, 2008 | Epson Aculaser C1100 Printer
2 Missing ink black streaks
Check the dev unit for missing lines. Also clean the laser glass with the supplied cleaner pad - though if the problem were caused by toner on the lens, there would be gaps in ALL colours.
Check the dev units first. You can also do a stop test whilst a full colour test image is half way through printing and see if the lines are missing off the image on the PCU as well.
May 20, 2008 | Epson Aculaser C1100 Printer
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
Epson Aculaser C1100 - misaligned printing
Your application will actually override the settings of the printer, what i can suggest is for you to check if you are using the correct page length and margin setting in your software program.
Try using Laserjet 3 emulation driver as well
Feb 08, 2008 | Epson Aculaser C1100 Printer
Print quality Epson C1100
It sounds as though a cartridge is faulty. To determine which one, the easiest way is to run a page of text/block of colour through in yellow then cyan then magenta. which ever page comes out with the streaks on it will tell you which cartyridge to ditch and replace. Hope this helps Cops Pete@wedotoners.com
Oct 10, 2007 | Epson Aculaser C1100 Printer
Colour lines across the page
Hey Paul, Can you post a scan of the printed paper? It may help diagnose your problem. The most common cause of lines accross the page is either the PhotoConductor Unit or the 2ND BTR Assy.
Nov 30, 2006 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
822 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
