Question about Sony Cyber-shot DSC-W200 Digital Camera
I can't get the flash to come back on the camera on any setting?? Any help would be great. Thanks, Nez
Hi, my problem is the flash does not flash. The HS10 is a great camera, which I highly recommend and it does everything and more that I was hoping it would do. The flash worked great and then one day no...
As I have suggested many times, try resetting all adjustments in the menus to factory specs., or what may also be called default settings, or something like that.
Then test the camera again, making sure that the flash settings are set to be used as you need them or the way you like.
Oct 30, 2010 | FUJIFILM FinePix HS10 / HS11 Digital...
Hi, the flash setting on my Vivitar Vivicam 8025 camera won't stay on what I select. It always goes back to "no flash" when I set it to have flash or no red eye flash. Please help! Thanks!
Remove the battery AND the memory card.
Then reinsert both starting with the memory card FIRST.
Doing this, the camera will keep its settings while you take pictures but will revert back to its default settings as soon as the camera is turned off, or if you going into playback mode, etc.
This is a little frustrating for us but since the camera is for our 7 year old, she's not really concerned much. Hopr that helps you!
Dec 13, 2009 | Vivitar ViviCam 8025 Digital Camera
Can't change flash settings to Sony Cybershot DSC-H10 camera
Glad ur problem solved !
kindly rate my response WELL in system
Regards
Zohail
May 28, 2009 | Sony Cybershot DSC-H3 Digital Camera
Set camera on AUTO (green mark) on dial jog, now you can set flash on desired option.
Feb 07, 2009 | Sony Cybershot DSC-H3 Digital Camera
Canon PowerShot A410 Flash Question
hi there
when in camera mode do the following
look at the multi function dial
at the 3 o'clock position you will see a lightning bolt
press it and select the bolt with a line through it
press the func set button and its off.
do the reverse to turn it on.
hope this helps
beergut707
Oct 25, 2008 | Canon PowerShot A410 Digital Camera
Problems taking photos at night.
Did you use flash? Did you use tripod? Generally speaking night photos with non-DSLR digital camera, W55 is non-DSLR, will be blurry unless either flash is used or a tripod is used. The issue is the camera shutter is set for a long exposure in order to get enough light that it is impossible to hold the camera steady. The color problem you mentioned is most likely your white balance. Normal white balance is sunlight at night you white balance should be Auto, Incandescent or Neon
Jul 23, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Blury and flash problems
Hello Chad,
As you told the condition of the are blurry,This problem is not related to the setting or master reset.This cause is due to malfunctioning of zoom optical motor and sensor who focus the object.Therefore, the solution of it is, You have to change its optical lens assembly.
I often deal these sort of cases in routine in said Model Although it's a very fine camera but dusty and moisturized conditions cause this problem.
Thanks & don't forget to rate.
Apr 12, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
Master reset for sony cybershot
my camera won't load pic. up to my computer when I plug it up now can I reset it? It use to work but I don't know what happen.
Mar 13, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Samsung A402 flash problems ¬¬
I do not have a solution but my camera has the exact same problem! Supposedly Samsung will charge a $55.00 fee to fix the flash, but several people seem to be having the exact same problem with their flash just not working, there should be something we can do about it.
Dec 31, 2007 | Samsung Digimax A402 Digital Camera
Sony Cyber-shot  DSC-W200 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
