Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have an old powerlift opener. had been working great. died suddenly i hear the click from the remote and 2 manual switches. i have 120v going into a set of pins. then the 2 row of pins above the feed have 60 volts. any sugggestions .
    President:
  • 3,197 Answers
It sounds like your logic board has bit the dust. Due to the age of that opener I would suggest a new up to date model.
Posted on Sep 28, 2009
I have an old powerlift wr827 garage door opener, but have lost the remote. Is there a universal opener with a 10-pin setting that I can purchase that will work with this?
This is an old opener, completely obsolete, but you could try buying a clicker universal remote at home depot, lowes, etc. follow the programing instructions for all of the 10 pin settings. sometimes different models will cross over. If it doesn't work which is likely you can always return it.
Oct 30, 2016 | Building Materials
Have Just Purchased a D.I.Y.Chamberlain PowerLift Plus ,Can i Connect old Hard wire Operating Switch to this unit
The old eye beams and controller may or may not work. The remotes definitely will not. If they do, they will probably cause problems over the long run. Best thing to do is to go ahead and replace them. But if you like the old button, give it a try. Some more basic older ones will work, you just may lose some of the features like door lock or light control.
Feb 18, 2015 | Building Materials
Genie 900 door operator
hello,there is an adjuster on the side of the motor,also check that the micro switch[if fitted on your particular type} is 'clicking' and actually in contact with the arm as it revolves closed. hope that helps, cheers
Jun 02, 2014 | Genie PowerLift 900 1/2 HP Screw Drive...
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
Abt trapdoor doesn't go up
Hello
I've only the user manual for your ABT Trapdoor Electriscreen projectior by Stewart. No other service details can be available now by NET search. There is one indication given in the user manual about the malfunction of the screeni I'll copy it here to you.
SCREEN WON'T OPERATE => NO 120V POWER AVAILABE OR OUTBARD SWITCHING PROBLEM => [1] CHECK TO SEE WHETHER THE CIRCUIT BREAKER IS SWITCHED OFF. RESET IF NEEDED.[2] CHECK OUTBOARD SWITCHING APPARATUS. [3] CHECK VOLTAGE AVAILABILITY; CONTACT AN ELECTRICIAN. [4] CHECK THAT TOGGLE SWITCHES ARE IN THE CORRECT POSITION. SEE FIG 2, P.5
That is all. OK.
Oct 28, 2011 | Stewart Filmscreens ABT TRAPDOOR...
I have a Merlin Powerlift model 430R roller door. The battery went flat in the remote and I replaced it. Now the door will not work via the remote.Works ok from red button on unit. I have tried to reset...
If the LED is flashing rapidly when the button on the remote is not pressed you have interference from something. Check for old remotes stored in a drawer somewhere or some new electric item nearby. Start unplugging things until that rapid flashing stops.
Apr 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
I bought a chamberlain clicker and want to program it for use with a POWERLIFT garage door
This remote is compatible with your power lift. It should of come with a manual on how to program it as well. Each opener has a different sequence to program it so I can't just give a general answer. On a chamberlain powerlift look for the color of the button while programming it. If you need a copy of this manual you can get one at chamberlain.com. Thanks BB
Aug 29, 2010 | Chamberlain Clicker Universal Remote...
I have an older Craftsman GDO setup. 2-3 button remotes,a manual hardwired push button operator and my wifes' car has been successfully liked to operate the opener as well. Up untill just a couple of days...
I suggest you look for a Chamberlain dealer in the yellow pages and explain what you have. You are looking for a 'universal receiver' that will work with what you have.
Mar 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Power supply of tv
if voltage drops means there is a short circuit in your tv. 1 disconnecting 120v line if supply becomes ok then there is short ckt in horz.section &if it does not gives 120 volts then there is problem in power supply. please check as per instruction &let me know. good luck.
Sep 19, 2007 | Proscan PS36500 36" TV
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
401 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
