Question about Electronics - Others
WIRING DIAGRAM FOR MARINE GUEST BATTERY SWITCH FOR TWO DEEP CYCLE BATTERIES . 12 VOLT SYSTEM TO SWITCH TO SECOND BATTERY WHEN THE FIRST BATTERY RUNS LOW
  • 53 Answers
SOURCE: wiring diagram for 12/24 volt system
here is a wire diagram. follow the pictures. you can do fuses but i like inline breakers. you can get them at your local outboard dealer.e9e9f8a.jpg
Posted on Nov 05, 2009
pctech1
  • 1940 Answers
SOURCE: wiring diagram for 69 volt
Here are the wiring diagrams for 5 12-Volt Batteries wired in Parallel and in Series:
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Apr 03, 2011
caroldon
  • 17130 Answers
SOURCE: cyberpower 1000 watt 12 volt
When the wattage of an invertor is specified it is meant for the power load but with a gradual CURRENT drain. If you load with modest loads of lighting , fan or other low wattage device it will work without tripping off. In this case your microwave when loaded will initially start up with a large surge current requirement thereby shutting off the invertor as it detects overload. So the safe limit to operate a microwave is to have an invertor above 2000 watts . If the input supply is 24 volts , then it will be more powerful.
Also try with a low wattage/heating setting on the microwave, tighten the battery terminals of the battery . Sometimes it might start but can also damage the invertor. failure of the driver MOSFETS.
Posted on Jul 12, 2011
pcdj64
  • 1150 Answers
SOURCE: I want to change my rv wiring from 2 12 volt
to increase amps your best bet is to get two deep cycle marine batteries with high cranking amps
Posted on Sep 18, 2011
  • 5631 Answers
SOURCE: Can I charge a low 12 volt battery and a new 12 volt battery in a 24 volt system?
You can try but I guess your device won't work so you'll have to buy another new 12 V battery
Posted on May 13, 2015
12 24 SYSTEM 2 BATTERYS BOTH WIRED SEPARATE GOING TO THE BOW OF BOAT 4 HOLE PLUG 3 WIRES GOING TO TROLLING MOTOR 12 24 SWITCH 12 OFF 24 ONLY RUNS ON 12 AND STOPS ON OFF BUT NOTHING ON 24
It is likely to be a function of the switch to place both batteries in parallel in the 12 volt position and in series in the 24 volt position - this is likely to make the switch and the wiring fairly complicated as the motor could be wired internally in a variety of ways and the switch will also need to send the right voltage down the right wires.
I suggest you first ensure both batteries are fully charged and in good order. Once you are certain of that it is time to inspect the switch and wiring and test the voltages. A wiring diagram would make the task much easier.
Mar 14, 2018 | Boating
Is there a kit or process that would to jump start a Boat that uses two 12 volt deep cycle Marine Batteries?
Sort of depends on how your two batteries are connected. If your boat is a 12 volt system, then any car type booster will do the trick, or you could simply add a 3rd battery with a switch. When you stop for a day's fishing, turn the 3rd battery off. Turn it back on for a quick "jump-start" and leave it on for the trip back to dock to keep it charged.
Jun 08, 2015 | Boating
I have a dual marine battery charger on my boat that is wired thru a 1-2 or both switch both batteries are 12 v batteries and i was wanting to know if i could add another two 12v batteries to the sy
It sounds to me like you have an Ad-A-Battery system or something similar. Your dual battery charger has two sets of output leads. Those leads should be connected DIRECTLY as one set of leads to battery #1 and one set of leads to battery #2. Your 1-2-both switch should be OFF when you are charging. You will, I suspect, be supplying current to your motor and other boat circuits by having the switch on and running your charger through that switch. Adding two more batteries could be accomplished by buying a four battery charger (four sets of output leads) or buying a second dual battery charger. When you only want one AC plug-in you connect both charger AC inputs to a small junction box that is fed current by the AC plug-in. That will be nice and simple and safe. Of course, you need to check wire size to make sure you have proper size for the length of your wire runs.
Mar 10, 2013 | Marinco Guest 2620 Waterproof Charger
Bought a minn kota 765mxt at a yard sale and need to know is it 12 volt or more
36 lbs is 12 volt any deep cycle battery will work
Feb 03, 2013 | Boating
I have a 1000 Watt Inverter, along with a regular car battery when the electricity goes out; Question: Can I use the 1000 Watt inverter and connect a 100 amp, deep cycle battery? I use regular house...
Yes, just be sure connections are heavy enough wire, and obviously the inverter uses 12 vdc input. Hook jumper wires positive to positive, negative to negative, on all 12 volt batteries. Deep cycle batteries will work better than car batteries. Just remember, when re-charging them, that they last longer when charged slowly, so don't use a high amp setting on charger and to monitor them closely, and do it in a well ventilated area, away from any ignition sources.
Apr 14, 2010 | Schumacher 1000 Watt Inverter with 2 GA....
Wiring diagram for 12/24 volt system
Nov 05, 2009 | Boating
What size batteries needed for minn kota 24 volt 74lb thrust
I use Red Hot Mama batteries. These have held up for longer than any other brands that I have used. These are deep cycle marine wet ones.
Nov 12, 2008 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Wiring diagram
dave, the link below contains electric golf carts wiring diagram, one here is almost the same with your 08 Precedent like the one below.
good luck
Wiring diagram
Jul 24, 2008 | Car Audio & Video
Electronics - Others Logo
1,790 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
