Question about Sanyo Cell Phones
How do I get the phone numbers off a SPC-5600?
  • Sanyo Master
  • 8,404 Answers
I dont understand your question as stated.
Do you want to delete numbers on your list of contacts?
Generally, open your contact list and look for a menu item (maybe a soft key) look for edit or erase or delete.
Posted on Sep 28, 2009
Unlock code
The phone can be programmed over the air with one step. First, call *228. Once that finishes, call any number and the programming will be complete. The programming menu is accessed from the home screen by quickly pressing "menu", 0, 73887*. At this point, the phone prompts for the Security Code, which is usually 000000 on Verizon, Alltel, and Amp'd, and 236197 on Bell. However, it's possible that this number could be any number at all. Once in the programming menu, the user can manually activate the phone, configure web browser sessions, GPS, Get It Now, and Test Mode. The security code is not the same thing as the SPC (Subsidy Provider Code). Of the carriers that support the e815, only Canadian carrier Bell Mobility uses a subsidy lock code. Verizon, Alltel, and Amp'd do not use SPCs. The SPC is needed to access any of the services located in the aforementioned Programming Menu. There is no default SPC: it varies from phone to phone. The SPC for a Bell Mobility e815 is located in seem 0055, Rec = 1, Bytes = e. The SPC code is usually a 6 digit decimal based number. If this does not work contact your service provider, as they may have to change the simms or unlock it. Good Luck
Jun 12, 2007 | Motorola Mobility E815
I need a reset code for phone screen locked
There's no hard reset on this phone. Here's what you want to do. If your phone is currently locked on your home screen pres 111111(do not press unlock because it'll only give your 4 spaces, just do it until you see the 1's appear). You should see Options or Service appear,if Options, select options then service, if service select service. You should see reset lock, select it then click yes. It'll ask you for a 6-digit code. This is called the 6-digit service programming code or SPC, just call MetroPCS' customer support and have them give you the SPC, once you've entered it, your phone's lock code will reset to 0000 or the last four digits of your phone number. If it'snot locked it'll be easier for you to enter 111111 on the home screen. Follow the same procedure.
Aug 28, 2013 | Kyocera wild card Cellular Phone
HOW TO OPENLINE HITACHI CDMA W42H???
All type of phones (old modeles):
NAM programming: 47*869#08#9
Test mode: *759#813580 or 5809540*45680
exit test mode - 02
A-Key: menu + 0, code 25##
Samsung A500
1. Enter ## and the 6 digit OTKSL
2. SERVICE MENU will appear and 1.Basic will be highlighted
3. Press OK
4. Device will display NAM CDMA/ Phone Number
5. Enter 10 digit MIN
6. Press OK (3 times)
7. Display will return to Service Menu. Press END.
8. Programming is complete
Samsung N240 and N400
1. Enter ## and type in the 6 digit OTKSL
2. The display will show SVC MENU and 1. Phone Number
3. Press OK
4. Enter the 10 digit MIN and press OK
5. The display will show NAM with Home SID on the second line (Note: SID is no longer used)
6. Press OK
7. The display will return to the SVC MENU
8. Press END to complete the programming
Samsung Uproar
1. Press MENU key
2. Enter 9 2 0
3. Enter the OTKSL
4. At SVC Menu screen press OK
5. Enter MIN and press OK 4 times
6. Enter SID (4654) and press OK
7. Press END key
Samsung N300
1. Press ## followed by the OTKSL
2. SVC menu will be displayed
3. Press 1 for Phone #
5. MIN that was entered will be displayed press OK
6. SVC Menu will display press 3 for NAM
7. Enter the 4 digit Home SID press OK
8. Press END and handset will power cycle
Samsung i300
1. Tap on the Phone Icon with stylus
2. Press #907*9#0 ENTER LOCK should appear on screen
3. ENTER OTKSL
4. SVC MENU will appear press 1
5. Enter 10 digit MIN and then press SAVE
6. Press SAVE again
7. Press 3 and then press SAVE 6 times
8. Enter the HOME SID and press SAVE once
9. Press END key twice
Samsung A400 and A460
1. Enter ## and OTKSL
2. Press 1 for Basic at MENU (1 of Phone # when using the MSL)
3. Enter 10 digit MIN and press OK
4. At 1.Basic Menu press the END key
5. Handset will power cycle
Samsung 3500 8500 6100 N200
1. Press MENU
2. Press 6 0 (3500) 8 2 0 (8500/6100/N200)
3. Enter OTKSL
4. Press 1 at SVC MENU Screen
6. Press OK 4 times
7. Enter SID (4654) and press OK
8. Press END key
9. Programming is complete
Qualcomm:
QCP-800 programming: menu + 3 + 0.
SPC: "000000" or may be other SPC typed by user.
QCP-820/1920/2035: type "111111" and press Jog Dial.
Choose "Programming" and enter SPC: "000000" or may be other SPC typed by user.
QCP 1960 and 2760
1. Press softkey under the work MENU
2. Press 8 0
3. Enter the OTKSL
4. Press softkey for OK
5. Enter MIN and press softkey for OK
6. No SID is require for this handset
7. Press softkey for EXIT
LG:
LGC-300 programming: menu + 9 and enter SPC: "000000" or may be other SPC typed by user
A-Key: press STO for some time while you can see special code enter zone. Type 2539** and enter A-key
LGC-330W programming: menu + 4 + 0 and enter SPC: "000000" or may be other SPC typed by user.
A-Key: type 2539** and enter A-key
LGC-800W /500 programming: menu + 0 and enter SPC: "000000" or may be other SPC typed by user.
LGC-510 programming: menu + 3 + 0 and enter SPC: "000000" or may be other SPC typed by user.
LG1010 LG4NE1 TP2200 TP2100 Touchpoint SB/DB TP 1100 TP5200
1. Press ##
2. Enter the OTKSL
3. Scroll to SAVE and press OK
4. Scroll to MIN and press OK
5. Enter 10 digit MIN scroll to SAVE and press OK
6. Scroll to SID and press OK (Skip on 4NE1 go to RESET PHONE and press OK to complete)
7. Enter SID (4654) and scroll to SAVE and press OK
LG5350
1. Enter ## and enter the OTKSL and press the left soft key under the word clear.gif
Mar 01, 2012 | Cell Phones
Where do I find the operating manual for a LG 5600 phone?
I am sending you the link to the lg website for their mobile handsets as well as an owners manual for a 5600. I could only find a 5600 for Verizon Wireless' version of the 5600 so I hope that this information helps some.
Here is the web link:
http://www.lg.com/us/mobile-phones/mobile-support/mobile-lg-mobile-phone-support.jsp?displayModelCode=VX5600&carrierCd=verizon
  • OWNER MANUAL English
  • Jan 21, 2011 | Lands Phones
    I need a spc code For a Motorola moto w755
    Your carrier has the SPC code or another way of master reset for you. Just remember to have your EIN # serial # and all the info behind the battery of your phonr for the tech dept.
    May 27, 2009 | Motorola Mobility MOTO W755 Cellular Phone
    Verizon prepaid blitz spc code not all zero's what is it?
    Try the last four digits of the phone number to the phone.
    Mar 19, 2009 | UTStarcom Blitz Cell Phone
    HELP PLEASE
    if you know thw spc/msl you can use ##3282#, ##33284#, and sometimes ##775# and ##786# works for manual programming.
    Sep 26, 2007 | Sanyo SCP-3100 Cellular Phone
    Cell Phones Logo
    Top Sanyo Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Jeffrey Thomas
    Jeffrey Thomas
    Level 1 Expert
    Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
