Question about Admiral Refrigerators
Admiral refrigerator model HMG211640 does not cool - freezer is working - temperture control knobs are broken
  • 19 Answers
SOURCE: my freezers works but my refrigerator
make sure all your fans are turning. maybe try to remove the knobs and see if you can turn them without the knobs, possibly they could be stripped.
Posted on Apr 22, 2009
TheMobilian
  • 8220 Answers
SOURCE: GE Model gss25jfmdww. No matter what I set the
If the ice box is working but not cooling right I would find the thermisters and check them, and replace them. This manual shows where they are.
Bonus Info: Your ice box uses artificial intel to determine proper operation. I suggest you read this manual: ADC
Posted on Mar 11, 2010
Sea Breeze
  • 4654 Answers
SOURCE: refrigerator cools freezer wont model rb215labp
I know that model very well and I would like to know how long you have owned it and will you or can you find someone that can perform some electrical test fo you. When Samsung made that brand they made a major mistake on the defrost heater elements. They were woven into the evaporator coil. If less that 5 years old it should fall under sealed parts warranty. When I look at a refrigerator from here there are so many possibilities of what is going on that I ask that this is not where to rate my solution. I see that you mentioned the digital controls but are they visible or gone whacked out? Sea Breeze
Posted on May 09, 2010
Testimonial: "thanks very helpful "
heatman101
  • 43501 Answers
SOURCE: freezer works refrigerator does not
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
caroldon
  • 17129 Answers
SOURCE: MY JENN-AIR REFRIGERATOR #JCD2389GES IS
Possible that the vent is getting blocked to prevent the cool air to be blown into the fridge section. So make sure that the auto defrost is working, if not check the auto defrost timer section, the fan, the heaters.
make sure that the thermostat is set to normal.
Finally shut off the fridge for 6-8 hours and see if the cooling resumes. If so the defrost section must be revisited
Posted on Oct 30, 2010
Refrigerator not cooling; freezer fine
I don't know which model refrigerator you have but nearly all refrigerators cool the refrigerator section by passing cold air from the freezer section. Often the air passage will ice up so that the cold air can't get through. A thermostat controls the air flow,
That should be enough information to help you find the problem. You may have to remove some inner covers to find the problem.
Aug 03, 2014 | Admiral Refrigerators
Admiral side by side, freezer working, fridge not getting cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Admiral 26 cu. ft. Side-By-Side...
Refrigerator does not cool below 50. Freezer side is ok
all cooling comes from thefreezer, lower down air flow to freezer and increase air flow to refrigerator, this should help.
Apr 08, 2011 | Admiral 26 cu. ft. Side-By-Side...
Admiral refrigeration not freezing not cooling
This could be a defrost problem or fan not working all time when compressor is working. What is your model number so I can see what components your model has and then solve your refrigerator problem. Need you to answer so we can get you running, Sea Breeze
Oct 23, 2009 | Maytag Admiral Top-Freezer Refrigerator
Trubleshoot refrigerator staying cold enough
First review the troubleshooting steps in the instruction manual. Check the freezer and frige temperature setting control knobs. Make sure the fan, coils, compressor etc. are clean. Check the door seals, especially at the bottom. If all that does not work, do some more online research (which is what I'm up to right now because I am faced with the same problem).
Sep 02, 2008 | Admiral 26 cu. ft. Side-By-Side...
Same problem no solution not sure but need help bad fridge is getting warm
Not cooling at all? or other symtoms that can help us get you going. Can you make sure the refrigerator is listed as Kenmore
Here are some examples of model numbers for this appliance: 106.8782070, 596.58692890, 119.909851, 119.3101279, 198.887482, 253.835123
•  Inside the refrigerator or freezer, on the upper left or right side wall
    •  Behind the lower crisper drawer
    •  Behind the lower toe kick-plate
    •  On the face frame of the refrigerator body
Can you help locate these numbers so I can assist you with the drawing of that door?  TKS,Sea Breeze
Oct 24, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Admiral - GC2224GEKB
Does freezer cool like the cold food section? Did this suddenly happen, and frozen food began to thaw?  Most freezers control the cooling in the cold food section. The freezer must work fine before the cold food section will work fine. Let us know more, Thanks JT
Oct 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jdthefixer
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
