Question about Bosch Evolution 800 SHE68M05UC Stainless Steel Dishwasher
Cycle was coming to end, pump will not shut off. I manually shut off the DW and restarted it, pump came back on, now is running and I cant restart a new cycle, pump stays on even with door open.
  • 142 Answers
Ther is poss water in plastic base or float is stuck.
Posted on Sep 28, 2009
  • quady Sep 28, 2009
    ther is poss water in plastic base or float is stuck.
How can i set program time when power failure during dishwasher is running ?
There should be a "cancel and drain" or similar to drain the machine and so you can restart your choice of wash cycle when power comes back on again. I don't believe it's possible to have the machine resume from where it was in the wash program if the power fails.
Sep 26, 2015 | Samsung Dishwashers
Dishwasher starts in any type of cycle, runs for a minute, then shuts off as the lights blink out.
in general your wash motor can cause that. It gets old and you can hear the wash motor making a rumbling noise when it turns on. The increased load with cause a thermal coupler to turn the unit off.
Jun 23, 2014 | GE Dishwashers
Bosch dishwasher she43m06uc/48 constantly trying to drain. Cannot reset to end cycle.
Have you tried shutting off power to it from circuit breaker panel for about a minute and leave door open to dish washer . If that does not fix it the float Is stuck from grime build up . You can down load a maintenance manual online on how to access it and cleaning tips.
May 17, 2014 | Dishwashers
Bosch Dishwasher wont run full cycle. Stops/Beeps and says CLEAN.
Hello there,
Could you please supply the full model # off your appliance?
Mar 12, 2014 | Bosch SHX4AP05UC Dishwasher
How do pressure tanks such as varem work?
Varem pressure tanks are simple pressure vessels. They have a chamber where the fluid comes in and a bladder that is pressurized on the other end that the fluid pushes against and compresses the air or other gas that is inside the bladder. When the pressure on the fluid line reaches the pressure switch setting, the pump shuts off and the gas pushes the water back out of the tank (if it is being used) until the pressure switch lower limit is reached and the pump kicks back on, pushing fluid back into the tank. This cycle continues until the fluid is no longer being allowed out of the system.
The bladder pressure is set when the system is empty of water and is set to a couple of pounds less than the low pressure cut on setting, that keeps the bladder from pushing all the fluid out of the tank before the pump comes back on resulting in a zero pressure moment which with some pump switches means it shuts down and has to be manually restarted.
Aug 29, 2012 | Ace Hardware Plumbing
Bosch dishwasher starts, pumps, stops and says it's clean
We have the exact same problem with our Bosch SHE5AL06UC/05 dishwasher. Works great when it works, but we are increasingly having a hard time getting the wash cycle to start.
Apr 13, 2012 | Bosch SHE5AL06UC 24 in Builtin Dishwasher
Duet GHW9150P Front Load Washer: I put my machine on pause and now I can't restart....
Press "end of cycle" for 3 seconds, wait for 2 minutes, try door. Shut door and restart your cycle. If door still does not open - repeat 'end of cycle' press for another 3 seconds.
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Pump will not shut off even with door open
Hi, There is a float under the dishwasher to protect from flooding... If there is a leak and there is water under the dishwasher in the pan then the float switch will turn on the drain pump...
first I could remove the toe panel check in the pan for water... if no water still check the float it maybe stuck up (soap can get under the float and hold it up)
remove water and make sure float in down... if not you may need a new float switch...
Sep 28, 2009 | Bosch Evolution 800 SHE68M05UC Stainless...
Bosch SHX46A (6 years old) Selected regular cycle, pressed On and closed door. Cycle did not start normally. Pump runs, but no water is coming into the DW. I confirmed the water supply line is turned on....
From your description, I doubt that the problem is door latch is the cause.
The first thing that a modern dishwasher does before it begins to fill with water is run the drain pump.  It appears that this DW is not progressing to the next cycle (inlet water) and because the pump runs even when the door is open, I agree that the controller card may have failed.
If possible, inspect all the wire connections (remove main power before you do this) ... if there is a loose connection, the controller could do odd things.
Good Luck!  Please report back what you find, OK?
Apr 14, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
Dishwasher does not complete cycle
It could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Sep 09, 2007 | Miele 24 in. G638 Plus Free-standing...
Bosch Evolution 800 SHE68M05UC Stainless Steel Dishwasher Logo
152 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
