Question about One For All URC4220 Remote Control
I have a universal remote its urc4220 do you know the code to it
  • 403 Answers
Try this as all remotes work about the same when manual setting.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Posted on Sep 28, 2009
Universal codes I'm needing codes for sanyo tv for the universal but i don't know the name brand of the universal remote
0387,0381,0389 are the codes to check. If you wish to get more, check these links. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 03, 2013 | One For All URC4220 Remote Control
I need a code for my tv and it is a zenith
For a Zenith TV (not a combination unit) try the following codes: 0017, 0092, 0178, 0463, 1265 . Please note that universal remotes are limited to codes for devices released 6 months or more before the remote was programmed. If your TV is newer, then you may need a new remote.
The manual for the URC4220 is here: http://www.oneforall.com/uploads/support/8210f6981b8d184d890a27645d6c32df.pdf . If the direct link doesn't work, try here: http://www.oneforall.com/support/manual and select Universal remote control and URC4220 in the drop down menus.
I hope this helps.
May 19, 2011 | One For All URC4220 Remote Control
How do you enter the codes....what are the steps
Hope This Helps. Write Me Back Please.
Programming and Operating the ONEFORALL URC4220 Universal Remote Control
Programming and Operating the One For All URC4220 Universal Remote Control
Features and Functions
Device Table
After programming, the One For All 4 Device Universal Remote Control will be able to control the following types of devices:
Apr 04, 2011 | One For All URC4220 Remote Control
Need code for panasonic vcr pv v4525s
Hello
Setup codes for Panasonic VCR with URC4220 universal remote control are:
0035, 0162, 0616, 1062
OK.
Feb 22, 2011 | One For All URC4220 Remote Control
I need 2 codes for my urc4220. vcr allegro mod# alg420 dvd memorex mod#mud2016blk "A" . Can you please help me ? thank you Jason
there are 3 codes for your vcr : 033 034 039
there are no codes for this model in the universal code catalog, sorry to tell you this. The original remote uses a proprietary code system that differs from the norm, and as such universal remotes don't work with it.
Dec 17, 2010 | One For All URC4220 Remote Control
I am looking for the VCR Codes for a Hitachi VCR on your remote. Could you please give me the code to program my VCR?
The One-For-All code list gives:
standalone Hitachi VCR: 0000 0042 0041
Hitachi TV/VCR combination unit: 0000
See the following page for the full code list: http://oneforall-na.com/remote.php?type=URC4220 and look for the codes link near the bottom of the page.
If your device was built within 6 months before the remote was programmed or is newer than the universal remote, the codes may not work. If this remote allows, try scanning through all the codes. However, if it still doesn't work, you need a newer universal remote, a universal remote that can be programmed from a computer or an exact or substitute replacement remote for the device. Search remotes.com for a replacement remote - use the model and not the manufacturer for the best chance of finding the remote.
I hope this helps.
Sep 18, 2010 | One For All URC4220 Remote Control
What is the code for a Sanyo television?
try these.....
Sanyo 0 1 5 4 ,0 1 5 9 ,0 1 4 6
Please rate my help++++THanks for using FIXYA
May 31, 2010 | One For All URC4220 Remote Control
Help plz
here is the codes for
your remote and that
tv
Sanyo tv code 0154 0159 all for one remote code
Mar 02, 2008 | One For All URC4220 Remote Control
One for all URC4220
go to one for all universal remotes
Feb 13, 2008 | One For All URC4220 Remote Control
One For All URC4220 Remote Control Logo
201 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
