Question about Mitsubishi VS-70707 70" Rear Projection Television
TV does not power on. Shows no signs of "turning over"
When tv is plugged in shows no power. LED lights on front do no light up, nor does tv show signs of receiving any power. I have checked four of the replaceable fuses and they are all in good shape and are the ones that voltage and amps all match up. Any help would be greatly appreciated!
  • imparkunot Sep 28, 2009
    I have left the tv unplugged for over 5 minutes and have been unable to get it tun on or get any response. I checked all the caps and have seen no visible bulges or leakage. I am checking the set for a friend and he thinks he might have replaced the power supply, and only had a few hours on the set before it went out again. Since the home is seldom used that warranty period for the work has already passed. When I was going through the set I was able to see the leftovers of some old resistors and insulation from the previous board and was unable to find anything that it came off of. I can get replacement boards that are refurbs but at this point it is hard for me to recommend replacement. I have been unable to test the power cord as of yet but it is not showing any visible signs of damage. The power outlet and surge strip both work. It is also in a seldom used home and the ac is not always left on, is it possible for the texas heat to cause issues? Thanks in advance
    Sergeant:
    Champion:
  • 269 Answers
Can you power something else from the same receptacle for example a lamp?If yes then I would suggest that the power supply in the TV is kaput
Posted on Sep 28, 2009
  • 647 Answers
Can you measure the voltage at the AC power cord input? (110VAC) Usually yo at least hear arelay click or the set try to start and the go to shut down
I would start by measuring for ac and then see if you have any regulated DC supplies
Read below and decide if you want to tackle the problem yourself if so I’ll help along the way with what info I have. If not contact the nearest repair shop armed with the info below.
A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition.
The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model – for instance convergence output IC’s(CRT projection TV’s) can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom (CRT standard and Projection).
The only way to determine the real cause is :
By an educated guess based on experience or by directly troubleshooting the set – checking fuses, measuring voltages and checking for shorts. Many of the intermittent problems such as, int.(Intermittent) no sound or picture, int. picture shrunken or misshaped. These problems are generally due to cold (bad) solder joints (all TV’s and electronics) that break down under slight temperature changes or vibration and are usually verified by physically tapping the suspected area on the circuit board, or by quickly heating or cooling a suspected component or area ( cold spray and hot air gun). The other main culprit is leaky or dried out capacitors or capacitors that change value depending on temperature. These can sometimes be seen as bulged or leaky and have an acrid odour.
  • johnnydiode
    johnnydiode Sep 28, 2009
    Yes the heat does play a role but TV's are built in consideration of these temperature ranges. more trouble shooting with ameter and possibly diagram is in order.
I have a vizio 470-a0 that is dark and the back light blinks every 5 seconds
The front LED light that shows whether the TV is on or off will flash so many ... press and hold the power button for 5 seconds upon plugging the TV in. ... The flashing code I got meant the power supply was bad.
Feb 08, 2016 | VIZIO, INC. E470-A0 47" 1080p LED-LCD TV -...
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Red light power blinking
power supply problem this can be done by a professional tv repair
Sep 12, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
TV repair man said that the regulator BSC 62A is damage. When apply power to TV on the power light on the front of the TV comes on but nothing shows on screen. Whats wrong?
Jul 06, 2009 | Televison & Video
Won't Turn on, standby LED lit
HI,
I am having the same problem, any solution? Thanks! -Steve
Aug 19, 2008 | Sony KP-61V80 TV
Mitsubishi VS-70707 70" Rear Projection Television Logo
216 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
