Question about Crosley 0187SST Turntable
Everything works on my record player but my turntable doesnt spin
I played a record on my record player and i fininshed the record but then after it was finished there was the crackling sound it usually makes then a pop..so i took the record out and put a new one in and everything was connected and power was on but my turntable doesnt spin! i really want it fixed what happened?
This happened to me tonight. I had the same problem, to activate the player on you need to move it to the right until you hear a click. If you don't do it it won't start. Even if all the power is on. This should fix everything!
Posted on Oct 12, 2009
  • James
    James Apr 20, 2014
    @fullofmoxie Move what to the right? "move "it" to the right. Can you please be a little more specific?
Needle Won't Stay Down
Hi, sounds like the automatic function has gone out of time. With the record player powered of spin the platter manually appox 12 times to reset. Cheers john. Stylus City
Jan 24, 2014 | Sony PS-LX250H Turntable
Detrola record player wont spin, even after moving arm to far right.
I suggest you lift up the turntable matt and see if you can see a belt, which has either broke or come off. You might need a new belt!
Mar 22, 2013 | Audio Players & Recorders
Can't get the record player to work on a detrola
Thank you for the solution of moving the arm to the right and wait for the click, now my turntable works and Keely Smith is playing and sounding great!
Apr 22, 2012 | Crosley Audio Players & Recorders
Im playing my SL-1200MK2 threw serato and it when i press play to make the record spin serato pick up that the record is slowly spinning backwards? and no noise is coming from the record
do you have your timecodes set properly and configured with serato? that could be the issue try adjusting the timecodes w serato and basically re sync them. if this doesnt help please let me know
May 11, 2011 | Technics SL-1200MK2 Turntable
Everything works but the turntable doesn't spin.
please be more specific. if your talking about an actual turntable and its plugged in and doesnt spin the motors dead. please vote 4 thumbs up for the help
May 10, 2011 | Audio Players & Recorders
I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
Jul 24, 2010 | Crosley CR248 Turntable
Turntable platter doesnt spin when you press start/stop
Is your turndable belt driven? If so replace the belt.
Jun 05, 2010 | Numark TTX Turntable
Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Jan 12, 2010 | Crosley Audio Players & Recorders
Home stereo audio problems
Could be a bad patch cord, a setting on the mixer, a faulty mixer (unless it works ok with other amps), or a dirty control on the Sony amp if it has analog controls. Have you tried connecting other sources to the Sony?
Sep 27, 2008 | Audio Players & Recorders
Crosley 0187SST Turntable Logo
1,185 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
